Dear,
I wonder if I can use the
mpguino on my car. My car is a modified 1989 MB 300E which now runs on diesel. So, the signals must be created to drive
mpguino somehow.
I have been trying to do that, using an Arduino clon with a digital screen. In the lab it works, but I havenīt been successful driving it with real signals of the car.
The signals I plan to use are basically two:
a) The tank level difference between starting time and checking time. Not very precise maybe, but better than run a whole tank trip. This info is analog.
b) The distance in km or miles for the same period, taken from the cluster panel, which has a facility to convert analog km in digital km.
The rest is calculation: marginal yield, mean yield, total distance, fuel left, etc.
For calibrating fuel consumption, I plan to calibrate the tank measuring tank signal and writing it down this way:
1. Empty the tank as much as possible.
2. Fill the tank until reserve light is off. This will tell me how much liters I have as reserve.
3. Fill the tank gallon by gallon and measure the resistance and write it down.
This way I take account of the irregular form of the tank and the non linear fuel indicator in the instruments cluster.
4. Go until the tank is full.
When I connect the cables to Arduino, it gets very hot and I have to shut it off, to avoid its destruction.
Using a pot the board works ok, though. But the tank signal is something as a voltage controlled by the sender resistance, which is a different thing. I donīt know how to polarize this signal to input an analog port on Arduino.
Can you help me?
Thank you much.
Old Beaver
Chile
