I put one of my fancy oscilloscopes on it yesterday and it is and follows that same peak and hold pattern we have seen posted. the temptation to hack my computer box(ecm) and find that digital signal is almost overwhelming.
But to tell you the truth the signal seems very dirty on my rig and the voltage difference is nearly impossible to see.
Im going to first look at some way of monitoring the current flow, then failing that, go back to trying to make some sort of flow meter.
