Surprising with that grille and the goofy fender flares. The grille section may be separate (removable). The original one is. Either way, some aftermarket body kit company has a great business opportunity. The weight is definitely a problem. Increased rigidity is much welcome (my 1990 Subaru felt more solid with over 200k on it than the 3 when it was new), but that's a heavy fwd compact. All they should have done with the engine was add DI to the 2.0 and 2.3 and a tall 6th gear. I won't be buying it.
