Old 11-28-2007, 02:43 PM   #9 (permalink)
MetroMPG
Blackfly - '98 Metro
90 day: 67.07 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 107.11 mpg (US)
U.F.O. - '00 Insight
90 day: 83.36 mpg (US)
How, exactly does changing cam lift & duration improve low end torque?
I'll be the first to admit I'm no a cam expert. Everything I've learned, I learned online... recently. Such as:
  • Lower lift & duration, reducing overlap, and advancing cam timing for more low end torque has apparently been understood for a long time.
  • Here's a description of an "economy cam" (designed like the XFi's to shift the torque peak to a lower RPM) in a special "efficient" 1960's era Olds 4-4-2 engine. It has the same effect: lower HP, shifted torque peak (so you can operate the engine more usefully at lower RPM), better fuel economy:
...the camshaft is the key. Intake duration is reduced from 286 to 250', and from 286 to 264' on exhaust. Overlap is reduced from 58 to 36', and lift is reduced from 0.472 in. on the 4-4-2 camshaft to 0.435 on the special ... camshaft.
The vital point of maximum torque is dropped from 3600 to 2600 rpm. - source
I can't defend the decisions of the engineers who made the XFi cam. But the proof is in the pudding - the XFi gets better fuel economy. And I suspect the laws of physics were respected.
