Old 04-14-2009, 11:56 AM   #135 (permalink)
oldbeaver
57.4 mpg best trip.
Mercedes 89 D - '89 300 E
90 day: 33.86 mpg (US)
Skodie - '09 Octavia TDI PD
90 day: 41.14 mpg (US)
Send a message via Skype™ to oldbeaver
Thumbs up Only one flow meter?
Wagonman,
Interesting. Can you explain how you need only one flowmeter if you install a pressure regulator?
Besides diminishing error, you cut cost to half, on flow sensors.
I listen. Try to make a diagram if necessary....
Tks.
Another: What is positive displacement pump?
Originally Posted by wagonman76 View Post
Another problem with the ball type is it needs to be held steady and vertical. Won't happen in a car. I agree with the positive displacement type.
I am not familiar much with diesels. But with most cars, you could install a separate pressure regulator and abandon the original. Then you could install the flowmeter between the regulator and engine, hence requiring only one flowmeter and halving your margin of error.
