Old 04-14-2009, 02:15 PM   #5 (permalink)
cfg83
Pokémoderator
cfg83's Avatar
1999 Saturn SW2 - '99 SW2 Wagon
Team Saturn
90 day: 43.05 mpg (US)
Bullockracing -
Originally Posted by Bullockracing View Post
If you can, the Subaru boxer engines are flat, aren't they? Or an air-cooled VW, although not very FE.
For a solution on mounting the engine lower, a dry-sump pan will let you lower the engine significantly. It may be costly, but it also reduces parasitic drag from the crank splashing in the oil, and you can use an electric oil pump, further reducing working HP required to turn the engine.
That's egg-zactly what I was thinking.
CarloSW2
American Solar Energy Society
