Hey John, you may have mentioned this already, but it might be simpler to figure out/calibrate diesel consumption if you measure the return line flow, and subtract that from what the flow "should" be in the main line if the control sleeve were at max travel for that rpm. idle consumption detection might not be an issue anymore and fluerburger might actually be a good fit (what is min return flow rate?).
