Old 04-15-2009, 02:20 AM   #17 (permalink)
1337
Now on two wheels!
[SOLD] Highway Warrior - '00 Protege LX 1.6L Manual
90 day: 35.93 mpg (US)
Basic Miata - '06 Miata Touring
90 day: 31.65 mpg (US)
Send a message via AIM to 1337
Originally Posted by skyl4rk View Post
Take a manual Fit for a test ride, run it in top gear at about 1800 rpm. How fast does it go? Are you willing to drive it at that speed quite a bit?
Also, get on the highway, how many rpm does it run at 70mph, 60 mph, 50 mph, 40 mph?
Now compare to the automatic version.
Generally lower rpm at speed is going to be better for hypermiling.
I'm a huge fan of manual transmissions because they're (usually) more efficient, easier to fix, and cheaper to replace.
Even so, the EPA highway rating for the automatic Fit is 35 MPG, while the manual is 33. The manual must be geared very low, and the Fit might be one of the few cars that is _more_ efficient with the automatic.
I know it's hypermiling is often easier and more effective with a manual, but if you do sustained highway speeds, the automatic might deserve a look too.
2006 Miata Touring 5MT
2006 VW Jetta TDI 6AT (Sold to buy Miata)
2000 Mazda Protege 1.6L 5MT
2002 Mercedes C230 Coupe 5AT (Water damage, totaled)
