Originally Posted by hummingbird
Thanks for the reply, Christ! I have two points here -
1. With increase in temp I saw a decrease in FE. Should it not be the other way round?
2. The ECU mistook my ~88 octane fuel to be 93, and gave me waay higher FE. What did it do differently with that assumption that it adjusted for the later tanks? (If I know, I can mimic it, so I get back the FE)
1. Again, this deals with more things than just intake air temperature. Specific density of the air, dynamic compression ratio in the engine, etc - all affect detonation characteristics. Without more information, I can't say for sure, or even in thought, that higher intake temp would actually increase your efficiency.
2. The ECU may have kept telling the engine to run at higher timing specs, in a more efficient range than the ~88 octane fuel could normally be run at according to the ECU's programming.
This is about as much as I can tell you specifically... hopefully, someone who knows more about your specific vehicle can chime in.
I'd like to think that people might open their eyes at some point... instead, I find it more and more likely that I'll just close mine.
-- Author kept secret.
Je ne veux pas d'une meilleure vie. Je veux être heureux avec celle que j'ai maintenant.
(I do not want a better life. I want to be happy with the one I have now.)
