OK, found wires(my ecu is under dash, drivers side, above fuse block) tapped vss (yellow w/green stripe) and speed function worked. Then tapped inj (yellow w/black stripe) got nothing. Now speed doesn't work either. Sorry to be such a problem child with this, but when I'm done I'll post pics of proper connections for others w/older metros.
Re-ran entire wire, got speed, but still no fuel data. Also, at highway speed signal fluctuates greatly(65 - 85 mph with vehicle at constant speed), then froze. Disconnected (waiting 20 sec before reconnecting) then functioned ok for a bit, then went blank. I know all my connections are solid, and can't figure what my problem is.
Reason: update
