Old 04-16-2009, 01:29 AM   #1 (permalink)
QuickLTD
QuickLTD's Avatar
Flying Brick - '96 Bonneville SE
90 day: 23.57 mpg (US)
Send a message via AIM to QuickLTD Send a message via Yahoo to QuickLTD
Aero Modding 96 Bonneville
Ok here goes..
I will address these more as I plan and complete each. Taking into account Florida heat.
1, Driving light relocation
2, Partial/Full lower grille block
3, Front under tray/pan
4, Upper grille block
5, Rear under tray/pan
This one is not mine (same color). It was a good picture to give you an idea of what I am working with.
First up: Relocating my driving lights. I dont expect to see any gains from this one it is more for my head and a place to start. I didnt know how I was going to approach this since even the factory delete plugs mount in the same location as the lights. What I discovered was that there is a channel cut in the bumper cover along the top of the driving light mouting pocket. I can make a simple extension and "push" the lights up an inch and a half to the edge of the mounting pocket. This will make it flush on the outside, bottom and much closer on the inside. Then I will close off the remaining channel. I really want to keep the lights so this might be a best of both worlds solution.
I should have the finished pictures by this weekend
Glad to be here and finally get started!
Dean
