The metro bolt pattern is 4 X 4.5" or 114.3mm. The 13" wheels were standard on the convertible, and there's room for even bigger tires if you want the gearing. Special lug nuts, or cone washers are recommended for the 10 mm studs. With the extra ground clearance, you tend to want a belly pan instead of an air dam, which is more practical, too.
