Thread: voltage
Old 04-16-2009, 02:29 PM   #5 (permalink)
jamesqf
How-where are you ckecking the voltage? Do you have a shop manual, and are you using the given procedure for checking battery voltage?
One thing I want to emphasize is that if you somehow get the full 144 Volts DC through your body, it can easily kill you. There are a bunch of control relays in the electronics, so you might not be getting at what the power system actually sees.
