If you have good tread on the fiero tires switch to those and sell the tires of the neon rims. Keep the rims and then when you eventually need to switch the tires out on the fiero rims if you don't like the fieros buy tires for the neon rims and sell the fieros with old tires mounted. This is assuming its going to fit. If they are mounted put it on a jack and switch the tires. Look carefully at the first one and see if it looks like it will fit. Put it down check the tires and the wheel well. If it looks too close abandone the idea.
The wheel will not seat quite right since the other tires/wheels are smaller so if its pretty reasonably close to being ok switch them all and then check again.
