I appreciate the discussion so far but I'm not getting the clear answers I was hoping for.
1. would the 9" motor and motorcycle transmission be a good match for blazing performance?
2. Is 72v enough power to be fast and have good range if you're using a multi-gear transmission?
3. Is 72v enough power (running through a 9") to move 1500lbs (vehicle + passengers)
4. What other options would I have for running a large motor to a single rear wheel if the motorcycle transmission isn't a good choice?
