Old 04-18-2009, 09:33 AM   #9 (permalink)
dremd
6 speed Diesel FTW!
The Golf - '02 Golf GLS TDI
Diesel
90 day: 63.94 mpg (US)
Mongoose - '05 E-bike AWD
90 day: 1810.34 mpg (US)
Send a message via AIM to dremd
Originally Posted by Electric Frenzy View Post
I appreciate the discussion so far but I'm not getting the clear answers I was hoping for.
1. would the 9" motor and motorcycle transmission be a good match for blazing performance?
Originally Posted by dremd
I'm no expert; but I'd bet that 7" motor would have more torque than the Busa transmission can handle.
I'd go with No
2. Is 72v enough power to be fast and have good range if you're using a multi-gear transmission?
More Voltage = more Power; if you are looking for power go 144 volts +++
since you said Blazing performance I'd say no
3. Is 72v enough power (running through a 9") to move 1500lbs (vehicle + passengers)
48 volts will do that; very slowly, but it will do it.
4. What other options would I have for running a large motor to a single rear wheel if the motorcycle transmission isn't a good choice?
Automotive transmission
Reduction housing built to go on a tail shaft
Industrial transmission
Direct drive is cheapest.
We can do the math to see what kind of performance is available. Have you tried eve's ev calculator?
What is the target vehicle? I hear 1500 lbs, Motorcycle, passangers so I'm not really sure what we are working with.
6 speed ALH TDI
