Old 04-18-2009, 01:35 PM   #10 (permalink)
oldbeaver
57.4 mpg best trip.
Mercedes 89 D - '89 300 E
90 day: 33.86 mpg (US)
Skodie - '09 Octavia TDI PD
90 day: 41.14 mpg (US)
Send a message via Skype™ to oldbeaver
Smile Zemco Trip Computer
Dear,
I understood that you said for a front wheel drive car the Zemco will need an extra sensor.
What I need to know is how the Zemco 44 TC connects to a carburated engine. If you can scan the connections diagram, I will know if I take the risk or not.
At last, "a carburated engine" means a non-injected engine, that is, the fuel flow sensors are not attached to injectors. That is exactly what I need: to sense the fuel flow somewhere else. It probably uses mechanic flow sensor, and that is what I need.
If you do not want to send me more info about the Zemco 44, then please tell me about the fuel flow sensors it uses, and where can I get them. Just give me the brand and model. Of course a picture will be a useful complement.
Thank you in advance for sharing that info with me.
Originally Posted by clbolt View Post
As described, this is designed for a carbureted engine, and diesels don't use carburetors. Any adaptation work that this would require would be at your own risk. I've listed everything I know about this unit.
