Old 04-20-2009, 01:41 AM   #1111 (permalink)
nubie
MAD Modder
Originally Posted by bennelson View Post
Actually, all the indications are that the car is using NO GAS and it's a HOT car!
Heh, that is true.
I also measured the frame around the two side gauges, and they are just a little bit too small to remove them and replace with standard 2" volt and amp meters.
If you disassemble the gauge you want to use you can probably mount the workings in that panel, maybe even re-use the needles from your car, then get a nice sticker printed up on the face that will read what the gauge is for, or paint it in with a stencil and some white paint.
(Would it help to use a hole saw to remove the offending material if you wanted to use the whole 2" gauge?
I got a 18 piece set of hole saws in sizes from 3/4" to 5" from Harbor Freight for a ridiculous price, $8 or something.
Harbor Freight Tools
It looks like it is $6, and you will wonder how you ever lived without one.
- Harbor Freight Tools - Quality Tools at the Lowest Prices
You can just cut it out so it overlaps a little bit. )
Love the video Too bad you didn't have 144 volts
