Old 04-20-2009, 09:08 AM   #1 (permalink)
bwilson4web
Engineering first
bwilson4web's Avatar
03 Prius - '03 Prius
90 day: 52.67 mpg (US)
10 Prius - '010 Prius III
90 day: 53.31 mpg (US)
SAE Papers Available
At $15/each, these were a little pricy. But papers can save a lot of 'lab time.' I'll be a little quiet thanks to the release of the SAE hybrid conference papers:
SAE 2009-01-1332 - "Development of New Hybrid System for Compact Class Vehicles"
This is the general systems approach to the new ZVH30 (2010) Prius. It is a recommended first read since it covers all systems.
SAE 2009-01-1048 - "Newly Developed Inline 4 AR Series SI Engine"
Here we get the details of the internal mechanics. One surprise, it uses variable oil pump to reduce internal losses.
NOTE: this is the Camry engine, not the 1.8L ZVH30 engine. Although not the same model, it introduces another energy saving device, a variable oil pump.
SAE 2009-01-0726 - "Development of New Hybrid Transmission for Compact-Class Vehicles"
It took me nearly a year and looking at Graham mini-scanner data to finally stop getting a headache. Time to bulk up on aspirin again. <GRINS>
SAE 2009-01-1322 - "Vehicle Inertia Impact on Fuel Consumption of Conventional and Hybrid Electric Vehicles Using Acceleration and Coast Driving Strategy"
I'm not a fan of "pulse and glide" and this paper requires close reading. A vehicle model was used along with some benchmarking so I'll be looking closely at the model and results. Looking at Table 4, "30-40 mph, 20 seconds of acceleration" shows their field test had a 25% performance improvement over the equivalent steady state, 35 mph cruise speed. My field testing of 25-40 mph, 33 mph cruise speed showed only an 11% improvement. We're off by a factor of two so the I'll be looking closely at their protocol.
SAE 2009-01-1321 - "An Analytic Foundataion for the Two-Mode Hybrid-Electric Powertrain with a Comparison to the Single-Mode Toyota Prius THS-II Powertrain"
Sad to say, this is an analysis of the soon to be replaced transaxle. Still, a quick scan suggests there may be some analytic techniques that may help us understand the ZVH30.
NOTE: This report is flawed because the author didn't realize MG1 is rated at 24 kW yet his model claims a loss of 15.6 kW at 80 mph. There is no way with any reasonable efficiency numbers that the MG1-to-MG2 power loss could exceed 3 kW. I'm also concerned about his use of "42 mph" as "its mechanical point," which is used in other parts of the same paper as a transition between a forward or reverse power flow.
BTW, I would recommend advocates of other hybrids search the SAE web page for released papers. The conference starts on Monday and releasing them before the conference gives folks a chance to read and review them. NOTE: there are some security features implemented in these SAE papers to limit making multiple copies. For example, there is a maximum limit of two print operations on a paper ... even if the software has a flaw that causes it to fail. I use a Mac and have two copies of paper that are lacking the first three pages and I can't print another copy. This leaves screen snapshots as the only way to get a hardcopy.
Bob Wilson
Local record
