Old 04-20-2009, 04:21 PM   #1 (permalink)
Southcross
Manic Rabbit
Southcross's Avatar
Slow-n-Low - '81 Rabbit S
90 day: 33.97 mpg (US)
Rear Alignment: Drivability vs Economy
I'm fixing the alignment on the rear of my car... I'm wondering the "if and why" of the OE Toe-in/out in my service manual...
The factory service manual (which doesn't always provide "perfect"/Ideal numbers).... has the rear wheels Toe'd In by 20' (1/3 degree), or a total Toe-In of 40' or 2/3 degree... I'm thinking about the "why"?
I assume there is a stability benefit to having your rear "Toe'd In"?
Would I benefit economically if I were to manually set it to a more neutral "Zero"? My rear end is pretty ehF'd as it is (until I do the alignment), but with a neutral rear end, would I run into drivability issues?
I should add this is a FWD car with a solid rear axle beam
-Edward
Driven on Colorado roads, where NOTHING is flat
Present City 3x / Highway 4x
Goal: 4x / 5x
