Old 04-20-2009, 04:59 PM   #3 (permalink)
Southcross
Manic Rabbit
Southcross's Avatar
Slow-n-Low - '81 Rabbit S
90 day: 33.97 mpg (US)
"increasing"? you mean "more" Toe-in?
I would expect those things, but what if you decrease Toe to a neutral Zero degrees?
Slight Toe-In I would suspect would have a benefit to turning/curve handling... as its pulling into itself on a curve vs pushing away.
Toe-out I would also expect that from the rear end, it would seem that you have two tires pulling/pushing the car to the side as you drive, gawd forbid one suddenly lost traction.
-Edward
Driven on Colorado roads, where NOTHING is flat
Present City 3x / Highway 4x
Goal: 4x / 5x
