Old 04-21-2009, 07:27 PM   #11 (permalink)
dremd
6 speed Diesel FTW!
The Golf - '02 Golf GLS TDI
Diesel
90 day: 63.94 mpg (US)
Mongoose - '05 E-bike AWD
90 day: 1810.34 mpg (US)
Send a message via AIM to dremd
I've got an Idea; build an MPG guino run the car around for a few tanks (get it calibrated).
Then do a simple experiment.
At constant speed / load switch on/ off the HHO generator (cockpit mounted switch). If less / more fuel is in fact required then the dutcy cycle of the injectors will change and be detected by the Guino.
Repeat several times to get a consistent reading
Sounds good?
Any body is more than welcom to modify my proposed test method.
6 speed ALH TDI
