2017-08-21 592.2 11.858 $2.499 49.94 "Completely stock filled up at 292,923 miles. Missing oem splash shield. Intake manifold almost completely filled with carbon/gunk."
2017-08-27 617.6 11.982 $2.499 51.54 "A little more city driving with addition of the skid plate/bellypan"
2017-09-06 755.2 14.635 $2.599 51.6 "Majority Highway, performed a diesel purge halfway through the tank."
2017-09-13 794.8 15.538 $2.659 51.15 ""
2017-09-21 808.4 15.379 $2.599 52.57 "Paid more attention to acceleration and coasting"
2017-09-30 749.2 14.872 $2.409 50.38 ""
2017-11-24 763.1 14.426 $2.649 52.9 "Cleaned intake manifold, injectors rebuilt, timing belt, clutch."
2017-12-01 757.9 13.947 $2.649 54.34 ""
2017-12-11 755.3 14.171 $2.649 53.3 "Avg. Temp down to 30 degrees, lots of 35+ mph headwind and snow tires."
2017-12-18 769.8 13.926 $2.649 55.28 ""
2017-12-29 765.3 15.386 $2.599 49.74 "400 miles of highway and the other was a mix of city/ some highway."
2018-01-04 764.7 14.625 $2.899 52.29 ""
2018-01-19 781.2 14.698 $2.599 53.15 ""
2018-01-28 757.8 14 $2.779 54.13 ""
2018-02-04 767.1 13.857 $2.779 55.36 "Adjusted timing to slightly advanced, still well within the timing chart per the Bentley manual."
2018-02-11 754.9 14.664 $2.779 51.48 "2 snow storms on this tank."
2018-02-21 756.5 13.922 $2.779 54.34 "I plan to go one more tank and then might retard the timing a little bit, it is hard to tell if it is the weather effecting mileage or the previous timing change I made. I am also on a very lean IQ setting, so I will attempt to get that within specs before moving the timing around again."
2018-02-28 875.7 15.997 $2.779 54.74 ""
2018-03-07 754 14.047 $2.739 53.68 "Installed summer tires after I filled up this tank."
2018-03-18 776 14.297 $2.739 54.28 ""
2018-03-29 760 13.712 $2.739 55.43 ""
2018-04-05 834.2 15.354 $2.659 54.33 ""
2018-04-12 842.8 15.506 $2.659 54.35 ""
2018-04-22 737.7 14.489 $2.979 50.91 "lots of in town driving and lost my rear exhaust section. Exhaust was repaired just prior to fill up."
2018-04-28 801.4 15.501 $2.829 51.7 ""
2018-05-04 727.5 13.894 $2.829 52.36 ""
2018-05-11 812 15.513 $2.829 52.34 ""
2018-05-23 808.8 14.275 $2.829 56.66 ""
2018-05-30 758 13.145 $2.979 57.66 ""
2018-06-09 840 14.95 $14.95 56.19 ""
2018-06-16 796.7 14.602 $2.899 54.56 ""
2018-06-26 811.1 14.4 $2.979 56.33 ""
2018-07-03 774 14.314 $2.979 54.07 ""
2018-07-11 780.3 14.072 $2.979 55.45 ""
2018-07-22 851.7 15.197 $3.199 56.04 ""
2018-08-02 862.1 15.968 $2.979 53.99 ""
2018-08-09 752 13.712 $2.979 54.84 ""
2021-01-19 788.2 15.455 $2.369 51 "PD150 intake, PD150 Intake Manifold, New Turbo, New Winter Tires, Removed front Air damn. 400,920miles."
