2016-07-29 |
161.56 |
4.71 |
34.3 |
"first fill, 3 clicks: from Montreal; CEL on for EVAP; soot in tail pipe; speedo was under-reporting by 10%, meaning ~110-115 km/h actual on highway, ~90 km/h HWY 2; probably wasn't completely filled at full serve stn." |
2016-08-02 |
130.49 |
2.03 |
64.28 |
"4 slow clicks, odo verified accurate against Google Earth & GPS; SG said 118 mi, 55.6 mpg US, 35 mph avg (ODB speed = good), @ fuel 6% offset; mostly rural highway driving target = PSL; some EOC, some EonC" |
2017-10-15 |
188.28 |
4.63 |
40.67 |
"Pre-e-test 2 fills: 10L first, then 7L, 3 slow clicks, CEL came on for EVAP at Kingston highway off ramp after multiple attempts to do drive cycles to get ""READY"" status on monitors for etest. Odo at e-test = 214,002 on Oct 21, 2017" |
2017-10-18 |
62.14 |
1.28 |
48.55 |
"Pre-e-test last short fill: Ultramar Brockville (no rcpt); guessed at odometer reading & fuel volume based on prev fill" |
2017-11-08 |
114.33 |
1.88 |
60.81 |
"First fill-up after the e-test. Calibrated odo on the trip to C&P's immediately following this trip and it was accurate vs. Google & GPS" |
2018-01-18 |
446.14 |
8.63 |
51.7 |
"4 slow clicks, mostly rural highway driving (C&P's, some local driving, incl. sitting Harris, Merrickville x2, Kville park & fly boarding; SG changed during this tank, replacement had wrong settings, so no good SG data." |
2018-02-12 |
280.24 |
5.71 |
49.08 |
"3 slow clicks, problems with stalling - removed kill switch this tank, also some idling (PCV/removed remote start); Trips include canal skating x2; Kville park 'n' board; some local driving; SG accidentally reset so no data. Target speed @ PSL, incl 100+ km of 416/417 driving." |
2018-03-01 |
632.56 |
10.3 |
61.41 |
"3 slow clicks, includes 5L splash. 95% secondary highway driving in all weather, target speed at or close to PSL. Trips include Ott skating #2 (210), Mrs G's (380), Kville park'n'board x1 (110); C&P's (200); Kemptville (110), local driving (10). Front driver's side tire low/flat for ~300 km(?). SG said: 58.9 mpg @ 7% offset; 624 mi (late reset); 36 mph avg." |
2018-04-08 |
557.99 |
9.12 |
61.18 |
"3 slow clicks (regular); Trips include S falls (110), Spencerville (110), Kville park'n'board x2 (220); C&P's (200); local driving (10); all secondary roads. Target speed close to PSL. RE92's on; SG said: 61.8 mpg @ 7% offset; 554 mi; 35 mph avg." |
2018-06-08 |
613.29 |
9.06 |
67.69 |
"5 slow clicks (prem) overfull; trips include e.g. Prescott (45), Merrick x2, kayak (210), C&P's x3 (600) partial return w/ flat tire, Poonamalie S Falls (100), all secondary roads. Target speed close to PSL. RE92's on; SG said: 68.2 mpg @ 7% offset; 594 mi; 34 mph avg.; CAD skirts on. Needle almost touching E." |
2018-08-01 |
714.58 |
9.98 |
71.6 |
"5 slow clicks (prem) overfull, plus 3L splash; trips include e.g. many to Charleston L, C&P's x2?, Kingston; all secondary roads. Target speed close to PSL. RE92's on; SG said: 70.4 mpg @ 7% offset; 709 mi; 34 mph avg.; skirts off, Kammback off for last 150 km; Needle almost touching E before 3L splash." |
2018-12-17 |
740.67 |
10.84 |
68.33 |
"10L splash + 3 slow clicks (prem). This tank is to mid-August, then mid-Nov to now. Trips include e.g. Charleston L, Kingston x2; C&P's (Dec); all secondary roads. Target speed close to PSL. RE92's on in Aug, snows in Nov; SG messed up, no tank data. 7% offset; skirts off, Kammback off in Aug, on for Dec." |
2018-12-28 |
234.26 |
3.85 |
60.85 |
"3 slow clicks (prem). Trips include e.g. Burritt's x3; some local, all secondary roads. Target speed close to PSL. SG said 62.2 @ 7% offset" |
2019-02-01 |
745.65 |
12.44 |
59.94 |
"3 slow clicks (regular), includes 15L splash. Needle width into E mark, 7L left. Trips include Picton, Merrickville snowbd day, Burritt's x3, Ottawa skate w/ 401 fishtail, some local, rest secondary roads. SG no data @ 7% offset; Muffler starting to unmuffle." |
2019-02-10 |
284.59 |
5.63 |
50.55 |
"3 slow clicks (premium), Trips include Merrickville for failed XC ski meet, Ottawa ice dragon boat, skate, C&P's, back to Ott at/near PSL on 401 into strong headwind 1-way; more local driving, SG 51.3 mpg / 281 mi / 32 mph avg / 7% offset." |
2019-03-07 |
451.12 |
7.95 |
56.74 |
"223,223 km. 3 slow clicks (premium), Trips include Ktown-Bville x 4, mostly HWY2, but also 1 way on 401 near PSL first trip; local driving in Ktown & Bville; SG froze/reset; no tank data." |
2019-03-31 |
516.36 |
8.24 |
62.67 |
"224,054 km. 3 slow clicks (premium), Trips include Ktown-Bville x 2? HWY2, Mrs G's, Merrickville, C&P's. SG froze/reset briefly. 2 no-start conditions this tank, both on 0C wet mornings (wet wires), fixed with hair dryer & insulation on motor. Oil changed this tank." |
2019-05-08 |
643.12 |
8.99 |
71.54 |
"3 slow clicks (reg+premium), Trips include Merrickville, C&P's multiple, Manotick. SG was in L's Prius (<5 km) and said: 68.5 mpg / 502 mi / 37 mph avg. Muffler broke on this tank. 225089" |
2019-06-01 |
629.45 |
9.07 |
$1.249 |
69.4 |
"3 slow clicks (reg), Trips include C&P's x5. SG said 71 / 34 mph / 499 mi. Brake line perforated on this tank. 226102" |
2019-06-22 |
917.14 |
12.15 |
75.48 |
"Includes 10L splash. 3 slow clicks (reg), Trips include Ktown, Seeley's, several C&P's. SG said 71.5 / 37 mph / 855 mi. CV joint started clicking on this tank. Re-filled with 21L premium, 15L mid-grade. 227578" |
2019-07-14 |
673.57 |
8.71 |
77.33 |
"3 slow clicks (20L premium + 13L reg), Trips include Charleston x2, Picton, Ktown, Edmunds Lock w/kayak (kamm open), C&P's. SG said 72.8 / 35 mph / 667 mi. 7% fuel offset. 228662 km" |
2020-05-29 |
496.48 |
8.01 |
61.98 |
"3 slow clicks (15L premium + 15L reg), Car last driven briefly in fall 2019 before getting Mirage in November. SG data lost. Tank MPG affected by repairs to car in spring 2020 (exhaust/alternator)." |
