2008-03-24 316.5 19.4 16.31 ""
2008-04-21 295.9 16.81 17.6 ""
2008-05-12 349.1 17.56 19.88 "It's been a lot more consistantly warm and I've been experimenting with more and longer EOCing."
2008-06-13 286 14.93 19.16 ""
2008-08-12 296.6 15.42 $3.439 19.23 "Thanks to my motorcycle this is the first fillup in 2 months."
2008-09-22 380.1 19 $3.329 20.01 "More highway than normal in this tank."
2008-10-08 312.3 15.44 $2.879 20.23 "E10"
2008-10-30 222.2 11.74 $1.979 18.93 "I couldn't wait to get a whole tank in case the price went up."
2008-11-04 29.3 1.47 $1.849 19.93 "Had to get my tank filled before the price shoots up after the election If not, I only wasted driving two blocks out ot the way."
2008-11-18 208.3 11.49 $1.699 18.13 ""
2008-11-24 166.5 8.27 $1.519 20.13 ""
2008-12-21 257.2 16.81 $1.519 15.3 ""
2009-01-06 348.6 18.6 $1.749 18.74 "E10
I can't catch a break. I wait 4 days to finish the tank and the price goes up 33 cents, I fill up and the next day the price drops 5 cents!"
2009-01-28 287.2 18.74 $1.739 15.33 ""
2009-02-20 238 14.65 $1.569 16.25 "Pump #8 E10"
2009-04-05 291 17.17 $1.799 16.95 "Pump #5 E10. Miles might be off by one or two because the battery change cleared my trip meters."
2009-04-25 304.8 16.13 $1.759 18.9 "E10 Pump #5"
2009-05-20 335 17.21 $2.199 19.47 "Pump #6"
2009-07-23 377 17.58 $2.219 21.44 "Put new smaller tires on. Went from huge 265/60R15 to 215/75R15. This tank was:
100 miles on old tires,
50 miles on new tires@max pressure(44 PSI)
Remainder on new tires@50PSI"
2009-08-23 477 20.58 $2.339 23.18 "60PSI tires and a 160 mile long highway trip to my parents' house."
2009-09-27 385 16.81 $2.179 22.9 "Pump #4 E10 100% city driving"
2009-10-27 395.3 18.36 $2.459 21.53 "E10 Kum&Go Pump #3
Lost trip mileage when disconnected battery to install onboard charger. Estimated 85 miles."
2009-11-28 405.7 18.76 $2.439 21.63 "E10 - I need to check the pressure in all my tires and put in my winter air. The one I checked was down 28lbs!"
2010-02-26 287.8 18.566 $2.499 15.5 "E10 89 octane
Pump #1"
2010-03-17 308 17.31 $2.599 17.79 "None, probably E10 89 octane"
2010-03-27 321.3 17.486 $2.579 18.37 "E10 89 octane
Pump #1"
2010-04-03 278.4 15.002 $2.699 18.56 "E10 89 octane
Pump #1"
2010-04-12 321.3 17 $2.619 18.9 "E10 89 octane
Pump #1"
2010-08-02 336.2 18 $2.499 18.68 "E10 89 octane
Pump #1"
2010-11-01 352.1 18.022 $2.539 19.54 "E10 87 octane"
2010-12-24 235.3 14.416 $2.899 16.32 "E10
Pump #10"
2011-01-07 299.7 18.483 $2.979 16.21 "E10 89 octane
Pump #1"
2011-02-11 298.8 20.029 $2.999 14.92 "E10 89 octane
Pump #1"
2011-04-10 303.2 17.026 $3.649 17.81 "E10 89 octane
Pump #6
Unknown station, not QuickTrip"
2011-05-03 320.9 18.453 $3.799 17.39 "E10 89 octane
Pump #1"
2011-07-21 346.3 17.587 $3.439 19.69 "E10 89 octane
Pump #3"
2011-09-23 362 18.683 $3.349 19.38 "E10 89 octane
Pump #1"
2011-11-11 332.2 17.905 $3.199 18.55 "E10 89 octane
Pump #1"
2011-11-21 185.2 10.298 $3.069 17.98 "E10 89 octane
Pump #1
Short fill because gas prices were going up"
2011-12-15 269.8 16.111 $2.999 16.75 "E10 89 octane
Pump #1"
2012-01-08 267.1 15.592 $3.099 17.13 "E10 89 octane
Pump #1"
2012-01-19 337.7 17.715 $3.059 19.06 "E10 89 octane
Pump #1"
2012-02-20 281.7 17.754 $3.349 15.87 "E10 89 octane
Pump #1"
2012-04-19 346.3 19.25 $3.499 17.99 "E10 89 octane
Pump #1"
2012-07-09 304.2 16.327 $3.299 18.63 "E10 89 octane
Pump #2"
2012-10-08 338.8 17.736 $3.649 19.1 "E10 89 octane
Pump #2"
2012-11-10 243.1 13.524 $3.199 17.98 "Pump #2
Kum&Go"
2012-12-13 318.8 18.219 $2.999 17.5 "E10 89 octane
Pump #1"
2013-01-10 255.6 16.19 $2.989 15.79 "E10 89 octane
Pump #1"
2013-02-06 299.2 18.148 $3.399 16.49 "E10 89 octane
Pump #1"
2013-03-07 261.7 16.686 $3.599 15.68 "E10 89 octane
Pump #2
Kum&Go"
2013-04-19 298.3 18.196 $3.359 16.39 "E10 89 octane
Pump #1"
2013-08-10 285.1 15.079 $3.269 18.91 "E0 87 octane
Pump #7
Casey's"
2013-09-17 368.9 19.004 $3.399 19.41 "E10 87 octane
Pump #1"
2013-10-05 280.8 14.001 $3.179 20.06 "E10 87 octane
Pump #1"
2013-11-08 189.7 10.692 $2.799 17.74 "E10 87 octane
Unknown pump
Kum & Go"
2013-12-14 251.9 16.273 $2.799 15.48 "E10
Pump #6
Pilot"
2014-02-25 310.3 19.022 $3.199 16.31 "E10 87 octane
Pump #1"
2014-03-29 311.7 18.006 $3.399 17.31 "E10 87 octane
Pump #5"
2014-05-09 308.3 16.72 $3.439 18.44 "E10 87 octane
Pump #1"
2014-07-11 335 16.911 $3.399 19.81 "E10 87 octane
Pump #1"
2014-10-10 216 11.461 $2.999 18.85 "E10 87 octane"
2014-12-10 302.7 17 $2.349 17.81 "E10 87 octane
Pump #1"
2015-01-14 299.6 18.138 $1.839 16.52 "E10 87 octane
Pump #2"
2015-02-19 301.1 18.509 $2.149 16.27 "E10 87 octane
Pump #1"
2015-04-26 297.1 17.758 $2.379 16.73 "E10 87 octane
Pump #1"
2015-10-23 329.9 21.239 $2.388 15.53 "'
E10 87 octane 18.102 gals@$2.329
(85.230%)
E0 87 octane 3.137 gals@$2.729
(14.770%)
E8.5 $50.72 total/21.239 total gals=$2.388/gal
Pump #1
Why the weird fill?
I had to use up some old gas that I had for the snow blower last winter."
2015-11-23 301 17.043 $1.979 17.66 "E10 87 octane
Pump #1"
2016-01-08 286.7 17.504 $1.799 16.38 "E10 87 octane
Pump #1
ODO: 89715
I lost the trip distance because my battery died. I logged an estimated distance that wouldn't alter my average so that I could log the other, known, data."
2016-02-04 287 18.002 $1.599 15.94 "E10 87 octane
Pump #1
ODO: 90,002"
2016-03-15 321 19.106 $1.989 16.8 "E10 87 octane
Pump #1
ODO: 90323"
2016-05-10 285.27 17.416 $2.079 16.38 "E10 87 octane
Pump #2
ODO: 90939
I lost the trip again, I'm going to have to fix that battery. Also filled up on March 18th without logging it, so I can't even use the odometer. I logged an estimated distance that wouldn't alter my average so that I could log the other, known, data."
2016-06-30 333 17.619 $2.179 18.9 "E10 87 octane
Pump #5
Casey's
Granger, IA
ODO: 91272"
2016-08-02 301 18.427 $1.959 16.33 "E10 87 octane
Pump #1
ODO: 91573
Lot's of AC used on hot days with the baby."
2016-09-20 244 17.032 $2.049 14.33 "E10 87 octane
Pump #1
Odo: 91817"
2016-11-08 286 17.654 $2.079 16.2 "E10 87 octane
Pump #1
ODO: 92103
Switched back to the huge 265/60R15 tires on Oct. 17th. About half of this tank was on the 215/75R15s and about half was on the huge tires."
2016-12-05 214 17.484 $2.159 12.24 "E10 87 octane
Pump #3
ODO: 92317"
2016-12-20 185 17.575 $2.259 10.53 "E10 87 octane
Pump #2
ODO: 92502"
2017-01-10 201 17.122 $2.359 11.74 "E10 87 octane
Pump #1
ODO: 92,703"
2017-01-31 230 17.386 $2.259 13.23 "E10 87 octane
Pump #1
ODO: 92,933
I finally got the battery terminal fixed so I can use the trip again."
2017-02-21 258.3 18.185 $2.229 14.2 "E10 87 octane
Pump #1
ODO: 93,190"
2017-03-18 264 18.758 $2.199 14.07 "E10 87 octane
Pump #2 Flying J on I35
ODO: 93,454"
2017-04-07 292 18.485 $2.279 15.8 "E10 87 octane
Pump #1
ODO: 93,746"
2017-06-14 297.5 18.36 $2.099 16.2 "E10 87 octane
Pump #1
ODO: 94,044"
2017-07-24 265.7 18.334 $2.149 14.49 "E10 87 octane
Pump #1
ODO: 94,309"
2017-08-17 264.9 17.826 $2.339 14.86 "E10 87 octane
Pump #2 HyVee gas Urbandale
ODO: 94,575"
2017-09-15 277.3 17.953 $2.599 15.45 "E10 87 octane
Pump #1
ODO: 94,853"
