0000-00-00 |
240.7 |
5.59 |
$4.139 |
43.06 |
"All Stock, FGB, FAUX, FWC, SMD, RWS, UBT, 50PSI, EOCING, MPGUINO, PSD.
$23.14
70*F at fillup, Fountain Valley Brookhurst Shell, pump #2
More city driving =(" |
0000-00-00 |
402.9 |
8.277 |
$4.159 |
48.68 |
$34.42
66*F at fillup, Tustin Ranch Shell, pump #5
BEST TANK EVER!" |
0000-00-00 |
386.2 |
8.953 |
$4.079 |
43.14 |
$36.52
65*F at fillup, Tustin Ranch Shell, pump #5" |
0000-00-00 |
370.1 |
8.204 |
$4.319 |
45.11 |
"All Stock, FGB, FAUX, FWC, SMD, RWS, UBT, 50PSI, EOCING, MPGUINO, Power Steering Delete.
$35.43
62*F at fillup, Tustin Ranch Shell, pump #5" |
0000-00-00 |
402.9 |
8.277 |
$4.159 |
48.68 |
$34.42
BEST TANK EVER!" |
0000-00-00 |
240.7 |
5.59 |
$4.139 |
43.06 |
$23.14
Girlfriend back in town for the summer, 80% city driving from now on. =(" |
2009-00-02 |
346.6 |
34.42 |
"1st Tank Electrolyzer
73*F, 55hwy/45city, Tustin Ranch Shell, pump #5." |
2009-03-04 |
313.6 |
10.05 |
31.2 |
"1st tank with HHO ""Vaporizer"" installed.
*54F at fillup. Mostly hwy. Shell Tustin Ranch, Pump #5." |
2009-03-09 |
330.9 |
10.14 |
32.63 |
"2nd tank with HHO ""Vaporizer"" installed.
*57F at fillup. Mostly hwy. Shell Tustin Ranch, pump #5." |
2009-03-15 |
309.3 |
9.79 |
31.59 |
"3rd tank with HHO ""Vaporizer"" installed.
*56F at fillup. Mostly hwy. Shell Tustin Ranch, pump #5." |
2009-03-20 |
281.5 |
8.97 |
$2.339 |
31.38 |
"4th tank: Removed ""Vaporizer."" Hm....
*56F at fillup. Mostly hwy. Shell Tustin Ranch, pump #5" |
2009-03-27 |
328 |
10.36 |
31.66 |
"5th tank: NO Vaporizer, all stock. i SWEAR i've NEVER gotten this much mileage ever since the engine swap, no matter how slow i drive.
Installed vacuum gauge half tank.
Maybe this HHO deal is a scam? I have faith, must stay diligent. I think next tank I'll install the actual HHO generator in my car. Or maybe I should put the Vaporizer back in just to double check? Hopefully I should get more consistent results now with the vacuum gauge installed.
*68F at fillup. Mostly hwy, Shell Tustin Ranch, pump #5" |
2009-04-04 |
241.6 |
8.08 |
29.9 |
"Had to help sister move. Gas station full, could not wait for my usual gas pump. Had to fill up using different gas pump. May need to disregard these results for HHO experiment.
*71F at fillup, Mostly hwy. Shell Tustin Ranch, pump #1" |
2009-04-05 |
121.1 |
3.49 |
34.7 |
"Helped sister move 60 miles to new house. Definitely used more hypermiling techniques (EOC, P&G, Drafting). All stock. Finally able to fill up at regular pump. May still need to disregard this reading for HHO experiment due to hypermiling and pump. Highest MPG EVER achieved since owning the car.
*99% hwy. Tustin Ranch Shell, pump #5." |
2009-04-05 |
11.4 |
0.46 |
24.78 |
"Quick fill up before installing HHO Electrolyzer. All City mpg btw.
*All city. Shell Tustin Ranch, pump #5." |
2009-04-05 |
30.1 |
0.7 |
43 |
"1st quick test with Electroylzer installed. Looks promising. 100% highway driving.
*66F at fillup. 100% hwy. Shell Tustin Ranch, pump #5." |
2009-04-05 |
30.1 |
0.74 |
40.68 |
"2nd quick test with Electrolyzer installed. 100% highway. Again, looks promising. Lets see if my car's ecu decides to defeat the HHO by riching up the Air/Fuel ratio.
*65F at fillup. 100% hwy. Shell Tustin Ranch, pump #5." |
2009-04-14 |
312.2 |
9.85 |
31.7 |
"1st tank with Electrolyzer installed. Bleh, same as before. However, less HWY driving than usual (65/35) so maybe it's a good result? I think I'll try the O2 sensor ""cheap mod"" next. The water4gas manual says this mod is the ""turning point"" in terms of gas-saving.
*WARNING do not attempt to make your motor run LEAN without a Hydrogen On Demand system installed. NOTE TO SELF, listen for engine knock, and check spark plugs regularly.
*60F at fillup. 65hwy/35city. Shell Tustin Ranch, pump #5." |
2009-04-17 |
111.9 |
4.02 |
27.84 |
"ACK!! 2nd tank with Electrolyzer installed. Tried the cheap O2 mod, but obviously made the MPG worst, decided to fill up early and try something else.
Did some research, going to re-do the cheap O2 mod, but make a better seal around the sensor. Also, ""T'd"" the hydrogen into the IAB port instead of the Evap Purge port. Let's see what happens.
*58F at fillup. 60hwy/40city. Shell Tustin Ranch, pump #5." |
2009-04-23 |
338.7 |
10.32 |
32.82 |
"3rd tank with Electrolyzer. Showing some improvement finally, with even less highway miles this tank.
*59F at fillup, 60hyw/40 city. Shell Tustin Ranch, pump #5
*4/24/09 update, checked under hood and discovered electrolyzer was not producing HHO due to loose connection. Perhaps I could've achieved better mileage?" |
2009-05-02 |
291.3 |
10.22 |
$2.53 |
28.5 |
"4th Tank Electrolyzer. LOTS of city driving. Started keeping a more accurate log of hwy/city driving.
62*F at fillup. 33Hwy/67City. Tustin Ranch Shell, pump #5." |
2009-05-12 |
303.6 |
10.54 |
28.8 |
"5th tank with Electrolyzer. LOTS of city driving.
60*F at fillup, 47hwy/53city, Tustin Ranch Shell, Pump #5." |
2009-06-02 |
329.9 |
9.99 |
33.02 |
"All stock. Failed smog check due to bad catalytic converter (3rd one!) Replaced catalytic converter and installed a brand new O2 sensor. Wow! Look at the difference in the mileage boost with all of this city driving! I think it's time to restart my HHO project with the new O2 sensor to see if the readings fluctuate.
62*F at fillup. 19hwy/81city. Tustin Ranch Shell, pump #5." |
2009-06-04 |
89 |
2.84 |
31.34 |
"Accidentally reset trip meter while cleaning up gauge cluster.
Not sure of ambient temp or highway/city ratio, Tustin Ranch Shell, pump #5." |
2009-06-15 |
9.93 |
32.73 |
"All stock.
64*F, 48hwy/52city, Tustin Ranch Shell pump #5" |
2009-06-24 |
348.4 |
9.51 |
$3.23 |
36.64 |
"ALL STOCK, more highway miles.
64*F at fillup, 59hwy/41 city, Tustin Ranch Shell, pump #5." |
2009-07-08 |
10.32 |
33.14 |
"ALL STOCK. Mostly highway miles again, however, it was all driving 70+ mph so the vacuum gauge needle was constantly below my targeted 15in.
64*F at fillup, 58hwy/42city, Tustin Ranch Shell, pump #5." |
2009-07-24 |
330.6 |
9.83 |
33.63 |
"ALL STOCK, more city driving.
70*f at fillup, 46hwy/54 city, Tustin Ranch Shell pump #5" |
2009-08-07 |
348.4 |
10.22 |
34.09 |
"ALL STOCK, slightly more highway miles.
66*F at fillup, 54hwy/46city, Tustin ranch shell, pump #5" |
2009-08-19 |
265.5 |
7.8 |
34.04 |
"ALL STOCK. At 1/2 tank, installed Alternator disable switch. Didn't seem to make any difference. Going to start the HHO experiment again now that I have a good consistent baseline mpg rating.
66*F at fillup, 56hwy/44city, Tustin Ranch Shell, pump #5." |
2009-09-02 |
346.6 |
34.42 |
"1st. Tank Electrolyzer. Hot summer night!
73*F at fillup, 55hwy/45city. Tustin Ranch Shell, pump #5." |
2009-09-13 |
276.4 |
8.53 |
32.4 |
"2nd Tank Electrolyzer. Looks like getting similar results as before. No change to slightly lesser mpg's.
67*f at fillup, 48hwy/52city, Tustin Ranch Shell, pump #5" |
2009-09-30 |
357.5 |
34.38 |
"3rd Tank Electrolyzer.
61*F at fillup, 55 hwy/45 city, Tustin Ranch Shell, pump #5" |
2009-10-12 |
321.1 |
9.8 |
32.77 |
"4th Tank Electrolyzer, installed 02 mod.
61*F at fillup, 50hwy/50city, Tustin Ranch Shell, pump #5" |
2009-10-15 |
63.8 |
1.96 |
32.55 |
"5th tank Electroylyzer, with o2 mod. Not sure if more city driving or Shell switched to winter blend. Will run for one more test, then remove everything back to stock.
65*F at fillup, 41hwy/59city, Tustin Ranch Shell, pump #5." |
2009-10-20 |
85.3 |
2.47 |
$3.239 |
34.53 |
"6th Tank Electrolyzer, O2 foil.
61*F, 62hwy/38city, Tustin Ranch Shell, pump #5." |
2009-10-30 |
75.3 |
2.7 |
27.89 |
"7th fill with Electrolyzer, moved to MAP sensor (pre throttle body), zip tie o2 mod, noticed tire psi was low (30's). Refill psi back to 35.
54*F at fillup, 13hwy/87city, Tustin Ranch Shell, pump #5." |
2009-11-05 |
152.6 |
4.18 |
36.51 |
"8th tank Electrolyzer in MAP sensor (pre throttle body), zip tie o2 mod, tires back up to 35psi.
64*F at fillup, 66hwy/34city, Tustin Ranch Shell, pump #5" |
2009-11-09 |
130.9 |
4.15 |
31.54 |
"9th tank electrolyzer, to MAP sensor, foil on o2 mod zip tie.
60*F at fillup, 50hwy/50city, Tustin Ranch Shell, pump #5." |
2009-11-16 |
95.6 |
2.82 |
33.9 |
"10th tank electrolyzer, to MAP sensor, foil on o2 zip tied. Definitely switched to winter blend. Will remove electrolyzer and o2 mod to get a new winter baseline.
60*F at fillup, 66hyw/34city, Tustin Ranch Shell, pump #5" |
2009-11-23 |
164.4 |
4.95 |
33.21 |
"ALL STOCK, with FGB. Getting a baseline for winter MPG.
57*F at fillup, 61hwy/39city, Tustin Ranch Shell, pump #5" |
2009-11-24 |
49.7 |
1.41 |
35.25 |
"ALL STOCK, with FGB. wtf?
61*f at fillup, 50hwy/50city, Tustin Ranch Shell, pump #5." |
2009-11-27 |
122.5 |
3.78 |
32.41 |
64*F at fillup, 70hwy/30 city, Tustin Ranch Shell, pump #5." |
2009-11-27 |
100.1 |
2.2 |
45.5 |
"ALL STOCK, with FGB. Pre-Kammback testing. Cruise control set at 65mph.
65*F at fillup, 95hwy/5 city, Tustin Ranch Shell, pump #5." |
2009-11-28 |
49.6 |
1.84 |
26.96 |
"ALL STOCK, with FGB. Random driving before testing kammback.
61*F at fillup, 37hwy/63 city, Tustin Ranch Shell, pump #5." |
2009-11-28 |
102 |
2.47 |
41.3 |
"ALL STOCK, with FGB and Kammback. Cruise control set at 65mph. Crap, back to the drawing board.
61*F at fillup, 95hwy/5 city, Tustin Ranch Shell, pump #5." |
2009-12-03 |
119.2 |
3.79 |
31.45 |
57*F at fillup, 40hwy/60 city, Tustin Ranch Shell, pump #5." |
2009-12-10 |
106.3 |
3.58 |
29.69 |
"Electrolyzer on MAP, FGB.
55*F at fillup, 61hwy/39 city, Tustin Ranch Shell, pump #5." |
2009-12-13 |
86.1 |
2.19 |
39.32 |
"Electrolyzer on MAP, FGB, Side Mirror Delete (SMD). Not bad at all for the SMD.
61*F at fillup, 83hwy/17city, Tustin Ranch Shell, pump #5." |
2009-12-13 |
34.7 |
0.95 |
36.53 |
"Electroylyzer on MAP, FGB, SMD, Cruise Control set to 55mpg on Santiago Canyon Dr. Had extra time tonight, decided to A-B test electrolyzer.
60*F at fillup, 61hwy/39city, Tustin Ranch Shell, pump #5." |
2009-12-13 |
34.7 |
0.86 |
40.35 |
"FBG, SMD, Cruise control set at 55mph. Hm interesting, however, I did notice a drop of wet fuel when I pulled out the fuel pump. Also, the last 1/3 of the trip had to follow a slower car at 45mph. Crap, maybe i'll just have to wait until i buy the MPGuino to fully test the electrolyzer.
2009-12-22 |
259.7 |
8.52 |
30.48 |
"All Stock, FGB, SMD
55*F at fillup, 32hwy/68city, Tustin Ranch Shell, pump #5." |
2010-01-02 |
307.7 |
10.29 |
29.9 |
"All Stock, FGB, SMD.
55*F at fillup, 18hwy/82city, Tustin Ranch Shell, pump #5." |
2010-01-05 |
122.4 |
3.54 |
$3.279 |
34.58 |
"All stock, FGB, SMD.
61*F at fillup, 65Hwy/35city, Tustin Ranch Shell, pump #5." |
2010-01-12 |
125.7 |
3.84 |
32.73 |
61*F at fillup, 50hwy/50city, Tustin Ranch Shell, pump #5." |
2010-01-17 |
120.8 |
3.37 |
35.85 |
60*f at fillup, 81hwy/19c, Tustin Ranch Shell, pump #5." |
2010-01-29 |
161.8 |
5.17 |
31.3 |
61*F at fillup, 45hwy/55city, Tustin Ranch Shell, pump #5." |
2010-02-02 |
16.7 |
0.83 |
20.12 |
63*F at fillup, 100city, Tustin Ranch Shell, Pump #5." |
2010-02-02 |
34.7 |
0.57 |
60.88 |
"All stock, FGB, SMD. Installed MPGuino. Cruise control set at 50mph.
61*F at fillup, 61hwy/39city, Tustin Ranch Shell, pump #5." |
2010-02-03 |
21.82 |
0.92 |
23.72 |
"All stock, with FGB, SMD
62*F at fillup, 100city, Tustin Ranch Shell, pump #5." |
2010-02-03 |
34.71 |
0.66 |
52.59 |
63*F at fillup, 61hwy/39city, Tustin Ranch Shell, pump #5." |
2010-02-08 |
143.6 |
4.48 |
32.05 |
"All Stock, FBG, SMD, Mpguino. Giving up on HHO, results are too sporadic to hardly showing any improvement at all and not going to spend any additional money on ECU tuning.
57.4*F at fillup, 52hwy/48city, Tustin Ranch Shell, pump #5." |
2010-02-18 |
185.1 |
4.86 |
$3.139 |
38.09 |
"All stock, FGB, SMD, MPGuino, EOCing
62.8*F at fillup, Tustin Ranch Shell, pump #5" |
2010-03-01 |
169.2 |
4.63 |
36.54 |
"All Stock, FGB, SMD, MPGuino, EOCing
64*F at fillup, Tustin Ranch Shell, pump #5." |
2010-03-24 |
304.3 |
8.741 |
34.81 |
61*F at fillup, Tustin Ranch Shell, pump #5." |
2010-03-30 |
293.1 |
7.649 |
38.32 |
60*F at fillup, Tustin Ranch Shell, pump #5." |
2010-04-12 |
305.2 |
7.93 |
38.49 |
2010-04-19 |
158.8 |
4.141 |
38.35 |
67*F at fillup, Tustin Ranch Shell, pump #5." |
2010-05-22 |
386.8 |
9.645 |
$3.239 |
40.1 |
"All Stock, FGB, SMD, EOCing, MPGuino, added rear skirts.
70*F at fillup, San Gabriel Shell, pump #5. (May have to thow out this reading because filled up at a different station and temperature is higher than my average fillup temperatures.)" |
2010-06-12 |
407.8 |
10.88 |
37.48 |
"All stock, FGB, SMD, RS, MPGuino, EOCing
N/A*F at fillup, Shell North Tustin Santa Ana, May need to disregard this reading because i forgot to reset my trip meter since the last fillup, so the distance reading is based purely off the MPGuino AND I filled up at a different gas station. MPGuino Tank MPG = 40.31mpg" |
2010-06-21 |
401.7 |
9.525 |
42.17 |
64*F at fillup, Tustin Ranch Shell, pump #5. BEST TANK EVER!" |
2010-07-02 |
337.1 |
8.319 |
40.52 |
"All stock, FGB, SMD, RS, EOCing, MPGuino, added Front Wheel Covers (FWC).
2010-07-21 |
159.5 |
4.167 |
38.28 |
"All stock, FGB, SMD, RS, FWC, EOCing, MPGuino, added Front Aux Light Covers (AuxC).
67*F at fillup, Tustin Ranch Shell, pump#6.
Bleh, lots of city driving and gas station attendant parked his car at my usual pump#5, so I had to use a different pump." |
2010-08-12 |
389.2 |
8.48 |
45.9 |
"All stock, FGB, SMD, RS, FWC, EOCing, MPGuino, FrAuxC, TIRES 45 PSI.
61*F at fillup, Tustin Ranch Shell, pump #5. NEW BEST TANK EVER!" |
2010-08-26 |
356.1 |
8.077 |
44.09 |
77*F at fillup, Tustin Ranch Shell, Pump #5.
Hot summer night." |
2010-09-19 |
250.2 |
6.352 |
39.39 |
"All Stock, FGB, SMD, RWS, FWC, FAUX, 45 PSI, MPGUINO, EOCING, MORE CITY DRIVING.
53.8*F at fillup, Tustin Ranch Shell, pump #5" |
2010-10-01 |
321.3 |
7.649 |
42.01 |
"All stock, FGB, SMD, RWS, FWC, EOCing, MPGuino, FrAuxC, Front Underbelly Tray, TIRES 45 PSI.
75* F at fillup, Tustin Ranch Shell, pump #5.
Lots of Kammback testing." |
2010-10-13 |
405.9 |
9.575 |
42.39 |
Added full underbelly tray (UBT).
2010-10-21 |
267.7 |
6.271 |
42.69 |
"All Stock, FGB, SMD, FAUX, RWS, UBT, 45PSI, MPGUINO, EOCING (No FWC).
2010-10-29 |
260.1 |
5.758 |
45.17 |
"All Stock, FGB, FAUX, FWC, SMD, RWS, UBT, 45PSI, EOCING, MPGUINO.
69*F at fillup, Tustin Ranch Shell, pump #5." |
2010-11-07 |
331.5 |
7.41 |
44.74 |
65*F at fillup, Tustin Ranch Shell, pump #5." |
2010-11-28 |
421.8 |
10.28 |
41.03 |
57*F at fillup, Tustin Ranch Shell, pump #5." |
2010-12-12 |
441.6 |
10.46 |
42.22 |
2010-12-29 |
361.2 |
10.28 |
35.14 |
"All Stock, FGB, FAUX, FWC, SMD, RWS, UBT, 45PSI, MPGUINO. NO EOCing due to christmas break, family was in town, lots of city driving, 2 weeks of rain.
56*F at fillup, Tustin Ranch Shell, pump #5." |
2011-01-13 |
402.5 |
9.894 |
40.68 |
2011-01-27 |
414.4 |
9.79 |
42.33 |
72*F at fillup, Tustin Ranch Shell, pump #5." |
2011-02-01 |
332.5 |
7.498 |
44.35 |
"All Stock, FGB, FAUX, FWC, SMD, RWS, UBT, 45PSI, EOCING, MPGUINO (exact reading!).
54*F at fillup, Tustin Ranch Shell, pump #5." |
2011-02-08 |
375.8 |
8.74 |
43 |
2011-02-19 |
354.4 |
8.847 |
40.06 |
46*F at fillup, Monterey Park Shell on Atlantic (filled up before going snowboarding)" |
2011-02-25 |
395.4 |
9.054 |
43.67 |
53*F at fillup, Tustin Ranch Shell, pump #5.
Snowboarding Trip. The drive up the mountain was HORRIBLE, I pretty much coasted all the way down the mountain, so MPG's evened out." |
2011-03-07 |
443.7 |
10.23 |
43.37 |
58*F at fillup, Tustin Ranch Shell, pump #5." |
2011-03-22 |
433.9 |
10.09 |
$4.199 |
43 |
"All Stock, FGB, FAUX, FWC, SMD, RWS, UBT, 50PSI, EOCING, MPGUINO.
Upped psi to 50, first half of tank was 44mpg, but rain during 2nd half of tank brought mpg down." |
2011-03-28 |
446.7 |
10.33 |
$4.259 |
43.24 |
63*F at fillup, Tustin Ranch Shell, pump #5
More rain this week, relatives in town=> more local driving." |
2011-04-08 |
392.8 |
8.89 |
$4.339 |
44.18 |
52*F at fillup, Tustin Ranch Shell, pump #5" |
2011-04-22 |
412.2 |
9.156 |
$4.419 |
45.02 |
67*F at fillup, Tustin Ranch Shell, pump #1" |
2011-04-30 |
337.7 |
7.568 |
$4.459 |
44.62 |
"All Stock, FGB, FAUX, FWC, SMD, RWS, UBT, 50PSI, EOCING, MPGUINO. Took smog test.
$33.75
60*F at fillup, Tustin Ranch Shell, pump #5" |
2011-05-16 |
432.1 |
9.556 |
$4.399 |
45.22 |
$42.04
2011-05-26 |
370.1 |
8.204 |
$4.319 |
45.11 |
"All Stock, FGB, FAUX, FWC, SMD, RWS, UBT, 50PSI, EOCING, MPGUINO. Power Steering Delete (PSD)
$35.43
2011-06-08 |
406.9 |
8.277 |
$4.159 |
49.16 |
$34.42
BEST TANK EVER!" |
2011-06-12 |
240.7 |
5.59 |
$4.139 |
43.06 |
$23.14
Girlfriend back in town for the summer, 80% city driving from now on =(" |
2011-06-23 |
386.2 |
8.953 |
$4.079 |
43.14 |
$36.52
80% city driving." |
2011-07-04 |
413.8 |
9.875 |
41.9 |
$39.10
2011-07-14 |
423.1 |
10.08 |
$4.039 |
41.97 |
$40.74
2011-07-23 |
421.6 |
9.631 |
$4.039 |
43.78 |
$38.90
Removed RWS and FWC. 80% city driving." |
2011-08-04 |
417.4 |
9.724 |
$4.039 |
42.92 |
"All Stock, FGB, FAUX, SMD, UBT, 50PSI, EOCING, MPGUINO, PSD.
$39.28
2011-08-15 |
402.7 |
9.248 |
43.54 |
$36.43
75*F at fillup, Tustin Ranch Shell, pump #5
2011-08-26 |
440.89 |
10.204 |
43.21 |
$40.81
72*F at fillup, Tustin Ranch Shell, pump #5" |
2011-09-09 |
437.72 |
10.288 |
$4.199 |
42.55 |
$43.20
N/A*F at fillup, Shell Fairview, Santa Ana, pump #3" |
2011-09-18 |
429.22 |
9.791 |
$4.159 |
43.84 |
$40.72
N/A*F at fillup, Tustin Ranch Shell, pump #7" |
2011-09-30 |
402.65 |
9.249 |
43.53 |
$37.54
N/A*F at fillup, Tustin Ranch Shell, pump #5" |
2011-10-13 |
397.25 |
9.119 |
43.56 |
"All Stock, FGB, FAUX, SMD, UBT, 50PSI, EOCING, MPGUINO, PSD, RWS back on.
$36.47
70*F at fillup, Tustin 1st st. Shell, pump #3" |
2011-10-23 |
387.8 |
8.53 |
45.46 |
"All Stock, FGB, FAUX, SMD, UBT, 50PSI, EOCING, MPGUINO, PSD, RWS.
$34.62
60*F, Tustin Ranch Shell, pump #5" |
2011-10-31 |
366.8 |
8.163 |
44.93 |
$34.64
65*F, Tustin 1st St. Shell, pump #3" |
2011-11-10 |
364.8 |
8.233 |
44.31 |
$32.92
67*F, Tustin 1st St. Shell, pump #3" |
2011-11-20 |
360 |
8.902 |
40.44 |
$35.24
54*F, Tustin 1st St. Shell, pump #3
Drove Chris home for the weekend, lots of city driving." |
2011-12-01 |
380.1 |
9.2 |
41.32 |
$34.95
63*F, Tustin 1st St. Shell, pump #3
Thanksgiving weekend, more city driving" |
2011-12-10 |
339.9 |
8.3 |
$3.829 |
40.95 |
"All Stock, FGB, FAUX, SMD, UBT, Low PSI!, EOCING, MPGUINO, PSD, RWS.
$31.80
55*F, Tustin 1st St. Shell, pump #3
Tire PSI 30's, Passenger rear 13 PSI!!" |
2011-12-19 |
415.6 |
10.394 |
39.98 |
"All Stock, SMD, UBT, EOCING, MPGUINO, PSD.
$39.07
57*F, Tustin Ranch Shell, pump #5
Leaking rear tire!" |
2012-01-01 |
432.87 |
11.218 |
38.59 |
"All Stock, SMD, UBT, 50PSI, EOCING, MPGUINO, PSD.
N/A*F, Tustin 1st St. Shell, pump #3
Multiple Fills. Xmas Break, city driving." |
2012-01-11 |
718.92 |
18.142 |
39.63 |
"All Stock, SMD, UBT, MPGUINO, PSD.
Chris home for Xmas Break. Local Driving, no EOCing. Multiple Fills." |
2012-01-24 |
405.11 |
10.24 |
39.56 |
"All Stock, SMD, 50PSI, EOCING, MPGUINO, PSD.
$40.54
N/A*F, Tustin Ranch Shell, pump #3" |
2012-02-22 |
439.11 |
9.844 |
$4.459 |
44.61 |
"All Stock,FGB, SMD, UBT v2.0, 50PSI, EOCING, MPGUINO, PSD.
$43.89
63*F, Tustin 1st St. Shell, pump #3" |
2012-03-08 |
384.3 |
9.221 |
$4.599 |
41.68 |
$42.41
66*F, Tustin 1st St. Shell, pump #3" |
