2010-05-11 |
307 |
16.3 |
18.83 |
"Started at 17mpg locally when new. With some country driving mixed in 50/50 hit low 20's. Now have bed cover and guage. Don't know what's helping but things appear to be headed the right way." |
2010-06-03 |
266 |
13.4 |
19.85 |
"all bedcoverless! though 1.5 hr cruising to Raccoon Creek surely brought it up some" |
2010-06-15 |
311 |
16.4 |
18.96 |
"no excuses this time" |
2010-06-24 |
346.3 |
16.2 |
21.38 |
"covered, trip to Morraine, and running to summer camps on the big roads" |
2010-06-30 |
211.1 |
10.5 |
20.1 |
2010-07-06 |
193.7 |
9.9 |
19.57 |
"back to the short hops, but still better than hwy est" |
2010-07-13 |
180.1 |
9.25 |
19.47 |
2010-07-21 |
269.7 |
13.7 |
19.69 |
2010-07-26 |
224.4 |
11.1 |
20.22 |
2010-08-03 |
279.2 |
13.4 |
20.84 |
2010-08-10 |
301.8 |
14.6 |
20.67 |
"finally replaced foglight cap." |
2010-08-15 |
282.4 |
13.6 |
20.76 |
"out on the big roads some this tank" |
2010-08-24 |
332.2 |
16.9 |
19.66 |
"the search for M&T and others, all uncovered" |
2010-09-03 |
320.3 |
16.9 |
18.95 |
"an hour idling w/ a/c and nearly 45 min @ 80mph" |
2010-09-14 |
324.5 |
16.6 |
19.55 |
"need to be more mindful of starts" |
2010-09-19 |
338.4 |
15 |
22.56 |
"second half of tank was first real road trip: so much for maintaining lowest instantaneous fuel consumption! first half of next tank is second half of trip and conservation of momentum seems to be the way to go" |
2010-09-22 |
348.3 |
14.9 |
23.38 |
2010-09-27 |
211.9 |
18.27 |
"the pallet debacle" |
2010-10-07 |
309.7 |
17 |
18.22 |
"fighting traffic to the strip, and nearly a week of defrost/A/C" |
2010-10-15 |
228.3 |
12.6 |
18.12 |
"starting to worry - I can't come up with an excuse for this one" |
2010-10-24 |
277 |
14.5 |
19.1 |
"I think it was the GF. She's not that heavy, but always running late so I've been masshing it lately. Three days without her and pretty much the usual running and..." |
2010-11-03 |
341.2 |
18.1 |
18.85 |
2010-11-15 |
475.3 |
24.4 |
19.48 |
"two part refill, not an elastic 21 gal tank; running heavy and uncovered" |
2010-11-23 |
295 |
15.5 |
19.03 |
2010-11-25 |
272.7 |
12.9 |
21.14 |
"Pa turnpike the whole tank - What happened?" |
2010-11-26 |
167.7 |
8.1 |
20.7 |
2010-11-29 |
318 |
15.2 |
20.92 |
"found one of the problems: low tire pressure, about 7 psi low - didn't think the cold would do that much!" |
2010-12-07 |
267.4 |
15.3 |
17.48 |
2010-12-14 |
258.4 |
14.4 |
17.94 |
"and so begins the abyssmal winter milage..." |
2010-12-20 |
298.3 |
16.2 |
18.41 |
"not exact - added some fuel from a can and am off, but not more than 1/2 gal" |
2010-12-26 |
296.7 |
15.8 |
18.78 |
2011-01-05 |
322 |
17.8 |
18.09 |
2011-01-11 |
204.1 |
11.8 |
17.3 |
2011-01-19 |
281.1 |
15.2 |
18.49 |
2011-01-26 |
289.7 |
16.4 |
17.66 |
2011-01-31 |
177.6 |
17.08 |
2011-02-08 |
358.8 |
19.6 |
18.31 |
2011-02-16 |
318.5 |
18.3 |
17.4 |
2011-02-20 |
278.7 |
13.4 |
20.8 |
"milder weather road trip" |
2011-03-02 |
365.7 |
20.3 |
18.01 |
2011-03-10 |
342.4 |
18.6 |
18.41 |
"starting to hoard fuel against price increases so using Scanguage fuel comsuption readings and not pump readings 'cause I'm pumping way more than I use and am dumping in from inaccurately filled cans along the way." |
2011-03-25 |
521 |
28.5 |
18.28 |
"not recorded well so running both est. and un-reconciled scannguage no.s for 3/26 and the actual ought to be somewheere in between" |
2011-03-26 |
532.8 |
25.5 |
20.89 |
2011-04-15 |
401.6 |
20.9 |
19.22 |
"SG says 18.8" |
2011-04-27 |
309.1 |
15.5 |
19.94 |
2011-05-04 |
339.6 |
16 |
21.23 |
"receipt sys 5/11 but it can't be." |
2011-05-09 |
207.5 |
10.6 |
19.58 |
2011-05-11 |
326.4 |
17.1 |
19.09 |
2011-05-17 |
313.2 |
17.7 |
17.69 |
"running a blend of approx 40% ethanol" |
2011-05-27 |
374.4 |
18.1 |
20.69 |
"another jerry can refuel - not sure on gallons." |
2011-05-30 |
357.1 |
14.8 |
24.13 |
"scanguage claims: 353 mi; 15.8 gal; 22.3mpg; steady 65 w/ grill block" |
2011-05-31 |
350.5 |
12.6 |
27.82 |
"scanguage: 346 mi; 15.0 gal; 23 mpg; fairly steady 60 w/ grill block" |
2011-06-09 |
376.3 |
16.8 |
22.4 |
"S/G: 22mpg; 369mi; 16gal" |
2011-06-16 |
235.1 |
11.7 |
20.09 |
"S/G: 21.1mpg; 226mi; 10.6gal" |
2011-06-27 |
261 |
14.6 |
17.88 |
"S/G: 20.3mpg; 253mi; 12.4gal" |
2011-07-02 |
275.7 |
12.8 |
21.54 |
"S/G: 271mi; 13.8 gal; 19.5mpg" |
2011-07-05 |
203.1 |
8.3 |
24.47 |
"S/G: 8.8 gal; 200 mi; 22.8 mpg" |
2011-07-13 |
286.7 |
14.3 |
20.05 |
"S/G: 281 mi; 13.2 gal; 21.1 mpg" |
2011-07-19 |
291.9 |
13.9 |
21 |
"S/G: 287mi; 14.1gal; 20.2mpg" |
2011-07-24 |
220.2 |
18.98 |
"S/G: 215mi; 11.4gal; 18.8mpg" |
2011-08-03 |
295 |
15.9 |
18.55 |
"S/G numbers only, and w/ 40% ethanol" |
2011-08-14 |
618.3 |
30 |
20.61 |
"S/G: 607mi; 29.2 gal; 20.6mpg" |
2011-08-21 |
238 |
11.2 |
21.25 |
"Prepay to pump,not quite to fuel shut-off at full, but how short? Needle was up to usual shut-off spot." |
2011-08-30 |
314.8 |
15.9 |
19.8 |
"S/G for last 2 fills combimed: 545mi; 27.5gal; 19.7mpg" |
2011-09-02 |
117.5 |
6.2 |
18.95 |
"Gas too cheap to pass up! S/G: 115mi; 5.73gal; 20.0mpg" |
2011-09-07 |
429 |
20.1 |
21.34 |
"S/G: 423 mi; 21.2gal; 19.8mpg" |
2011-09-11 |
234.8 |
20.24 |
"S/G: 231mi; 12.9gal; 17.8mpg running 75-80 mph w/ bikes in bed" |
2011-09-22 |
416.6 |
21.1 |
19.74 |
"S/G: 409mi; 20.4gal; 19.9mpg" |
2011-09-30 |
336.6 |
16.6 |
20.28 |
"S/G: 331mi; 16.9gal; 19.5 mpg" |
2011-10-07 |
449.2 |
25.1 |
17.9 |
"S/G: 440mi; 24.4gal; 18.0mpg Pulling church trailer." |
2011-10-12 |
526.6 |
26.2 |
20.1 |
"S/G: 519mi; 26.0gal; 19.8mpg Pulling church trailer" |
2011-10-21 |
352.2 |
19 |
18.54 |
"S/G: 346mi; 18.4gal; 18.7mpg" |
2011-10-31 |
357.8 |
18.5 |
19.34 |
"S/G: 351mi; 18.9gal; 18.5mpg" |
2011-11-07 |
265.7 |
14 |
18.98 |
"S/G: 261mi; 14gal; 18.5mpg
Hauling scrap: traffic & extra weight (up to 200 lbs) ~ 80 mi./fill-up" |
2011-11-21 |
224 |
12.1 |
18.51 |
"S/G: 218mi; 11.9gal; 18.2" |
2011-11-23 |
374.4 |
17.3 |
21.64 |
"S/G: 369mi; 17.6gal; 20.9mpg" |
2011-11-28 |
366.5 |
16.6 |
22.08 |
"S/G: 362mi; 16.7gal; 21.5mpg" |
2011-12-05 |
241.4 |
12.2 |
19.79 |
"S/G: 237mi; 11.9gal; 19.7mpg" |
2011-12-09 |
230.2 |
19.18 |
"S/G: 222mi; 11.5gal; 19.2mpg" |
2011-12-20 |
319.4 |
17.4 |
18.36 |
"S/G: 313mi; 17.8gal; 17.5mpg" |
2011-12-27 |
258.5 |
13.9 |
18.6 |
"S/G: 253mi; 13.8gal; 18.2mpg" |
2012-01-16 |
126 |
6.16 |
20.45 |
"S/C only - cans and partial fills" |
2012-02-01 |
260.4 |
14 |
18.6 |
"No S/G" |
2012-02-08 |
454.1 |
23.4 |
19.41 |
"S/G: 446mi; 24.7gal; 18.0mpg" |
2012-02-15 |
324.7 |
17.7 |
18.34 |
"S/G: 318mi; 18.8gal; 16.8mpg" |
2012-02-21 |
319.7 |
16.5 |
19.38 |
"S/G: 313mi; 17.6gal; 17.7mpg
mounted Kendas at 50psi" |
2012-02-27 |
256.1 |
15.1 |
16.96 |
"S/G: 251mi; 13.5gal; 18.5mpg" |
2012-03-05 |
255.8 |
14.7 |
17.4 |
"S/G: 250mi; 15.3gal; 16.2mpg" |
2012-03-12 |
273.8 |
14.9 |
18.38 |
"S/G: 269mi; 15.3gal; 17.5mpg" |
2012-03-20 |
265 |
14.1 |
18.79 |
"S/G:264mi; 14.7gal; 17.7mpg" |
2012-04-03 |
419.3 |
24 |
17.47 |
"S/G: 425mi; 23.3gal; 18.2" |
2012-04-13 |
297.2 |
16.7 |
17.8 |
"S/G: 725mi; 40.2gal; 17.9mpg" |
2012-04-24 |
323.6 |
17.5 |
18.49 |
"S/G: 318mi; 18.1gal; 17.5mpg" |
2012-05-07 |
473 |
26.7 |
17.72 |
"S/C no.s only" |
2012-05-09 |
88.3 |
4.79 |
18.43 |
"S/G no.s only" |
2012-05-17 |
336 |
17.9 |
18.77 |
"S/G: 329mi; 18.2gal; 18.0 mpg" |
2012-05-24 |
17.5 |
18.57 |
"S/G only." |
2012-05-26 |
288 |
22.15 |
2012-05-27 |
268.3 |
11.7 |
22.93 |
"S/G: 550mi; 26.7gal; 20.5mpg" |
2012-05-29 |
343.5 |
16.5 |
20.82 |
"S/G:339mi; 16.7gal; 20.2mpg" |
2012-06-21 |
504.1 |
25.7 |
19.61 |
"S/G: 494mi; 23.9gal; 20.6mpg" |
2012-07-06 |
343.9 |
17.2 |
19.99 |
"S/G: 337mi; 16.5gal; 20.3mpg" |
2012-07-06 |
22 |
17.5 |
"S/G: 873mi; 42.9gal; 20.3mpg" |
2012-07-13 |
308.7 |
15.8 |
19.54 |
"S/G: 1175mi; 58.2gal; 20.1mpg" |
2012-07-19 |
159.2 |
8.8 |
18.09 |
"S/G: 155mi; 8.2mi; 19.0mpg
Great news! my axle bearings are shot. Perhaps that's while the milage has dropped, though the shop tech didn't think it would have any effect." |
2012-07-30 |
398.4 |
22.1 |
18.03 |
2012-08-09 |
120 |
6.35 |
18.9 |
"S/G no.s only" |
2012-08-16 |
330.2 |
17 |
19.42 |
"S/G: 323mi; 15.7mi; 20.5mpg" |
2012-08-29 |
255 |
14 |
18.21 |
"S/G: 250mi; 13.1gal; 18.9mpg" |
2012-09-07 |
288.9 |
17.8 |
16.23 |
"S/G: 283mi; 15.4gal; 18.3mpg" |
2012-09-08 |
305.1 |
15.6 |
19.56 |
"S/G: 302mi; 16.3gal; 18.5mpg. on E~40" |
2012-09-09 |
341.6 |
18 |
18.98 |
"S/G: 338mi; 19.6gal; 17.2mpg Appenently the new axle bearing didn' help anything as these last two tanks were highway (@75-80mph)" |
2012-09-17 |
289.3 |
14.4 |
20.09 |
"S/G: 284mi; 15.2gal; 18.7mpg" |
2012-09-24 |
173 |
9.9 |
17.47 |
"S/G mi only" |
2012-10-09 |
313.8 |
17 |
18.46 |
"S/G: 308mi; 17.5gal; 17.5mpg" |
2012-10-15 |
406 |
22.9 |
17.73 |
"S/G info only" |
2012-10-18 |
607.5 |
26.3 |
23.1 |
"S/G: 601mi; 28.9gal; 20.7mpg" |
2012-10-30 |
202.6 |
18.42 |
"S/G: 198mi; 10.2gal; 19.3mpg" |
2012-11-14 |
214.7 |
10.8 |
19.88 |
"S/G: 212mi; 10.8gal; 19.5mpg" |
2012-11-21 |
134.4 |
7 |
19.2 |
"S/G: 131mi; 6.57mi; 20.0mpg with ~30% ethanol" |
2012-11-22 |
258.8 |
13.4 |
19.31 |
"S/G: 256mi; 13.8gal; 18.5mpg" |
2012-11-25 |
16.5 |
20.91 |
"S/G: 340mi; 16.6gal; 20.3mpg" |
2012-11-27 |
299.3 |
14.3 |
20.93 |
"S/G: 295mi; 15.5gal; 19.0mpg" |
2012-12-05 |
136 |
8.8 |
15.45 |
"S/G: 133mi; 6.93gal; 19.2 mpg Loose bat. cable!!!" |
2012-12-12 |
98.4 |
6.1 |
16.13 |
"S/G: 94.0mi; 6.3gal; 15mpg Loose bat. cable!!!" |
2013-01-07 |
422.8 |
29.8 |
14.19 |
"S/G: 413mi; 29.8gal; 13.8mpg Loose bat. cable!!!" |
2013-01-30 |
317.3 |
16 |
19.83 |
"S/G:310mi; 16.5gal; 18.7mpg" |
2013-02-11 |
217.5 |
13.4 |
16.23 |
"S/G: 213mi; 11.2gal; 18.8mpg" |
2013-02-22 |
174.7 |
10.8 |
16.18 |
"S/G: 172mi; 10.6gal; 16.0mpg
last 235/85/16 fill-up" |
2013-03-07 |
208.5 |
12.4 |
16.81 |
"S/G: 204mi; 12.6gal; 16.1 mpg" |
2013-03-22 |
271.2 |
15.8 |
17.16 |
"S/G: 266mi; 15.6gal; 16.9mpg" |
2013-04-19 |
531.4 |
29.4 |
18.07 |
"S/G: 521mi; 29.4gal; 17.7 mpg" |
2013-05-02 |
288.6 |
15.3 |
18.86 |
"S/G: 283mi; 15.7gal; 17.9mpg" |
2013-05-09 |
323.7 |
16.2 |
19.98 |
"S/G: 318mi; 16.5gal; 19.1 mpg" |
2013-05-15 |
176.7 |
8.6 |
20.55 |
"S/G: 173mi; 8.78gal; 19.6mpg" |
2013-05-24 |
204.2 |
20.42 |
"S/G: 200mi; 9.87gal; 20.1mpg" |
2013-05-28 |
319.4 |
14.4 |
22.18 |
"S/G: 315mi; 14.9gal; 21.0mpg" |
2013-06-13 |
315.3 |
16.6 |
18.99 |
"S/G: 308mi; 15.9gal; 19.3mpg" |
2013-07-05 |
616.1 |
29.5 |
20.88 |
"S/G: 603mi; 29.6gal; 20.3 (only have S/G fuel use)" |
2013-07-16 |
334.5 |
16.9 |
19.79 |
"S/G: 327mi; 16.9gal; 19.3mpg" |
2013-07-24 |
309.6 |
15.3 |
20.24 |
"S/G: 303mi; 15.2gal; 19.8mpg" |
2013-08-03 |
247 |
12.6 |
19.6 |
"S/G; 242mi; 12.6gal; 19.2mpg" |
2013-08-06 |
261.6 |
10.9 |
24 |
"S/G: 257mi; 11.2gal; 22.9mpg" |
2013-08-15 |
379.3 |
18 |
21.07 |
"S/G: 372mi; 17.8gal; 20.8mpg" |
2013-08-25 |
318.4 |
15.6 |
20.41 |
"S/G: 312mi; 15.2gal; 20.3mpg" |
2013-08-30 |
200.3 |
21.08 |
"S/G: 195mi; 9.9gal; 19.6mpg" |
2013-09-02 |
373.2 |
15.1 |
24.72 |
"S/G: 368mi; 15.1gal; 24.2mpg" |
2013-09-06 |
386.2 |
16.7 |
23.13 |
"S/G; 380mi; 17.0gal; 22.3mpg" |
2013-09-08 |
278.8 |
24.03 |
"S/G; 275mi; 11.2gal; 24.3" |
2013-09-12 |
14.6 |
23.29 |
"S/G: 336mi; 15.1gal; 22.1mpg" |
2013-09-18 |
230 |
11.7 |
19.66 |
"S/G; 225mi; 10.9gal; 20.5mpg" |
2013-09-30 |
315 |
16.6 |
18.98 |
"S/G: 308mi; 16.4gal; 18.7mpg" |
2013-10-10 |
298.6 |
15.8 |
18.9 |
"S/G: 292mi; 15.7gal; 18.5mpg" |
2013-10-23 |
410 |
20.4 |
20.1 |
"S/G: 402mi; 20.4gal; 19.6mpg" |
2013-10-31 |
274.8 |
14.4 |
19.08 |
"S/G: 269mi; 14.4gal; 18.6mpg" |
2013-11-14 |
299.8 |
17.2 |
17.43 |
"S/G: 292mi; 17,0gal; 17.1mpg" |
2013-11-25 |
269 |
16.2 |
16.6 |
"S/G: 263mi; 16.0gal; 16.3mpg" |
2013-11-28 |
293.7 |
14.9 |
19.71 |
"S/G: 289mi; 16.0gal; 18.0mpg" |
2013-12-01 |
292.5 |
15.2 |
19.24 |
"S/G: 288mi; 14.8gal; 19.4mpg" |
2013-12-10 |
396 |
21.1 |
18.77 |
"S/G: 388mi; 21.1gal; 18.3mpg" |
2013-12-19 |
232.3 |
14.8 |
15.7 |
"S/G: 227mi; 13.7gal; 16.5mpg" |
2014-01-13 |
247.1 |
16 |
15.44 |
2014-01-19 |
251.8 |
15.2 |
16.57 |
2014-01-30 |
247 |
16.2 |
15.25 |
2014-02-08 |
284.1 |
16.8 |
16.91 |
"S/G: 277mi; 17.3gal; 15.9mpg" |
2014-02-17 |
237.5 |
16 |
14.84 |
"S/G: 230mi; 15.8gal; 14.5mpg
cold and lots of wheel spin in the snow" |
2014-02-25 |
248.1 |
15 |
16.54 |
"S/G: 472mi; 30.6gal; 15.3mpg" |
2014-03-05 |
213 |
14.1 |
15.11 |
"S/G: 207mi; 13.8gal; 14.9mpg" |
2014-03-12 |
249.6 |
14.8 |
16.86 |
"S/G: 243mi; 14,8gal; 16.3mpg" |
2014-03-21 |
276.3 |
16.8 |
16.45 |
"S/G: 269mi; 16.7gal; 16.0mpg" |
2014-03-28 |
267.9 |
15.1 |
17.74 |
"S/G: 261mi; 15.4gal; 16.8mpg" |
2014-04-04 |
197.9 |
11.7 |
16.91 |
"S/G: 193mi; 11.5mpg; 16.7mpg" |
2014-04-10 |
225.2 |
12.6 |
17.87 |
"S/G: 219mi; 12.5mi; 17.5mpg" |
2014-04-23 |
515 |
29.6 |
17.4 |
"S/G numbers only - multiple partial fills including 474mi; 27.5gal; 17.2mpg" |
2014-04-30 |
213 |
11.4 |
18.68 |
"S/G: ? Lost a fill-up and cleaned throttle body so everything is off temporarily." |
2014-05-09 |
331.3 |
16.8 |
19.72 |
"S/G; 323mi; 19.4gal;16.6mpg" |
2014-05-16 |
284.5 |
14.3 |
19.9 |
"S/G: 277mi; 14.8gal; 18.6mpg" |
2014-05-26 |
318 |
16.1 |
19.75 |
"S/G: 310mi; 16.1gal; 19.2mpg" |
2014-06-06 |
234.2 |
21.29 |
"S/G: 516mi; 26.1gal; 19.6mpg" |
2014-06-15 |
291.1 |
15.3 |
19.03 |
2014-06-22 |
275.6 |
13.2 |
20.88 |
"S/G: 270mi; 13.5gal; 20.0mpg" |
2014-06-25 |
155.3 |
7 |
22.19 |
"S/G: 153mi; 7.06gal; 21.6mpg" |
2014-07-03 |
215.6 |
10.9 |
19.78 |
"S/G: 162 mi; 7.76gal; 20.8mpg" |
2014-07-04 |
304.4 |
14.1 |
21.59 |
"S/G: 301mi; 13.1gal; 22.9mpg" |
2014-07-06 |
288.9 |
13.1 |
22.05 |
"S/G: 285mi; 12.8gal; 22.1mpg" |
2014-07-06 |
345.5 |
16.1 |
21.46 |
"S/G: 342mi; 16.6gal; 20.5mpg" |
2014-07-15 |
276.1 |
14.9 |
18.53 |
"S/G: 269mi; 13.9gal; 19.3mpg" |
2014-07-21 |
278.8 |
14.4 |
19.36 |
"S/G: 273mi; 13.2gal; 20.6mpg" |
2014-07-24 |
148.4 |
8 |
18.55 |
"S/G: 145mi; 8.0gal; 18.1mpg" |
2014-07-27 |
287.1 |
14.7 |
19.53 |
"S/G: 282mi; 14.6mpg; 19.2" |
2014-08-01 |
293.5 |
14.3 |
20.52 |
"S/G: 287mi; 14.5gal; 19.6mpg This isn't Aug 2014: possibly 8 Jan?" |
2014-08-04 |
284.2 |
14.9 |
19.07 |
"S/G: 278mi; 15.2gal; 18.1mpg" |
2014-08-07 |
134.7 |
6.7 |
20.1 |
"S/G: 132mi; 6.3gal; 20.6mpg" |
2014-08-12 |
248.1 |
12.2 |
20.34 |
"S/G: 244mi; 12.1gal; 20.0mpg" |
2014-08-24 |
283.1 |
15.7 |
18.03 |
"S/G: 277mi; 15.3gal; 17.9mpg" |
2014-09-04 |
153.9 |
8.1 |
19 |
"S/G: 150mi; 7.23; 20.7mpg
lost all data from fill-up on 9/1 (dead battery and scanguage move)" |
2014-09-08 |
191.4 |
10.1 |
18.95 |
"S/G: 183mi; 8.80gal; 20.7mpg" |
2014-09-15 |
243.2 |
13.2 |
18.42 |
"S/G: 237mi; 13.4gal; 17.5mpg" |
2014-09-22 |
256.5 |
13.8 |
18.59 |
"S/G: 250mi; 13.9gal; 17.9mpg" |
2014-09-28 |
249.6 |
13.8 |
18.09 |
"S/G: 244mi; 13.6gal; 17.8mpg" |
2014-10-02 |
168 |
9.1 |
18.46 |
"S/G: 163mi; 9.14gal; 17.8mpg" |
2014-10-09 |
260.4 |
14.5 |
17.96 |
"S/G: 254mi; 14.4gal; 17.5mpg" |
2014-10-21 |
453 |
25.7 |
17.63 |
"S/G: 443mi; 25.2gal; 17.5mpg" |
2014-10-29 |
287.3 |
16 |
17.96 |
"S/G: 280mi; 15.9gal; 17.5mpg" |
2014-11-04 |
235.4 |
13.1 |
17.97 |
"S/G: 223mi; 12.3gal; 17.9mpg" |
2014-11-11 |
257.1 |
14.8 |
17.37 |
"S/G: 251mi; 14.9gal; 16.8mpg" |
2014-11-14 |
211.9 |
11.9 |
17.81 |
"S/G: 459mi; 26.9gal; 17.0mpg" |
2014-11-20 |
143.3 |
15.1 |
9.49 |
"S/G: 383mi; 22.2gal; 17.1mpg. Jumped and partial fill, so likely inaccurate." |
2014-11-25 |
275.6 |
15.7 |
17.55 |
"S/G: 653mi; 37.8gal; 17.2mpg Nearly 40% ethanol" |
2014-11-30 |
272.6 |
12.1 |
22.53 |
"S/G: 554mi; 28.5gal; 19.4mpg" |
2014-11-30 |
285 |
15.8 |
18.04 |
"Only S/G numbers available - battery issues/jumping" |
2014-12-06 |
196.4 |
8.5 |
23.11 |
"S/G; 194mi; 9.5gal; 20.3mpg" |
2014-12-06 |
265.8 |
12.5 |
21.26 |
"S/G: 263mi; 12.3gal; 21.3mpg" |
2014-12-09 |
225.9 |
12.2 |
18.52 |
"S/G: 222mi; 11.7gal; 18.9mpg" |
2014-12-17 |
263.4 |
15.8 |
16.67 |
"S/G: 257mi; 14.9gal; 17.1mpg" |
2015-01-02 |
382.1 |
23.6 |
16.19 |
"used cans, so may be a bit off S/G:373mi; 22.6gal; 16.4mpg" |
2015-01-09 |
241.2 |
15.1 |
15.97 |
"S/G: 235mi; 14.8gal; 15.9mpg" |
2015-01-15 |
203.9 |
12.8 |
15.93 |
"S/G: 199mi; 12.9gal; 15.3mpg" |
2015-01-25 |
248.9 |
14.8 |
16.82 |
"S/G: 243mi; 15.0gal; 16.0mpg" |
2015-01-28 |
143.8 |
15.14 |
"S/G: 140mi; 9,0gal; 15.4mpg" |
2015-02-04 |
225.7 |
14.3 |
15.78 |
"S/G: 220mi; 15.0gal; 14.6mpg" |
2015-02-11 |
252.9 |
16.2 |
15.61 |
"S/G: 467mi; 31.7gal; 1.,6mpg" |
2015-02-18 |
192.3 |
14.79 |
"S/G: 188mi; 13.1gal; 14.2mpg" |
2015-02-26 |
218.1 |
15.4 |
14.16 |
"S/G: 212mi; 15.5gal; 13.6mpg" |
2015-03-02 |
77.6 |
5.7 |
13.61 |
"S/G: 75.8mi; 5.6gal; 13.5mpg This fill-up was with E85!" |
2015-03-06 |
195.1 |
15.01 |
"S/G: 190mi; 12.8gal; 14.7mpg" |
2015-03-10 |
114.7 |
7 |
16.39 |
"S/G: 302mi; 19.9gal; 15.0mpg" |
2015-03-19 |
282.9 |
17.3 |
16.35 |
"S/G: 276mi; 17.6gal; 15.5mpg" |
2015-04-02 |
375.7 |
23.2 |
16.19 |
"S/G: 366mi; 23.2; 15.7mpg" |
2015-04-08 |
168.8 |
18.15 |
"S/G: 165mi; 9.4gal; 17.5mpg" |
2015-04-16 |
303.2 |
16.4 |
18.49 |
"S/G: 296mi; 16.7gal; 17.6mpg" |
2015-04-23 |
305.1 |
16.3 |
18.72 |
"S/G: 299mi; 16.4gal; 18.2mpg" |
2015-04-30 |
295.9 |
16.2 |
18.27 |
"S/G: 290mi; 16.6gal; 17.4mph" |
2015-05-08 |
311.5 |
17 |
18.32 |
"S/G: 304mi; 17.1gal; 17.7mpg" |
2015-05-15 |
16.8 |
19.05 |
"S/G: 313mi; 17.4gal; 17.9mpg" |
2015-05-18 |
122.8 |
6.47 |
18.98 |
"S/G: 120mi; 6.43gal; 18.6mpg" |
2015-05-24 |
259.7 |
13.8 |
18.82 |
"S/G: 254mi; 14.0gal; 18.1mpg" |
2015-05-27 |
178.8 |
8.3 |
21.54 |
"S/G: 175mi; 8.7gal; 20.2mpg" |
2015-06-03 |
257.8 |
13.9 |
18.55 |
"S/G: 252mi; 13.7gal; 18.2mpg" |
2015-06-09 |
198.4 |
18.04 |
"S/G: 194mi; 10.5gal; 18.2mpg" |
2015-06-16 |
147.4 |
7.9 |
18.66 |
"S/G: 143mi; 8.09gal; 17.7mpg" |
2015-06-26 |
558 |
27.4 |
20.36 |
"S/G: 692mi; 36.8gal; 18.7mpg - previous fill-up added to this one" |
2015-07-05 |
270.8 |
15.8 |
17.14 |
"S/G: 263mi;14.8gal; 17.7mpg" |
2015-07-11 |
286.8 |
14.9 |
19.25 |
"S/G: 281mi; 15.7gal; 17.8mpg" |
2015-07-15 |
166.7 |
8.5 |
19.61 |
"S/G: 163mi; 8.7gal; 18.7mpg" |
2015-07-17 |
162.4 |
7.5 |
21.65 |
"S/G: 159mi; 7.1gal; 22.6mpg" |
2015-07-20 |
142.3 |
6.6 |
21.56 |
"S/G: 139mi; 6.88gal; 20.3mpg" |
2015-07-23 |
205.1 |
9.7 |
21.14 |
"S/G: 340mi; 17.1gal; 19.8mpg" |
2015-08-03 |
307.1 |
15.6 |
19.69 |
"S/G: 299mi; 15.3gal; 19.5mpg" |
2015-08-08 |
173.4 |
8.2 |
21.15 |
"S/G: 171mi; 8.22gal; 20.8mpg" |
2015-08-08 |
204.1 |
19.07 |
"S/G: 199mi; 10.7gal; 18.5mpg" |
2015-08-09 |
308.2 |
13.7 |
22.5 |
"S/G: 299mi; 14.4gal; 20.6mpg" |
2015-08-10 |
277.4 |
12.8 |
21.67 |
"S/G: 273mi;12.8gal; 21.3mpg" |
2015-08-14 |
283 |
12.9 |
21.94 |
"S/G: 278mi; 12.5gal; 22.1mpg" |
2015-08-14 |
246.1 |
10.9 |
22.58 |
"S/G: 243mi; 11.7gal; 20.6mpg" |
2015-08-15 |
220.3 |
21.18 |
"S/G: 217mi; 9.76gal; 22.2mpg" |
2015-08-15 |
298.3 |
14.6 |
20.43 |
"S/G: 295mi; 13.8gal; 21.1mpg" |
2015-08-20 |
258 |
12.9 |
20 |
"S/G: 253mi; 12.0gal; 20.8mpg" |
2015-08-26 |
146.2 |
7.8 |
18.74 |
"S/G: 143mi; 7.26gal; 19.6mpg" |
2015-08-26 |
146.2 |
7.8 |
18.74 |
2015-08-31 |
232.8 |
11.5 |
20.24 |
"S/G: 228mi; 10.8gal; 20.9mpg" |
2015-09-10 |
394.8 |
20.2 |
19.54 |
"S/G: 386mi; 18.9gal; 20.3mpg" |
2015-09-16 |
139.2 |
7.9 |
17.62 |
"S/G: 136mi; 6.83gal; 19.9mpg" |
2015-09-23 |
212.1 |
19.82 |
"S/G: 207mi; 11.7gal; 17.5mpg" |
2015-10-02 |
166.2 |
9.9 |
16.79 |
"S/G: 162mi; 9.2gal; 17.6mpg" |
2015-10-09 |
173.4 |
18.06 |
"S/G: 169mi; 10.0gal; 16.0mpg" |
2015-10-16 |
198.7 |
10.6 |
18.75 |
"S/G: 194mi; 10.7gal; 18.1mpg" |
2015-10-24 |
276.5 |
15.7 |
17.61 |
"S/G: 269mi; 15.1gal; 17.7mpg" |
2015-10-29 |
133.7 |
7.6 |
17.59 |
"S/G: 130mi; 7.6gal; 17.1mpg" |
2015-11-06 |
272.4 |
14.9 |
18.28 |
"S/G: 266mi; 15.1gal; 17.5mpg" |
2015-11-08 |
173.8 |
9 |
19.31 |
"S/G: 171mi; 9.1gal; 18.7mpg" |
2015-11-11 |
167.8 |
9.2 |
18.24 |
"S/G: 164mi; 9.05gal; 18.1mpg" |
2015-11-25 |
357.5 |
20.1 |
17.79 |
"S/G: 348mi; 20.6gal; 16.8mpg" |
2015-12-10 |
332.2 |
21.6 |
15.38 |
"S/G: 674mi; 41.0gal; 16.4mpg
somewhere after this tank, started running 235s up front all year,not just winter" |
2015-12-23 |
425.1 |
25.3 |
16.8 |
"S/G: 416mi; 24.7gal; 16.7mpg" |
2015-12-24 |
295.1 |
14.1 |
20.93 |
"S/G:292mi; 15.3gal; 18.9mpg" |
2015-12-24 |
236 |
11.2 |
21.07 |
"S/G: 234mi; 11.2gal;20.9mpg" |
2015-12-28 |
268.7 |
15 |
17.91 |
"S/G: 263mi; 14.0gal; 18.7mpg" |
2015-12-30 |
321.7 |
15.3 |
21.03 |
"S/G: 562mi; 28.4gal; 19.7mpg" |
2015-12-30 |
247.4 |
19.03 |
"S/G: 244mi; 12.6gal; 19.3mpg" |
2016-01-08 |
215.3 |
13.8 |
15.6 |
"S/G: 211mi; 12.5gal; 16.7mpg" |
2016-01-16 |
128.2 |
8.9 |
14.4 |
"S/G: 125mi; 8.8gal; 14.2mpg" |
2016-01-19 |
230.7 |
15.2 |
15.18 |
"S/G: 226mi; 14.9gal; 15.1mpg" |
2016-02-02 |
122.1 |
7.7 |
15.86 |
"S/G: 244mi; 16.4gal; 14.7mpg" |
2016-02-09 |
156 |
9.7 |
16.08 |
"S?G: 397mi; 26.3gal; 15.0mpg" |
2016-02-16 |
154.1 |
10.3 |
14.96 |
"S?G: 150mi; 10.1gal; 14.7mpg" |
2016-02-24 |
166.8 |
16.35 |
"S?G: 162mi; 10.3gal; 15.6mpg" |
2016-03-03 |
215.8 |
12.9 |
16.73 |
"S?G: 211mi; 12.8gal; 16.3mpg" |
2016-03-09 |
163.8 |
17.24 |
"S?G: 160mi; 9.6gal; 16.7mpg" |
2016-03-16 |
164.3 |
9.8 |
16.77 |
"S?G: 160mi; 9.7gal; 16.5mpg" |
2016-03-21 |
202.9 |
18.45 |
"S/G: 360mi; 21gal; 17.0mpg" |
2016-03-29 |
184.1 |
10.3 |
17.87 |
"S/G: 180mi; 10.8gal; 16.5mpg" |
2016-04-05 |
240 |
14 |
17.14 |
"S/G: 234mi; 13.4gal; 17.3mpg" |
2016-04-12 |
141.2 |
8.8 |
16.05 |
"S/G: 372mi; 21.6gal; 17.2mpg" |
2016-04-19 |
207.6 |
11.7 |
17.74 |
"S/G: 202mi; 11.1gal; 18.1mpg" |
2016-04-27 |
280.9 |
15.4 |
18.24 |
"S/G: 272mi; 14.7gal; 18.5mpg" |
2016-04-30 |
223.1 |
11.5 |
19.4 |
"S/G; 219mi; 12.3gal; 17.7mpg" |
2016-05-01 |
251.6 |
12.3 |
20.46 |
"S/G: 468mi; 25.6gal; 18.2mpg" |
2016-05-05 |
157.1 |
8.1 |
19.4 |
"S/G: 154mi; 8.55gal; 18.0mpg" |
2016-05-10 |
208.3 |
11.3 |
18.43 |
"S/G: 204mi; 11.5gal; 17.6mpg" |
2016-05-19 |
372 |
20.9 |
17.8 |
"S/G: 568mi; 32.5gal; 17.4mpg" |
2016-05-24 |
220.7 |
11.9 |
18.55 |
"S/G:216mi; 12.1gal; 17.7mpg" |
2016-06-01 |
227.4 |
12.7 |
17.91 |
"S/G: 222mi; 12.5gal; 17.7mpg" |
2016-06-07 |
155.7 |
8.6 |
18.1 |
"S/G: 152mi; 8.6gal; 17.6mpg" |
2016-06-14 |
266.8 |
14.2 |
18.79 |
"S/G: 261mi; 14.3gal; 18.1mpg" |
2016-06-19 |
199.1 |
18.61 |
"S/G: 194mi; 10.9gal; 17.7mpg" |
2016-06-21 |
233.6 |
11.2 |
20.86 |
"S/G: 229mi; 11.3gal; 20.1mpg" |
2016-06-28 |
341.1 |
17.9 |
19.06 |
"S/G: 565mi; 28.9gal; 19.4mpg" |
2016-07-03 |
245.6 |
12.7 |
19.34 |
"S/G: 240mi; 12.8gal; 18.7mpg Sea Foamed the engine oil looks like it may have helped" |
2016-07-04 |
261.3 |
11.7 |
22.33 |
"S/G: 258mi; 12.4gal; 20.7mpg" |
2016-07-06 |
339.1 |
16.2 |
20.93 |
"S/G: 335mi; 16.8gal; 19.8mpg" |
2016-07-12 |
127.2 |
7 |
18.17 |
"S/G: 124mi; 6.8gal; 18.2mpg" |
2016-07-18 |
237.1 |
12.1 |
19.6 |
"S/G: 232mi; 12.0gal; 19.3mpg" |
2016-07-22 |
284.7 |
14.8 |
19.24 |
"S/G: 279mi; 13.9gal; 20.0mpg" |
2016-07-29 |
289.4 |
16.1 |
17.98 |
"S/G: 282mi; 16.2gal; 17.3mpg" |
2016-08-02 |
138.5 |
7.8 |
17.76 |
"S/G: 135mi; 8.0gal; 16.7mpg" |
2016-08-08 |
287.8 |
16 |
17.99 |
"S/G: 416mi; 24.1gal; 17.2mpg" |
2016-08-16 |
123.6 |
8 |
15.45 |
"S/G: 121mi; 7.84gal;15.4mpg" |
2016-08-18 |
252.5 |
12.2 |
20.7 |
"S/G: 249mi; 13.0gal; 19.0mpg" |
2016-08-19 |
364.6 |
17.5 |
20.83 |
"S/G: 361mi; 17.8gal; 20.1mpg
@75-80mph!" |
2016-08-23 |
109.5 |
6.7 |
16.34 |
"S/G: 107mi; 5.91gal; 18.0mpg" |
2016-08-30 |
170.3 |
9.7 |
17.56 |
"S/G: 166mi; 10.3gal; 16.0mpg" |
2016-09-05 |
277.8 |
14.9 |
18.64 |
"S/G: 439mi; 26.0gal; 16.8mpg" |
2016-09-16 |
151 |
8.38 |
18.02 |
"Only S/G data after LED debacle blowing fuses and resetting trip counter and S/G" |
2016-09-21 |
94 |
5.32 |
17.67 |
"Only have S/G data - forgot to reset after last fill-up and that after LED debacle blowing fuses and resetting trip counter" |
2016-09-29 |
241.2 |
13.9 |
17.35 |
"S/G: 235mi; 14.9gal; 15.7mpg" |
2016-10-05 |
169.4 |
9.8 |
17.29 |
"S/G: 165mi; 9.9gal.16.7mpg" |
2016-10-16 |
237.9 |
15.1 |
15.75 |
"S/G: 396mi; 24.8gal; 15.9mpg
trying maf clean after fill-up" |
2016-10-26 |
241.2 |
14.4 |
16.75 |
"S/G: 235mi; 14.1gal; 16.1mpg" |
2016-11-03 |
224.9 |
13.4 |
16.78 |
"S/G: 219mi; 13,6gal; 16.0mpg" |
2016-11-08 |
138.2 |
8.5 |
16.26 |
"S/G: 134mi; 8.0gal; 16.8mpg" |
2016-11-23 |
404 |
25.3 |
15.97 |
"S/G: 394mi; 25.4gal; 15.4mpg" |
2016-11-24 |
277.5 |
14.2 |
19.54 |
"S/G: 274mi;15.6gal; 17.5mpg" |
2016-11-25 |
207.4 |
20.33 |
"S/G: 205mi; 10.4gal; 19.6mpg" |
2016-11-26 |
289.4 |
15.5 |
18.67 |
"S/G: 286mi; 15.0gal; 18.9mpg" |
2016-12-01 |
156.7 |
8.3 |
18.88 |
"S/G: 153mi; 8.4gal; 18.2mpg" |
2016-12-07 |
153.4 |
10.1 |
15.19 |
"S/G: 145mi; 9.2gal; 16.0mpg
40% ethanol
started running paper filter - suspecting oil contamination of MAS" |
2016-12-12 |
212.1 |
15 |
14.14 |
"S/G: 81.8mi; 4.70gal; 17.3mpg" |
2016-12-14 |
72.8 |
5.5 |
13.24 |
"S/G: 66.5mi; 3.88gal; 17.0mpg" |
2016-12-21 |
218.1 |
15.6 |
13.98 |
"S/G: 212mi; 18.2gal; 11.6mpg
new battery after this tank" |
2017-01-04 |
126.3 |
11.8 |
"S/G: 154mi; 11.0gal; 13.9mpg
fixed dragging brake and other front left bits after this tank" |
2017-01-11 |
167.1 |
11.1 |
15.05 |
"S/G: 163mi; 11.2gal; 14.5mpg" |
2017-01-18 |
101.3 |
6.8 |
14.9 |
"S/G: 98.9mi; 7.1gal; 13.7mpg" |
2017-01-24 |
154.9 |
10.3 |
15.04 |
"S/G: 151mi; 10.3gal; 14.5mpg" |
2017-02-01 |
169.3 |
10.8 |
15.68 |
"S/G: 165mi; 10.7gal; 15.3mpg" |
2017-02-09 |
173.3 |
11.1 |
15.61 |
"S/G: 168mi; 11.3gal; 14.8mpg" |
2017-02-27 |
315.9 |
19 |
16.63 |
"S/G: 308mi; 20gal; 15.3mpg" |
2017-03-09 |
185.7 |
11.9 |
15.61 |
"S/G: 181mi; 11.8gal; 15.2mpg" |
2017-03-16 |
117.6 |
8.3 |
14.17 |
"S/G: 115mi; 8.0gal; 14.4mpg" |
2017-03-22 |
167.4 |
10.5 |
15.94 |
"S/G:163mi; 10.3gal; 15.8mpg" |
2017-04-05 |
270.1 |
17.2 |
15.7 |
"S/G: 263mi; 17.2gal; 15.2mpg
don't have actual gallons - used S/G which has been pretty close" |
2017-04-13 |
280.3 |
15.8 |
17.74 |
"S/G: 274mi; 16.2gal; 16.7mpg" |
2017-04-19 |
149.9 |
8.7 |
17.23 |
"S/G: 146mi; 8.7gal; 16.7mpg" |
2017-04-26 |
127.5 |
7.9 |
16.14 |
"S/G: 270mi; 16.4gal; 16.4mpg" |
2017-05-02 |
162.2 |
17.07 |
"S/G: 158mi; 9.60gal; 16.4mpg" |
2017-05-18 |
424.7 |
25.1 |
16.92 |
"S/G: 415mi; 25.1gal; 16.4mpg" |
2017-06-14 |
260.3 |
14.9 |
17.47 |
"S/G: 493mi; 30.6gal; 16.0mpg" |
2017-06-17 |
244.6 |
15.1 |
16.2 |
"S/G: 238mi; 15.4gal; 15.4mpg" |
2017-06-20 |
187 |
17 |
"S/G: 182mi; 11.5gal; 15.7mpg" |
2017-06-28 |
277 |
15.7 |
17.64 |
"S/G: 260mi; 16.0gal; 16.7mpg" |
2017-07-07 |
326.9 |
18.4 |
17.77 |
"S/G: 319mi; 18.1gal; 17.5mpg" |
2017-07-17 |
258.1 |
14.9 |
17.32 |
"S/G: 250mi; 14.8gal; 16.8mpg" |
2017-08-02 |
173.2 |
16.65 |
"S/G: 168mi; 10gal; 16.7mpg" |
2017-08-10 |
237.5 |
13.1 |
18.13 |
"S/G: 232mi; 13.5gal; 17.1mpg" |
2017-08-12 |
250 |
12.1 |
20.66 |
"S/G: 246mi; 12.2gal; 20.1mpg" |
2017-08-14 |
280.5 |
21.09 |
"S/G: 523mi; 25.0gal; 20.1mpg" |
2017-08-22 |
232.6 |
17.89 |
"S/G: 227mi; 12.8gal; 17.5mpg" |
2017-08-26 |
247 |
18.57 |
"S/G data only" |
2017-08-26 |
337.2 |
15.4 |
21.9 |
"S/G: 333mi; 16.2gal; 20.5mpg" |
2017-08-30 |
184.4 |
9 |
20.49 |
"S/G: 181mi; 9.1gal; 19.9mpg" |
2017-09-08 |
139.6 |
8.2 |
17.02 |
"S/G: 136mi; 8.0gal; 16.9mpg" |
2017-09-08 |
186.5 |
8.3 |
22.47 |
"s/g: 184mi; 9.1gal; 20.3mpg" |
2017-09-09 |
223.6 |
21.92 |
"S/G: 221mi; 10,1gal; 21.8mpg" |
2017-09-17 |
283 |
15.6 |
18.14 |
"S/G: 277mi; 14.9gal; 18.5mpg
with 10 gal E15/88oct" |
2017-09-27 |
234.4 |
14.4 |
16.28 |
"S/G: 223mi; 13.4gal; 16.5mpg" |
2017-10-04 |
146.5 |
8.8 |
16.65 |
"S/G: 142mi; 9.1gal; 15.7mpg" |
2017-10-12 |
167 |
16.37 |
"S/G: 162mi; 10.4gal; 15.6mpg" |
2017-10-25 |
290.1 |
17.3 |
16.77 |
"S/G: 281mi; 17.2gal; 16.2mpg" |
2017-11-02 |
217 |
13.7 |
15.84 |
"S/G: 212mi; 13.6gal; 15.5mpg" |
2017-11-16 |
154 |
10.1 |
15.25 |
"S/G numbers only
electrical issues
actual No.s 21.7mi; 10.3gal" |
2017-11-22 |
145 |
9.06 |
16 |
"S/G: 145mi; 9.06gal; 16.0mpg Measured: 84.1mi; 9.3gal
Bad electrics - kept losing trip reading" |
2017-12-06 |
262 |
16 |
16.38 |
"S/G: 255mi; 16.0gal; 15.9mpg" |
2017-12-13 |
169.6 |
10.8 |
15.7 |
"S/G: 165mi; 10.8gal; 15.2mpg" |
2017-12-20 |
152.6 |
15.26 |
"S/G: 146mi; 9.7gal; 15.0mpg" |
2017-12-28 |
85.8 |
11.4 |
7.53 |
"Jumpstart so no tripcounter
S/G: 84.7mi; 4.33gal; 19.5mpg" |
2018-01-04 |
147 |
14.41 |
"Battery issues so no tripcounter
S/G: 147mi; 8.74gal; 16.8mpg" |
2018-01-11 |
167 |
14.4 |
"S/G: 162mi; 9.82gal; 16.5mpg" |
2018-01-23 |
243.5 |
16.8 |
14.49 |
"S/G: 237mi; 14.6gal: 16.2mpg" |
2018-01-31 |
137 |
9.9 |
13.84 |
"S/G; 133mi; 9.76gal; 13.6mpg" |
2018-01-31 |
137 |
9.9 |
13.84 |
2018-02-07 |
91.9 |
6.9 |
13.32 |
"S/G: 89.8mi; 6.4gal; 13.9mpg" |
2018-02-22 |
242.2 |
16.2 |
14.95 |
"S/G; 236mi; 17.6gal; 13.3mpg" |
2018-03-07 |
224.2 |
15.2 |
14.75 |
"S/G: 218mi; 14.7gal; 14.7mpg" |
2018-03-15 |
212.4 |
13.9 |
15.28 |
"S/G: 207mi; 13.9gal; 14.8mpg" |
2018-03-21 |
153 |
15.3 |
"S/G: 149mi; 9.8gal; 15.2mpg" |
2018-04-05 |
206.5 |
15.88 |
"S/G:201mi; 13.8gal; 14.5mpg" |
2018-04-18 |
165 |
11.2 |
14.73 |
"S/G:160mi; 11.1gal; 14.4mpg
electrical issues lost some mileage on S/G and trip counter but have running miles total so 165 is right" |
2018-04-25 |
148.2 |
9.2 |
16.11 |
"S/G: 144mi; 9.5gal; 15.2mpg" |
2018-05-09 |
223.2 |
13.8 |
16.17 |
"S/G: 217mi; 14.0gal; 15.4mpg" |
2018-05-25 |
353.2 |
19.5 |
18.11 |
"S/G: 354mi; 19.5gal; 17.6mpg" |
2018-05-31 |
313.4 |
16.1 |
19.47 |
"S/G: 308mi; 16.5gal; 18.5mpg" |
2018-06-22 |
447.2 |
25.9 |
17.27 |
"S/G: 435mi; 26gal; 16.6mpg" |
2018-06-29 |
321 |
17 |
18.88 |
"S/G: 313mi; 17.2gal; 18.2mpg" |
2018-07-06 |
352.6 |
18.4 |
19.16 |
"S/G: 346mi; 18.4gal: 18,7mpg" |
2018-07-09 |
302.7 |
15.9 |
19.04 |
"S/G: 298mi; 15.8gal; 18.7mpg" |
2018-07-15 |
298.4 |
16 |
18.65 |
"S/G: 291mi: 15.6gal; 18.5mpg" |
2018-07-31 |
455.2 |
26 |
17.51 |
"S/G: 443mi; 26.9gal; 16.4mpg" |
2018-08-10 |
283 |
16 |
17.69 |
"S/G: 276mi; 16.0gal; 17.2mpg
lost gal part of receipt so S/G gal" |
2018-08-21 |
294.8 |
15.7 |
18.78 |
"S/G: 289mi; 16.1gal; 17.8mpg" |
2018-08-31 |
351 |
19.8 |
17.73 |
"S/G: 343mi; 19.8gal; 17.2mpg" |
2018-10-26 |
285 |
16.36 |
17.42 |
"S/G: 279mi; 16.7gal; 16.6mpg" |
2018-11-15 |
265.1 |
16.8 |
15.78 |
"S/G: 259mi; 15.7gal; 16.4mpg" |
2018-11-30 |
235.4 |
15.1 |
15.59 |
"S/G: 230mi; 14.7gal; 15.5mpg" |
2018-12-11 |
98 |
7.1 |
13.8 |
"S/G: 95.6mi; 6.8gal; 13.9mpg" |
2018-12-19 |
224.9 |
16.91 |
"S/G: 220mi; 14.2gal; 15.4mpg" |
2019-01-06 |
138.9 |
8.8 |
15.78 |
"S/G: 135mi; 8.7gal; 15.6mpg" |
2019-01-21 |
206.4 |
14.8 |
13.95 |
"S/G: 201mi; 14.6gal; 13.7mpg" |
2019-01-27 |
149 |
16.02 |
"S/G: 140mi; 10.7gal; 15.1mpg" |
2019-02-13 |
265.3 |
16.6 |
15.98 |
"S/G: 259mi; 16.9gal; 15.2mpg" |
2019-02-26 |
264.5 |
16.9 |
15.65 |
"S/G: 258mi; 16.6gal; 15.4mpg" |
2019-03-19 |
380.7 |
26.1 |
14.59 |
"S/G: 371mi; 24.7gal; 14.9mpg" |
2019-04-03 |
247.5 |
15.4 |
16.07 |
"S/G: 242mi;15.7gal;15.3mpg" |
2019-04-14 |
173.6 |
11.5 |
15.1 |
"S/G: 170mi;10.4gal;16.2mpg" |
2019-04-24 |
366.9 |
22.2 |
16.53 |
"S/G: 356mi;22.2gal;15.8mpg
can refill so off a bit" |
2019-05-05 |
328.4 |
19.9 |
16.5 |
"S/G: 321mi;19.5gal;16.4mpg" |
2019-05-15 |
245.2 |
15.5 |
15.82 |
"S/G: 238mi;15.7mpg;15.1mpg" |
2019-05-31 |
284 |
17.5 |
16.23 |
"S/G: 277mi;17.6gal;15.6mpg" |
2019-06-16 |
237.6 |
13.7 |
17.34 |
"S/G: 233mi;14.1mi;16.4mpg" |
2019-06-23 |
264 |
15 |
17.6 |
"S/G: 259mi;14,9gal;17.2mpg" |
2019-06-26 |
181.2 |
10.3 |
17.59 |
"S/G: 178mi;9.95gal;17.8mpg" |
2019-07-03 |
122.3 |
7.3 |
16.75 |
"S/G: 119mi;7.48gal;15.9mpg" |
2019-07-11 |
281.5 |
15.9 |
17.7 |
"S/G: 276mi;16.0gal;17.2mpg" |
2019-08-02 |
206.9 |
12.9 |
16.04 |
"S/G: 201mi;13,0gal;15.3mpg" |
2019-08-23 |
277.5 |
16.7 |
16.62 |
"S/G: 272mi;18.0gal;15.0mpg" |
2019-09-23 |
246.2 |
16.4 |
15.01 |
"S/G: 241mi;15.7gal;15.2mpg" |
2019-10-04 |
249.1 |
14.9 |
16.72 |
"S/G: 243mi;14.6gal;16.5mpg" |
2019-10-06 |
181.1 |
19.47 |
"S/G: 178mi;9.4gal;18.9mpg" |
2019-10-16 |
270.3 |
16.1 |
16.79 |
"S/G: 264mi;15.7gal;16.7mpg" |
2019-10-30 |
243.6 |
15 |
16.24 |
"S/G: 238mi; 14.8gal; 16.0mpg" |
2019-11-08 |
227.7 |
14.4 |
15.81 |
"S/G: 220mi; 14.0gal; 15.7mpg" |
2019-11-25 |
252 |
15 |
16.8 |
"S/G: 247mi; 15.8gal; 15.5mpg" |
2019-12-16 |
247.5 |
16.4 |
15.09 |
"S/G: 241mi; 16.5gal; 14.6mpg" |
2019-12-25 |
262.2 |
15.4 |
17.03 |
"S/G: 257mi; 15.7gal; 16.2mpg" |
2020-01-08 |
269.2 |
15.8 |
17.04 |
"S/G: 264mi; 15.9gal; 16.5mpg" |
2020-01-17 |
254.5 |
16.3 |
15.61 |
"S/G: 248mi; 15.9gal; 15.5mpg" |
2020-02-04 |
241.7 |
16.1 |
15.01 |
"S/G: 144mi; 8.31gal; 17.3mpg" |
2020-02-14 |
265 |
16.4 |
16.16 |
"S/G: 259mi; 27.7gal; 9.2mpg" |
2020-02-28 |
247.8 |
16.2 |
15.3 |
"S/G: 242mi; 26.3mi; 9.1mpg" |
2020-03-11 |
204.7 |
12.5 |
16.38 |
"S/G: 199mi; 17.1gal; 11.6mpg" |
2020-03-19 |
183.6 |
10.5 |
17.49 |
"S/G: 179mi; 11.9gal; 14.9mpg" |
2020-04-10 |
135 |
8 |
16.88 |
"S/G: 132mi; 8.52gal; 15.4mpg" |
2020-05-08 |
270.7 |
15.8 |
17.13 |
"S/G: 265mi; 16.0gal; 16.4mpg" |
2020-05-23 |
282 |
15.7 |
17.96 |
"S/G:277mi; 15.7gal; 17.5mpg" |
2020-06-24 |
264.9 |
15 |
17.66 |
"S/G: 260mi; 15.8gal; 16.3mpg" |
2020-06-30 |
307 |
14.9 |
20.6 |
"S/G: 302mi; 15.6gal; 19.3mpg" |
2020-07-05 |
253.5 |
14.4 |
17.6 |
"S/G: 248mi; 14.7gal; 16.9mpg" |
2020-07-09 |
221.4 |
12.2 |
18.15 |
"S/G: 218mi; 12.3gal; 17.7mpg" |
2020-07-23 |
203.2 |
11.5 |
17.67 |
"S?G: 198mi; 11.2gal; 17.5mpg" |
2020-08-06 |
272 |
15.2 |
17.89 |
"S/G: 267mi; 15.1gal; 17.6mpg" |
2020-08-26 |
237.9 |
14.1 |
16.87 |
"S/G: 232mi; 13.6gal; 17.0mpg" |
2020-09-18 |
201 |
11.2 |
17.95 |
"S?g: 196mi; 10.7gal; 18.3mpg" |
2020-10-14 |
244.5 |
14.9 |
16.41 |
"S/G:239mi; 14.4gal; 16.5mpg" |
2020-11-04 |
245 |
14.9 |
16.44 |
"S/G: 240mi; 14.0gal; 17.0mpg" |
2020-12-01 |
272.5 |
16.5 |
16.52 |
"S/G: 266mi; 16.9gal; 15.6mpg" |
2020-12-09 |
93.9 |
6.5 |
14.45 |
"S/G: 358mi; 23.1gal; 15.4mpg" |
2021-01-08 |
211 |
13.2 |
15.98 |
"S/G: 201mi; 12.9gal; 15.4mpg" |
2021-01-16 |
250.8 |
13.4 |
18.72 |
"S/G: 247mi; 14.5gal; 17.0mpg" |
2021-01-27 |
221.2 |
13.9 |
15.91 |
"S/G: 217mi; 13.4gal; 16.1mpg" |
2021-02-04 |
261.8 |
14.4 |
18.18 |
"S/G: 456mi; 27.5gal; 16.5mpg" |
2021-02-04 |
200.4 |
12.3 |
16.29 |
"S/G: ? only one set of numbers, no note..." |
2021-02-10 |
212.1 |
12.1 |
17.53 |
"S/G: 209mi; 12.1gal; 17.2mpg" |
2021-03-03 |
252.3 |
16 |
15.77 |
"S/G: 246mi; 15.7gal; 15.6mpg" |
2021-04-04 |
330.6 |
20.5 |
16.13 |
"S/G: 570mi; 35.8gal; 15.9mpg" |
2021-04-28 |
263.2 |
15.5 |
16.98 |
"S/G: 257mi; 15.3gal; 16.7mpg" |
2021-05-21 |
463.9 |
27.1 |
17.12 |
"S/G: 454mi; 27.1gal (don't have actual); 16.7mpg" |
2021-05-29 |
265.6 |
15.4 |
17.25 |
"S/G: 261mi; 15.6gal; 16.6mpg" |
2021-05-30 |
332.4 |
17.5 |
18.99 |
"S/G: 328mi; 18.1gal.; 18.1mpg" |
