2010-07-13 |
406 |
9.601 |
$2.7 |
42.29 |
"Cruising 65 - 75mph. 99% highway miles." |
2010-07-15 |
402 |
9.016 |
$2.8 |
44.59 |
"Experimented with 60 - 65 mph cruising speed. 99.9% highway miles." |
2010-07-26 |
219 |
4.925 |
44.47 |
"90% highway, 10% city. Mostly at 60 mph.
Installed two flaps in front of two front wheels to minimize air from going into wheel well from the air passing below the belly pan." |
2010-07-27 |
400 |
8.227 |
48.62 |
"99% highway at 60 mph. The front air diverters for the two front tires appear to be working well.
Method of driving was to slow to 55 mph while go uphill and accelerate back to 60 mph go down hill." |
2010-07-29 |
401 |
8.702 |
$2.74 |
46.08 |
"Not very happy with the HAI, but at least I can go back to the stock setup and call it quits on the HAI. It seems to be decreasing the overall vacuum pressure and skewing the scanguages mpg calculation. I seen 51 - 52 mpg for the entire tank per the scanguage but it appears that I really only got around 46 mpg on this tank.
Also, I pumped at Sams Club instead of my usual Meijer gas station. The pump was pumping gas much faster than I normally pumped so that may have caused some error." |
2010-08-02 |
206 |
4.547 |
$2.78 |
45.3 |
"Half miles at 60 mph, other half at 70 mph. In a rush for a meeting so drove faster." |
2010-08-03 |
199 |
4.2 |
$2.86 |
47.38 |
"Single day commute at 60 mph to re-establish baseline mpg with the car and current mods." |
2010-08-04 |
200 |
4.314 |
$2.86 |
46.36 |
"Drove at 60 mph. Took off mud flaps / air diverters on the two front wheels. Looks like I will have to put them back on." |
2010-08-05 |
200 |
4.402 |
$2.86 |
45.43 |
2010-08-09 |
189.2 |
4.002 |
$2.66 |
47.28 |
"Using new gas station that tends to pump gas ""faster"". Testing 70mph cruising speeds again. On the way home, some rain and turned on the lights." |
2010-08-11 |
401 |
9.437 |
$2.86 |
42.49 |
"May have gas pump error. Tried to maintain 70mph to determine mpg at that level." |
2010-08-20 |
9.473 |
$2.65 |
39.9 |
"Half highway, half city" |
2010-08-23 |
277.1 |
7.112 |
$2.6 |
38.96 |
"70mph average, all highway" |
2010-08-24 |
391.6 |
9.111 |
$2.6 |
42.98 |
"70mph, all highway" |
2010-08-26 |
306.3 |
7.656 |
$2.48 |
40.01 |
"70 mph, all highway. Found a cheaper gas station" |
