2009-07-20 |
279.8 |
11.03 |
25.37 |
"Commute, Summer 2009, Gasohol (90/10)" |
2009-07-23 |
383.5 |
14.14 |
27.12 |
2009-08-02 |
357.5 |
13.85 |
25.81 |
2009-08-09 |
245.2 |
9.595 |
25.55 |
2009-08-15 |
354.8 |
13.62 |
26.05 |
2009-08-21 |
336.3 |
12.17 |
27.63 |
"End of summer, Week before school started back up, may have had highway trip, Gasohol (90/10)" |
2009-09-07 |
208.3 |
9.253 |
22.51 |
"Mainly Weekend Travel, trips around campus College back in session, Gasohol (90/10)" |
2010-01-11 |
228.4 |
12.9 |
17.71 |
"Found a blog post about how I was complaining my winter mileage was 17.7 mpg. Decided to add this to my fuel log. I could not find the receipts for over this past winter, so I started trying to track down other methods of back logging winter mileage." |
2010-06-10 |
342.3 |
14.23 |
24.05 |
"Mixed Driving, Gasohol (90/10)" |
2010-06-18 |
315 |
12.76 |
24.69 |
"Mixed Driving, Commute, Gasohol (90/10), Mileage is approximate" |
2010-06-29 |
354.9 |
13.34 |
26.6 |
"Mixed driving with Highway Trip, Gasohol (90/10)" |
2010-07-07 |
303.1 |
12.8 |
23.68 |
"Mixed Driving, All Commute, Gasohol (90/10)" |
2010-07-14 |
292.5 |
11.94 |
24.5 |
"Mixed Driving, Commute, Gasohol (90/10)" |
2010-07-21 |
310.4 |
11.91 |
26.06 |
"Mixed Driving, Commute, Gasoline (non-ethanol)" |
2010-07-29 |
331.1 |
11.72 |
28.25 |
"Mixed Driving, Commute, Highway Trip, Gasoline (non-ethanol)" |
2010-08-06 |
312.5 |
11.24 |
27.8 |
"Mixed Driving - Commute, Gasoline (100/0) Did a stunt of spirited driving for about 8 miles at ludicrous speed" |
2010-08-16 |
339.8 |
11.9 |
28.55 |
"Mixed Driving - Mainly commute, includes some short trips and eco testing doing 60-50 and 50-40 coast test for before and after front grill block." |
2010-08-19 |
162.2 |
5.606 |
28.93 |
"Commute work, only 5.6 gallons into tank, refilled before a long trip. Gasoline (100/0) ~35 miles of the tank was driven in Non-eco mod as I took a co worker home from work. :-p" |
2010-08-22 |
532.2 |
16.8 |
31.68 |
"Trip to NY state near Lake Ontario. Observed ~284 miles on 8-9 gallons (31-35MPG). Return trip was rain, defroster, and traffic jams. Defroster is ~10-11 percent lost, estimated true MPG for pure Highway to about 34MPG." |
2010-09-01 |
322.1 |
11.96 |
26.93 |
"Alot of mixed driving, short trips, idle in the driveway, work commute, School traffic this past week, also let loose a bit and drove little bit on the aggressive side, Gasohol (90/10). Happy with results considering." |
2010-09-13 |
351.6 |
12.9 |
27.26 |
"Regular work commute on pure gasoline with mild residual gasohol (~3 gallons gasohol to 13 gallons Gasoline, so 99% gasoline). Drove a bit like an ass again. Weather is starting to go south as well. redeemed myself got managed to break 27." |
2010-09-24 |
365.3 |
12.93 |
28.25 |
"Mostly commute, few cold mornings. Evenings still above 65-70 degrees" |
2010-10-05 |
355.7 |
14 |
25.41 |
"Exceptionally rainy weather in NE, some excess idle from working on exhaust with leaks. A few spurts of aggressive driving, and every morning commute started @ 45-50 degrees" |
2010-10-20 |
489.7 |
19 |
$2.85 |
25.77 |
"Short trips and work commute, Gasohol (E10). Topped off tank while trying to find another non-ethanol station...all cold morning starts. Last tank prior to swapping to synthetic trans fluid. Should help the cold morning starts." |
2010-10-29 |
285.9 |
11.24 |
25.44 |
"E10 gas used during a bit cold spell (sub 50) and bit of a warm spell (upper 60's) in October weather. Changed the trans fluid to syn ATF halfway through tank. Changing required short drives and ~25 minutes of idle time. Not sure how to gauge MPG average. Mixed wasted idle time, commute, short trip, cold weather, warm weather, and rain days with defroster. Overall can't complain because the Subaru broke 25MPG which is its highway rating." |
2010-10-31 |
430.7 |
14.93 |
28.85 |
"Trip to DC for Steward/Colbert Rally. Was following a leading vehicle who drove decently, but not economically. Load vehicle 4 people w/ driver and light cargo (~600lbs more than normal). E10 fuel with winter-blend. Temp ranges from 32 to 50 degree Fahrenheit. Mainly highway with speeds above 70mph (following lead vehicle)." |
2010-11-08 |
13.1 |
26.11 |
"Mostly commute with one alumni trip to and from school. Broke 26 mpg, higher than all the other commuter tanks in October. I believe 1500rpms and 40mph might be working better in the cold. Ordered Ultra Gauge this past weekend!" |
2010-11-17 |
325.9 |
12.77 |
25.52 |
"A few short trips, regular commute. E10 gas. First trip with Ultra Gauge, approximately calibrated now." |
2010-11-24 |
360.7 |
13.06 |
27.62 |
"Commute with journey out for job interview. A bit more highway than usual. I have the UG calibrated and it has been helping ALOT to lean out the thorttle as much as possible." |
2010-12-06 |
292.9 |
12.95 |
$3.099 |
22.62 |
"~100 miles commute, and 40 mile trip to go shopping at a distant location. The other 150 was a majority short distance driving to and from town. Still using E10, only non-ethanol gas around is 93 octane :-/" |
2010-12-16 |
344.4 |
14.54 |
23.69 |
"Sunoco 87 octane E10. I believe this is mostly commuting with a few short trips to shops. I was a little late with posting this one to retain the details! :-/" |
2010-12-23 |
350.2 |
13.85 |
$3.099 |
25.29 |
"This tank was Sunoco 89 octane, Part work commute and a trip to see friends. Also have a few short trips to and from shopping. 89 octane seemed to give no noticable difference in start up/running. (subaru has 10:1 compression, recommending 87 or higher). I will see if there is any differences with the next tank and try to make a comparison between 87 E10 and 89 E10 and how the vehicle runs with either on in the tank.
I maybe have skewed data myself as I finally go to get the smooth wheel covers on the front of the car. So I may need to do another 89 octane tank to properly compare." |
2010-12-31 |
292.8 |
11.78 |
$3.099 |
24.86 |
"Sunoco 87 Octane, E10 gas. Working commute, one snow day where took an additional 20 minutes to get to work in the morning. Wheel covers on, side mirror out (previously had been folding/unfolding depending on drive location, seem to have let go of this habit)" |
2011-01-09 |
297.2 |
11.61 |
$3.129 |
25.6 |
"Sunoco 87 octane, E10. Drove to New years part, slightly more highway than normal, and some side trips while visiting friends new years day. Rest of tank was normal work commute, Friday snowy morning took additional 15-20 minutes on commute into work (had UG go from 26.6 to 26.8 on trip in!) Wheel covers on front, side mirror out. Need to fold side mirror in and try my best to beat out last years MPG of 17.7 for mid January!" |
2011-01-18 |
331.9 |
13.74 |
24.16 |
"Sunoco 87 Octane, E10, Two snow days of driving through slush, 95% commuting. Mirrors out, front wheels covered, wheel skirts, using heated seats, defroster, etc." |
2011-01-25 |
336.6 |
13.61 |
24.73 |
"Extreme Cold and Fuel issues with Subaru. Fuel Rail is leaking at sub zero temperatures.
One snow day.
Sunoco 87 oct. E10 Gasoline, folding mirror in again." |
2011-02-04 |
328.8 |
14.32 |
22.96 |
"Should be mostly work commute, Sunoco gas, E10, late entry don't remember much of the details, definitely has snow days on this tank." |
2011-02-08 |
186 |
7.719 |
24.1 |
"Work commute, filled up before driving to an interview (irregular trip), had a snow day on this short tank, Sunoco, E10," |
2011-02-13 |
304.4 |
12.39 |
24.57 |
"Not sure, found the receipt in my stack of paper work this morning. Probably snow days and work commuting.
E10 Sunoco Fuel" |
2011-02-16 |
168.6 |
6.244 |
27 |
"Re-filled in middle of the week so I would have enough fuel to make it through the weekend plans and work. Still using Sunoco E10. Weather was bitter cold and I was using both mirrors." |
2011-02-22 |
286.2 |
11.61 |
24.65 |
"Work commuting, few short trips, regular driving. E10, sunoco" |
2011-03-01 |
343.6 |
13.42 |
25.6 |
"Last few days commute at old job, weekend driving, and two days commute to new job. Next tank will be quite exciting. It's getting warming and the new commute is eco-friendlier than old commute...well hopefully! E10 Sunoco" |
2011-03-07 |
320.9 |
12.53 |
25.61 |
"Sunoco Gas, E10, 87 Oct. New commute route to the new job :-) Topped off on 209." |
2011-03-09 |
156.7 |
5.614 |
27.91 |
"Sunoco E10, 87 Oct. Filled on 209. Topped off to make the week. ~80 miles a day, 5 days, 400 miles a week (without side trips). Current mileage makes the tank near 0.5 gallons on the way home friday. Too close for comfort!" |
2011-03-13 |
324.4 |
11.92 |
27.21 |
"Topped off tank in L-town for the week. Sunoco, E10, 87 Oct. Temps are coming up, may need to clip free a grill block. But the warm weather is welcomed. 0W-30 oil is within 1,000 miles of an oil change. May sway to 5W-30 for summer." |
2011-03-17 |
297.7 |
10.98 |
27.11 |
"Work commute, Sunoco Gas From Ltown, filled up at Sunoco #209. E10, 87 Octane. Warming weather. Mirrors out. Grill blocks still on." |
2011-03-22 |
332.8 |
12.71 |
26.18 |
"Sunoco, E10, 87 Octane, filled up at 209 station, tank includes snow day." |
2011-03-28 |
347.6 |
13.46 |
25.82 |
"Sunoco on 209, E10 87 octane" |
2011-04-03 |
354.1 |
13.32 |
26.58 |
"Last Tank before decommissioning of the skirts and wheel tape. Fill up in Lehighton at Sunoco with 87, E10" |
2011-04-08 |
330.9 |
12.65 |
26.16 |
"-E10 87 octane
-Work commute without skirts" |
2011-04-14 |
331.5 |
12.36 |
26.82 |
"-E10 87 octane
-Work Commute without skirts" |
2011-04-20 |
299.8 |
11.93 |
25.13 |
"E10 87 octane, Work Commute, new pulley installed, drove a bit like an ass to test new pulley" |
2011-04-21 |
136.8 |
4.753 |
28.78 |
"two days commute, with upgraded pulley, on E10 87 octane. Gave it an honest try to eco-mile the Subaru. This is with wheels open, no skirts, temps in the 40s-50s, weather is reasonable - no rain, overcast, slight humidity. Refill because this weekend installed an exhaust header. This will be the base comparison if the header can add/subtract fuel mileage." |
2011-04-27 |
334.3 |
12.48 |
26.79 |
"Post Header install, don't expect greatness, had a little fun. :-)
E10 87 octane" |
2011-04-29 |
153.8 |
5.542 |
27.75 |
"Had a bit of decent driving conditions without too much romping the gas. Morning drive was down pours @ 2""/hr. Had small impact on the FE. This is Header, crank pulley mod, only aero mod install are the air deflectors under the bumper to cover each front tire. No grill block, side deflectors, or skirting.
Sunoco E10 87 octane" |
2011-05-05 |
361 |
13.12 |
27.52 |
"Work commute, kept a steady foot and eco-miled most of the tank. Result are pretty in favor of the exhaust header and light weight pulley.
2011-05-11 |
340.3 |
11.97 |
28.43 |
"Work Commute in good weather! E10 87 octane sunoco gas." |
2011-05-13 |
153.5 |
5.144 |
29.84 |
"Two days work commute, UG showed 29.1 MPG, so I figured I would top off before the weekend. E10 87 octane Sunoco Gas" |
2011-05-20 |
310.6 |
10.9 |
28.5 |
"Work Commute, 87 octane sunoco" |
2011-05-26 |
339.8 |
11.97 |
28.39 |
"Weekend driving + Work Commute, heavy rain in the early week. E10 87 octane sunoco." |
2011-05-27 |
75.3 |
2.384 |
31.59 |
"One day's commute, Friday before memorial, very little traffic and good weather 65 in the morning and 80 on the way home. Basically sets the peak of the best that may be achievable with current setup. E10 87 octane, sunoco." |
2011-06-06 |
342.9 |
12.7 |
27 |
"This tank included spirited driving, work commute, and short trips before a weekend vacation. 87 octane sunoco" |
2011-06-10 |
312.8 |
10.82 |
28.91 |
"Regular work commute, 87 octane, E10, Sunoco" |
2011-06-16 |
340.5 |
12.23 |
27.84 |
"work commute, sunoco, 87 octance, reasonable weather, one day rain." |
2011-06-23 |
351.5 |
12.96 |
27.12 |
2011-06-30 |
360.1 |
12.67 |
28.42 |
"work commute" |
2011-07-06 |
317.8 |
11.93 |
26.64 |
"work commute" |
2011-07-12 |
322 |
11.4 |
28.25 |
"Driving commute to and from work" |
2011-07-18 |
335.5 |
12.5 |
26.84 |
2011-07-19 |
76.6 |
2.66 |
28.8 |
"refill before departure on trip to NY for wedding" |
2011-07-20 |
286.3 |
9.381 |
30.52 |
"Trip from PA to the NY mountains and back" |
2011-07-25 |
345.4 |
12.7 |
27.2 |
"No receipt..." |
2011-07-31 |
338.6 |
11.74 |
28.84 |
2011-08-05 |
387.1 |
13.31 |
29.08 |
"work commute" |
2011-08-13 |
417.1 |
15.13 |
27.57 |
"work commute" |
2011-08-19 |
385.9 |
13.62 |
28.33 |
"work commute" |
2011-08-26 |
389.6 |
13.501 |
28.86 |
"work commute" |
2011-09-13 |
421.6 |
14.79 |
28.51 |
"Last Tank!" |
