2010-08-28 |
223 |
12.5 |
$2.49 |
17.84 |
"Road trip to OBX several days on beach lots of idling and 4wd use painful trip to Kittyhawk hospital with mom" |
2010-09-02 |
487 |
24.57 |
19.82 |
"return trip from OBX trip all highway driving little to no traffic finish all levels checked and driving straight with 1 highway stops for quick snack 60-65mph drive home." |
2010-09-10 |
361 |
25.37 |
14.23 |
"Back to reality Daycare and the train station daily drive" |
2010-09-26 |
25.08 |
13.16 |
"daily commute" |
2010-10-21 |
26.94 |
11.88 |
"motorcycle use didn't drive truck much" |
2010-10-30 |
275 |
18.55 |
$2.65 |
14.82 |
"fixed junk design of exhaust and changed air filter STP stock replacement" |
2010-11-06 |
376 |
24.69 |
15.23 |
"True Mix of highway and in town driving first full fill up since exhaust completion Highway speeds 72mph" |
2010-11-29 |
311 |
24.27 |
12.81 |
"Trailered car found tires to be Very low on air... most around town driving" |
2010-12-08 |
328.1 |
21.82 |
$2.89 |
15.04 |
"mix driving half and half" |
2010-12-10 |
378.1 |
24.3 |
15.56 |
"320 mile highway trip to Albany up the catskill mountains 30 mins stop and go traffic some bad speeding habits apx. 20 mins of idiling trying to keep warm. Speed 65-75 mph
65mph truck turns 1700rpm 70mph it turns 1900rpm" |
2011-01-10 |
238.4 |
20.47 |
$2.93 |
"a month of only driving in 4wd only when needed. Alot of Idling tires were filled up entire tank wa @30lbs. 4 big snow storms more to come Not driving with mpg's in mind just point A to B with crap traffic." |
2011-02-20 |
465 |
9.88 |
$3.039 |
47.06 |
"Partial add to the tank, we are not allowed to pump our own fuel the halfwitt at the pump got me to 3/4 of a tank the next fill up will balance out the #s properly." |
2011-03-05 |
178 |
25.78 |
6.9 |
"Filled to the top this time still needs an oil change and hauled around a few hundred pounds of auto parts finally removed the extra weight today 3-7-2011. Need to check tire pressure weather just plain sucks still 30-40 degrees at best windy as hell today 40+mph and flooding due to heavy rains not ideal to say the least what a crappy week of weather." |
2011-03-12 |
182 |
12.12 |
15.02 |
"Light traffic drove around town all week truck needs front shocks handling is going to hell. Overdue for Oil change and need to check air pressure its been a while.
disappointed in the mpg with this tank but then again the station attendant squeezed in too much trying to even the price to $40 it may show on next tank." |
2011-03-23 |
141 |
10.78 |
13.08 |
"Its April and snowing today rain + Sleet = traffic this just sucks garbage driving week..." |
2011-04-21 |
23.92 |
13.59 |
"Swap Meet Weekend in the rain carried a couple thousand extra pounds. spent total 4 hours idling in traffic coming and going. All local driving, I miss the highway local sucks its too crowded here." |
2011-05-24 |
25.2 |
15.12 |
"Truck not driven much it is in need of repair that was done today 5/24/11. Replaced front 2 shocks and stock original coil with BWD factory replacement total cost $38.98 for parts. Shocks so nice want new rear shocks now I am sure 1 is bad also need new wires they are looking real bad and very old." |
2011-06-28 |
276 |
23.23 |
$3.479 |
11.88 |
"Bought a cheap set of Wires for $15 from advance auto parts and a cheap set of monroe shocks for rear Cost $51.23 for all after discount coupons. Idle still seems rough need time to really figure out why it is not smooth." |
2011-08-24 |
24.25 |
12.87 |
"Idle has been very rough finally checked it out and found my distributor bolt is loose need to reset timing and check all of the plugs." |
2011-10-30 |
281 |
15.79 |
17.8 |
"I marked this as a partial fill up in my phone records truck still has fuel in it parked at Johns house while I repair his wagon." |
2012-01-11 |
25.96 |
$3.149 |
12.71 |
"Truck sat parked for months broke her out for some towing and home depot runs. gas is several moths old" |
2012-01-19 |
347 |
24.51 |
14.16 |
"Lots of driving, back and forth runs 30 mile sprints 6 times in one day drove way too fast and something in suspension is loose clunking + alignment is out pulling and shaking over 70mph." |
2012-01-29 |
295 |
23.03 |
12.81 |
"Just found out that was half a quart oil low and 1 quart of trans fluid low. Still has the shakes at 70mph and needs that alignment + noise is getting worse think it may be something silly like the shock loose. trying to use it less last lumberyard run is finished for now." |
