2009-03-18 |
232 |
13.42 |
17.29 |
"Purchased truck
Start...100% highway driving, 40PSI, cleaned TB and IAC, cab high camper top installed, fully stock set up, night drive from San Antonio to Houston" |
2009-03-18 |
219.1 |
11.89 |
18.43 |
"Day drive from Houston to San Antonio" |
2009-03-22 |
230.1 |
13.44 |
17.12 |
"Night drive from San Antonio to Houston" |
2009-03-23 |
218.6 |
10.21 |
21.41 |
"Start...New KYB Gas-A-Just shocks, new stock cat back exhaust, Auto-RX in trans, PS, engine" |
2009-04-03 |
18.87 |
16 |
"Start...New timing belt, water pump, front seals, t-stat, hoses, belts, sway bar bushings/end links, MAF cleaned/ECU reset" |
2009-04-15 |
320.3 |
18.86 |
16.98 |
"Start...New Sylvania 9003 xtravision bulbs, B&M trans coolers (2), Yokohama Geolander A/T-S LT235/75-15R 104/101S tires" |
2009-04-24 |
283 |
15.64 |
18.09 |
2009-05-08 |
267.2 |
16.07 |
16.63 |
"Start...New fan clutch" |
2009-05-09 |
228.3 |
13.27 |
17.2 |
2009-05-10 |
317 |
15.5 |
20.45 |
2009-05-12 |
376.9 |
20.67 |
18.23 |
"Start...New radiator, brake lines" |
2009-05-26 |
307.4 |
19.65 |
15.64 |
2009-06-08 |
250 |
15.6 |
16.03 |
"Start...Auto-RX rinse phase, 5 qts 5W-30 Supertech" |
2009-06-09 |
343.7 |
16 |
21.48 |
2009-06-13 |
361.2 |
19.08 |
18.93 |
2009-06-23 |
284.7 |
16.16 |
17.62 |
"Start...12 qts Supertech ATF" |
2009-07-06 |
300.5 |
19.58 |
15.35 |
"new windshield, new oil filter" |
2009-07-16 |
324.3 |
18.91 |
17.15 |
2009-07-29 |
231 |
15.1 |
15.3 |
2009-07-30 |
367.1 |
18.64 |
19.69 |
2009-08-02 |
389.9 |
20.05 |
19.45 |
2009-08-09 |
315.6 |
18.12 |
17.42 |
2009-08-09 |
328.1 |
18.07 |
18.16 |
2009-08-09 |
276.9 |
15 |
18.46 |
2009-08-16 |
358.6 |
20.25 |
17.71 |
"Start...2nd Auto-RX cleaning, custom oil catch jars" |
2009-09-03 |
287.4 |
19 |
15.13 |
"Start...Roadmaster Active Suspension (LF=31"", RF=31"", LR=33.5"", RR=33.5""), added cool air intake mod to factory air box" |
2009-09-10 |
316.4 |
18.15 |
17.43 |
2009-09-10 |
363.6 |
17.74 |
20.5 |
"Cruise control set to 70mph" |
2009-09-11 |
277.2 |
12.18 |
22.76 |
"Cruise control set to 60mph" |
2009-09-13 |
114.5 |
6.5 |
17.62 |
"Mostly city driving" |
2009-09-13 |
281.7 |
13.1 |
21.5 |
"Cruise control set to 65mph, bug shield removed" |
2009-09-17 |
371.9 |
19.16 |
19.41 |
"Start...Synthetic gear oil in rear differential" |
2009-09-29 |
278.6 |
18.05 |
15.43 |
"City driving moving stuff" |
2009-10-08 |
356.1 |
20 |
17.81 |
"Start...Dropped air dam to 6.5"" below stock (9"" clearance)" |
2009-10-21 |
337.2 |
20.12 |
16.76 |
2009-10-30 |
19.85 |
17.13 |
2009-11-11 |
341.9 |
20.13 |
16.98 |
2009-11-19 |
214.9 |
12.32 |
17.44 |
"Start...2nd Auto-RX rinse phase, 5 qts 5W-30 Supertech, Mobil1 oil filter, tires at 44lbs, bumped bottom lip, air dam belly pan, front tire flaps (3"" below air dam belly pan)" |
2009-11-20 |
254.9 |
12.52 |
20.36 |
"Start...Taped grill and hood gaps, added middle grill block, bed loaded with approx 300lbs, front wheel well height = 31.5"", rear wheel well height = 32.5""" |
2009-11-23 |
306 |
14.93 |
20.5 |
"Middle grill block removed" |
2009-11-27 |
316.7 |
16.94 |
18.7 |
2009-11-27 |
273.2 |
23.45 |
"Cruise set at 60mph, day drive" |
2009-11-29 |
367.1 |
17 |
21.59 |
"Cruise set at 60mph, night/day drive" |
2009-11-30 |
324.9 |
16.44 |
19.76 |
"Cruise set at 70mph, day drive" |
2009-12-09 |
308.5 |
19.2 |
16.07 |
"Start...4oz Dynabeads per tire, filtered cores, 44lbs per tire" |
