2011-06-19 |
253 |
5.105 |
49.56 |
"Alot of highway miles" |
2011-07-01 |
195 |
4.113 |
47.41 |
2011-07-08 |
304 |
5.953 |
$3.809 |
51.07 |
2011-07-23 |
333 |
6.821 |
48.82 |
"Changed cluster over to one with a tach" |
2011-08-06 |
375 |
7.709 |
$3.749 |
48.64 |
2011-08-29 |
7.622 |
$3.839 |
45.92 |
2011-09-07 |
383 |
7.768 |
49.3 |
2011-09-17 |
207 |
4.798 |
43.14 |
2011-09-25 |
348 |
7.637 |
45.57 |
"added 1 qt of oil" |
2011-10-05 |
242 |
5.686 |
$3.289 |
42.56 |
2011-10-18 |
7.817 |
$3.479 |
42.86 |
"cooler temps" |
2011-10-28 |
334 |
7.901 |
42.27 |
"focused more on shifting habits" |
2011-11-14 |
7.958 |
42.1 |
2011-11-24 |
275 |
7.04 |
$3.289 |
39.06 |
2011-12-07 |
7.646 |
39.5 |
"Held higher gears on this tank, colder temps" |
2011-12-20 |
8.444 |
39.32 |
"Holding 5th gear longer" |
2011-12-28 |
339 |
8.205 |
$3.369 |
41.32 |
"More highway miles on this tank" |
2012-01-18 |
319 |
8.224 |
38.79 |
"cooold" |
2012-01-31 |
296 |
7.871 |
37.61 |
2012-02-07 |
247 |
6.209 |
39.78 |
2012-02-16 |
317 |
8.021 |
$3.379 |
39.52 |
"little warmer" |
2012-02-25 |
294 |
7.341 |
$3.439 |
40.05 |
"kroger fuel" |
2012-03-06 |
7.905 |
40.48 |
2012-03-27 |
323 |
7.505 |
43.04 |
"warmer" |
2012-04-06 |
333 |
7.713 |
43.17 |
"warmer" |
2012-04-16 |
303 |
7.132 |
$3.879 |
42.48 |
2012-04-28 |
337 |
7.548 |
44.65 |
2012-05-15 |
310 |
6.828 |
$3.879 |
45.4 |
"60-70 degree days" |
2012-05-26 |
324 |
7.02 |
$3.989 |
46.15 |
2012-06-06 |
7.599 |
45.4 |
"installed factory hubcaps" |
2012-07-22 |
6.511 |
46.84 |
2012-07-30 |
283 |
6.474 |
43.71 |
"Filled to neck" |
2012-08-11 |
351 |
7.319 |
47.96 |
"filled to top of neck" |
2012-08-25 |
7.136 |
49.05 |
2013-06-27 |
6.517 |
44.04 |
"81 degrees" |
2013-07-08 |
310 |
6.735 |
46.03 |
"82 degrees" |
2013-07-23 |
7.403 |
$3.809 |
46.6 |
"81 degrees" |
2013-08-08 |
7.265 |
44.74 |
2013-09-03 |
339 |
7.799 |
$3.629 |
43.47 |
"Gapped plugs to .39 from .50 aired tires to proper pressure" |
2013-09-18 |
324 |
7.243 |
$3.469 |
44.73 |
"73 degrees" |
2013-10-07 |
7.848 |
43.96 |
"54 degrees" |
2013-10-28 |
343 |
8.216 |
$3.369 |
41.75 |
"50degrees" |
2013-11-17 |
285 |
7.201 |
39.58 |
"58 degrees. tires at 40 psi" |
2014-03-01 |
9.448 |
33.87 |
"10 degrees" |
2014-03-14 |
291 |
7.219 |
40.31 |
"49 degrees" |
2014-03-29 |
326 |
8.045 |
$3.69 |
40.52 |
"34 *" |
2014-04-10 |
6.945 |
$3.749 |
42.04 |
"66*" |
2014-04-28 |
334 |
8.003 |
$3.749 |
41.73 |
2014-06-01 |
650 |
13.24 |
49.09 |
2014-06-18 |
8.051 |
$3.949 |
46.33 |
"67*" |
2014-07-07 |
376 |
8.2 |
$3.829 |
45.85 |
"82*" |
2014-07-22 |
319 |
6.963 |
45.81 |
"87*" |
2014-08-06 |
7.662 |
$3.309 |
46.85 |
"75*" |
2014-08-27 |
361 |
8.09 |
$3.269 |
44.62 |
"74*" |
2014-09-09 |
309 |
6.777 |
45.6 |
"80*" |
2014-09-20 |
294 |
6.784 |
43.34 |
"75*" |
2014-09-28 |
317 |
7.241 |
43.78 |
"68*" |
2014-10-11 |
336 |
7.918 |
$3.109 |
42.43 |
"60*" |
2014-10-25 |
7.94 |
$2.979 |
40.93 |
"60*" |
2014-11-04 |
7.853 |
38.33 |
"50*" |
2014-11-15 |
281 |
8.037 |
$2.919 |
34.96 |
"28*" |
2014-11-29 |
280 |
8.28 |
33.82 |
"35*" |
