2011-03-11 299 10.8 27.69 "1st refill...."
2011-03-17 153 5.6 27.32 "one 12 oz bottle of Chevron Techron concentrate...9.1 oz per 10 G"
2011-03-23 266 8.4 31.67 "Chevron Techron concentrate...5.3 oz per 10 G...fuel line magnets..."
2011-03-28 230 6.6 34.85 "Chevron Techron concentrate...1.9 oz per 10 G...fuel line magnets..."
2011-04-10 343 11 31.18 "Chevron Techron concentrate...0.9 oz per 10 G...fuel line magnets...Kiker wires...Autolite plugs"
2011-04-15 205 6.6 31.06 "fuel line magnets...Kiker wires...Autolite plugs
idling...short trips"
2011-04-27 291 9.7 30 "fuel line magnets...Kiker wires...Autolite plugs...2 oz / 10 G Techron
* have a leaking PS system...adding Lucas PS fix to it and it might be reducing mpg due to the increased viscosity?"
2011-05-05 401 12.2 32.87 "fuel line magnets...Kiker wires...Autolite plugs...2 oz / 10 G Techron"
2011-05-19 377 11.4 33.07 "fuel line magnets...Kiker wires...Autolite plugs...2 oz / 10 G Techron...air dam"
2011-06-08 386 11.9 32.44 "fuel line magnets...Kiker wires...Autolite plugs...2 oz / 10 G Techron...air dam"
2011-06-18 434 12.5 34.72 "fuel line magnets...Kiker wires...Autolite plugs...2 oz / 10 G Techron...air dam"
2011-07-04 331 9.3 35.59 "fuel line magnets...Kiker wires...Autolite plugs...2 oz / 10 G Techron...air dam"
2011-07-19 422 12.1 34.88 "fuel line magnets...Kiker wires...Autolite plugs...1.3 oz / 10 G MS gas...MS engine/auto-trans...air dam"
2011-08-08 438 12.1 36.2 "fuel line magnets...Kiker wires...Autolite plugs...1.3 oz / 10 G MS gas...MS engine/auto-trans...air dam"
2011-08-22 440 12.8 34.38 "fuel line magnets...Kiker wires...Autolite plugs...1.3 oz / 10 G MS gas...MS engine/auto-trans...air dam"
2011-09-08 352 10.3 34.17 "fuel line magnets...Kiker wires...Autolite plugs...1.3 oz / 10 G MS gas...MS engine/auto-trans...air dam"
2011-09-27 413 11.8 35 "fuel line magnets...Kiker wires...Autolite plugs...1.3 oz / 10 G MS gas...MS engine/auto-trans...air dam"
2011-10-07 233 6.6 35.3 "fuel line magnets...Kiker wires...Autolite plugs...1.3 oz / 10 G MS gas...MS engine/auto-trans...front pan/upper grill block"
2011-10-20 422 12.4 34.03 "fuel line magnets...Kiker wires...Autolite plugs...1.3 oz / 10 G MS gas...MS engine/auto-trans...front pan/upper grill block...Volo FS2 HHO Ed"
2011-11-08 413 12.4 33.31 "fuel line magnets...Kiker wires...Autolite plugs...3 oz / 10 G Techron/DieselKleen/MysteryOil gas...MS engine/auto-trans...front pan/upper grill block."
2011-11-24 398 12.3 32.36 "fuel line magnets...Kiker wires...Autolite plugs...3 oz / 10 G Techron/DieselKleen/MysteryOil gas...MS engine/auto-trans...front pan/upper grill block."
2011-12-17 456 13.4 34.03 "fuel line magnets...Kiker wires...Autolite plugs...3 oz / 10 G Techron/DieselKleen/MysteryOil gas...MS engine/auto-trans...front pan/upper grill block...radiator 5/8s covered using cardboard.
* 1.6 G added to avoid running out."
2012-01-10 393 12.8 30.7 "fuel line magnets...Kiker wires...Autolite plugs...2 oz / 10 G Techron in gas...MS engine/auto-trans...front pan/upper grill block...radiator 5/8s covered using cardboard."
2012-02-07 360 11.3 31.86 "fuel line magnets...Kiker wires...Autolite plugs...2 oz / 10 G Techron in gas...MS engine/auto-trans...front pan/upper grill block...radiator 5/8s covered using cardboard."
2012-02-20 332 10.5 31.62 "fuel line magnets...Kiker wires...Autolite plugs...2 oz / 10 G Techron in gas...MS engine/auto-trans...front pan/upper grill block...radiator 5/8s covered using cardboard."
2012-03-12 365 11.2 32.59 "fuel line magnets...Kiker wires...Autolite plugs...2 oz / 10 G Techron in gas...MS engine/auto-trans...front pan/upper grill block...radiator 5/8s covered using cardboard."
2012-04-04 390 11.9 32.77 "fuel line magnets...Kiker wires...Autolite plugs...2 oz / 10 G Techron in gas...MS engine/auto-trans...front pan/upper grill block..."
2012-04-30 539 15.5 34.77 "fuel line magnets...Kiker wires...Autolite double-plat plugs...2 oz / 10 G Techron in gas...MS engine/auto-trans...front pan/upper grill block...
* added 5 extra gallons from winter storage"
2012-05-14 420 12.1 34.71 "fuel line magnets...Kiker wires...Autolite double-plat plugs...2 oz / 10 G Techron in gas...MS engine/auto-trans...front pan/upper grill block...Condensator..."
2012-05-31 366 10.8 33.89 "fuel line magnets...Kiker wires...Autolite double-plat plugs...2 oz / 10 G Techron in gas...MS engine/auto-trans...front pan/upper grill block...Condensator..."
2012-06-17 433 11.6 37.33 "fuel line magnets...Kiker wires...Autolite double-plat plugs...2 oz / 10 G Techron in gas...MS engine/auto-trans...front pan/upper grill block...Condensator...cone filter...
*fill not on level?"
2012-07-11 450 11.8 38.14 "fuel line magnets...Kiker wires...Autolite double-plat plugs...2 oz / 10 G Techron in gas...MS engine/auto-trans...front pan/upper grill block...Condensator...cone filter
next tank...2.5W/25 semi-synth oil + LubroMoly additive"
2012-07-29 428 11.7 36.58 "fuel line magnets...Kiker wires...Autolite double-plat plugs...2 oz / 10 G Techron in gas...MS engine/auto-trans...front pan/upper grill block...Condensator...cone filter...LubroMoly additive
* short trips/rain...
* 3 tank avg of 37.35 mpg concludes an A-B test of a cone filter for a 6.7% mpg gain from last summer's ~35 mpg avg."
2012-08-30 414 11.4 36.32 "fuel line magnets...Kiker wires...Autolite double-plat plugs...2 oz / 10 G Techron in gas...MS engine/auto-trans...front pan/upper grill block...Condensator...cone filter...LubroMoly additive
* according to the SG...this tank should have come in ~ 37...possible that the SG is less accurate in calculating mpg for shorter trips with many starts/stops?
For longer runs with some stops...seeing trips at ~ 39-40 mpg....SG info."
2012-09-12 425 11.5 36.96 "fuel line magnets...Kiker wires...Autolite double-plat plugs...2 oz / 10 G Techron in gas...MS engine/auto-trans...front pan/upper grill block...Condensator...cone filter...LubroMoly additive"
2012-09-28 293 8.1 36.17 "fuel line magnets...Kiker wires...Autolite double-plat plugs...2 oz / 10 G Techron in gas...MS engine/auto-trans...front pan/upper grill block...Condensator...cone filter...LubroMoly additive...code A partial..."
2012-10-15 231 6.8 33.97 "fuel line magnets...Kiker wires...Autolite double-plat plugs...MS engine/auto-trans...front pan/upper grill block...Condensator...cone filter...LubroMoly additive...code B..."
2012-10-16 256 6.8 37.65 "fuel line magnets...Kiker wires...Autolite double-plat plugs...MS engine/auto-trans...front pan/upper grill block...Condensator...cone filter...LubroMoly additive...code C...
road trip...injuredanna"
2012-11-06 379 11 34.45 "fuel line magnets...Kiker wires...Autolite double-plat plugs...MS engine/auto-trans...front pan/upper grill block...Condensator...cone filter...LubroMoly additive...code D..."
2012-12-03 400 11.7 34.19 "fuel line magnets...Kiker wires...Autolite double-plat plugs...MS engine/auto-trans...front pan/upper grill block...Condensator...cone filter...LubroMoly additive...code E..."
2012-12-20 351 10.3 34.08 "fuel line magnets...Kiker wires...MotorCraft copper plugs...MS engine/auto-trans...front pan/upper grill block...Condensator...cone filter...LubroMoly additive...code F..."
2013-01-04 317 10.1 31.39 "fuel line magnets...Kiker wires...MotorCraft copper plugs...MS engine/auto-trans...front pan/upper grill block...Condensator...cone filter...LubroMoly additive...code F..."
2013-01-28 374 12.3 30.41 "fuel line magnets...Kiker wires...MotorCraft copper plugs...MS engine/auto-trans...front pan/upper grill block...Condensator...cone filter...LubroMoly additive...code F..."
2013-02-19 369 11.7 31.54 "fuel line magnets...Kiker wires...MotorCraft copper plugs...MS engine/auto-trans...front pan/upper grill block...Condensator...cone filter...LubroMoly additive...code F..."
2013-03-08 384 11.6 33.1 "fuel line magnets...Kiker wires...MotorCraft copper plugs...MS engine/auto-trans...front pan/upper grill block...Condensator...cone filter...LubroMoly additive...code F..."
2013-03-08 425 11.8 36.02 ""
2013-03-31 370 11.5 32.17 "fuel line magnets...Kiker wires...MotorCraft copper plugs...MS engine/auto-trans...front pan/upper grill block...Condensator...cone filter...LubroMoly additive...code F..."
2013-04-13 408 11.7 34.87 "fuel line magnets...Kiker wires...MotorCraft copper plugs...MS engine/auto-trans...front pan/upper grill block...Condensator...cone filter...LubroMoly additive...code F..."
2013-05-11 590 16.7 35.33 "fuel line magnets...Kiker wires...MotorCraft copper plugs...MS engine/auto-trans...front pan/upper grill block...Condensator...cone filter...LubroMoly additive...code F..."
2013-05-27 426 12 35.5 "fuel line magnets...Kiker wires...MotorCraft copper plugs...MS engine/auto-trans...front pan/upper grill block...Condensator...cone filter...LubroMoly additive...code F..."
2013-07-11 420 11.7 35.9 "fuel line magnets...Kiker wires...MotorCraft copper plugs...MS engine/auto-trans...front pan/upper grill block...Condensator...cone filter...LubroMoly additive...code F..."
2013-07-29 398 10.8 36.85 "fuel line magnets...Kiker wires...MotorCraft copper plugs...MS engine/auto-trans...front pan/upper grill block...Condensator...cone filter...LubroMoly additive...Motorsilk fuel additive"
2013-08-14 443 12.8 34.61 "fuel line magnets...Kiker wires...MotorCraft copper plugs...MS engine/auto-trans...front pan/upper grill block...Condensator...cone filter....104 Octane Boost fuel additive"
2013-09-03 425 11.8 36.02 "fuel line magnets...Kiker wires...MotorCraft copper plugs...MS engine/auto-trans...front pan/upper grill block...Condensator...cone filter...LucasUCL"
2013-09-24 399 10.5 38 "fuel line magnets...Kiker wires...MotorCraft copper plugs...MS engine/auto-trans...front pan/upper grill block...Condensator...cone filter....LucasUCL"
2013-09-30 372 10.7 34.77 "fuel line magnets...Kiker wires...MotorCraft copper plugs...MS engine/auto-trans...front pan/upper grill block...Condensator...cone filter....Techron"
2013-10-26 346 9.7 35.67 "fuel line magnets...Kiker wires...MotorCraft copper plugs...MS engine/auto-trans...front pan/upper grill block...Condensator...cone filter....STP Diesel Treatmt"
2013-11-11 380 11.6 32.76 "fuel line magnets...Kiker wires...MotorCraft copper plugs...MS engine/auto-trans...front pan/upper grill block...Condensator...cone filter....STP Diesel Treatmt"
2013-12-18 340 10.7 31.78 "fuel line magnets...Kiker wires...MotorCraft copper plugs...MS engine/auto-trans...front pan/upper grill block...Condensator...cone filter....STP Diesel Treatmt"
2014-01-10 320 10.4 30.77 "fuel line magnets...Kiker wires...MotorCraft copper plugs...MS engine/auto-trans...front pan/upper grill block...Condensator...cone filter....STP Diesel Treatmt
MSDS - http://www.whatsinproducts.com//files/brands_pdf/1338932396.pdf"
2014-01-29 265 9 29.44 "fuel line magnets...Kiker wires...MotorCraft copper plugs...MS engine/auto-trans...front pan/upper grill block...Condensator...cone filter....STP Diesel Treatmt"
2014-02-19 352 11.5 30.61 "fuel line magnets...Kiker wires...MotorCraft copper plugs...MS engine/auto-trans...front pan/upper grill block...Condensator...cone filter....STP Diesel Treatmt"
2014-03-10 387 12.4 31.21 "fuel line magnets...Kiker wires...MotorCraft copper plugs...MS engine/auto-trans...front pan/upper grill block...Condensator...cone filter....STP Diesel Treatmt"
2014-04-02 343 11.9 28.82 "fuel line magnets...Kiker wires...MotorCraft copper plugs...MS engine/auto-trans...front pan/upper grill block...Condensator...cone filter...."
2014-04-21 478 14.6 32.74 "fuel line magnets...Kiker wires...MotorCraft copper plugs...MS engine/auto-trans...front pan/upper grill block...Condensator...cone filter...."
2014-05-03 398 11.6 34.31 "fuel line magnets...Kiker wires...MotorCraft copper plugs...MS engine/auto-trans...front pan/upper grill block...Condensator...cone filter...."
2014-06-09 385 11.8 32.63 "fuel line magnets...Kiker wires...MotorCraft copper plugs...MS engine/auto-trans...front pan/upper grill block...Condensator...cone filter...."
2014-07-03 427 12.8 33.36 "fuel line magnets...Kiker wires...MotorCraft copper plugs...MS engine/auto-trans...front pan/upper grill block...Condensator...cone filter...."
2014-07-17 431 12.5 34.48 "fuel line magnets...Kiker wires...MotorCraft copper plugs...MS engine/auto-trans...front pan/upper grill block...Condensator...cone filter...."
2014-08-14 438 12.3 35.61 "fuel line magnets...Kiker wires...Autolite doubleplat plugs...MotSilk engine/Lubegard auto-trans...front pan/upper grill block...Condensator...cone filter...."
2014-08-22 414 11.9 34.79 "fuel line magnets...Kiker wires...Autolite doubleplat plugs...MotSilk engine/Lubegard auto-trans...front pan/upper grill block...Condensator...cone filter...."
2014-09-08 440 12.1 36.36 "fuel line magnets...Kiker wires...Autolite doubleplat plugs...MotSilk engine/Lubegard auto-trans...front pan/upper grill block...Condensator...cone filter...."
2014-09-25 416 12.3 33.82 "fuel line magnets...Kiker wires...Autolite doubleplat plugs...MotSilk engine/Lubegard auto-trans...front pan/upper grill block...Condensator...cone filter...."
2014-10-30 413 12.1 34.13 "same"
2014-11-19 298 10.1 29.5 "same"
2014-12-09 367 12.3 29.84 "same"
2014-12-29 344 10.6 32.45 "same"
2015-02-06 380 12.6 30.16 "same"
2015-03-15 304 10.6 28.68 "same"
2015-04-03 351 11.4 30.79 "same"
2015-04-17 426 13 32.77 "same"
2015-05-07 416 11.7 35.56 "same"
2015-05-19 339 10.7 31.68 "same...had vac leak which caused to run in open loop"
2015-06-08 410 11.9 34.45 "same"
2015-07-22 307 10.4 29.52 ""
2015-08-08 414 11.5 36 ""
2015-09-03 428 12.6 33.97 ""
2015-10-02 437 13.5 32.37 ""
2015-10-24 426 12.5 34.08 ""
2015-12-10 358 11.5 31.13 ""
2015-12-30 352 12 29.33 ""
2016-01-16 373 11.8 31.61 ""
2016-02-10 324 10.1 32.08 ""
2016-02-28 361 11.1 32.52 ""
2016-04-13 351 11.8 29.75 ""
2016-04-29 423 12.7 33.31 ""
2016-05-12 397 10.8 36.76 ""
2016-05-26 396 12.1 32.73 ""
2016-06-10 407 12.4 32.82 "fictitious...lost receipt"
2016-06-30 422 11.9 35.46 ""
2016-07-21 390 12.5 31.2 ""
2016-08-10 396 12.3 32.2 ""
