2011-04-06 |
200 |
7.49 |
$3.469 |
26.7 |
"First logged fill up. 40psi in tires, used Shell 87 octane." |
2011-04-15 |
294 |
11.49 |
$3.82 |
25.59 |
"shell v power 93 octane" |
2011-04-18 |
398 |
11.71 |
$3.82 |
33.99 |
"Not filled all the way up, pump kept turn off. Tank had some gas left,around 2-3 gals.
Shell V-power 93 octane" |
2011-04-24 |
309 |
16.22 |
$4.129 |
19.05 |
"Shell v power 93" |
2011-05-02 |
395 |
16.67 |
23.7 |
"Discovered misfire a day before, 1 plug was really bad.Fixed. Week before gearbox oil was changed to syntech. Put in Shell 87" |
2011-05-14 |
16.02 |
$4.119 |
24.09 |
"SHELL 89" |
2011-05-23 |
16.42 |
$4.07 |
23.51 |
"Put in Speedway 92 octane, changed oil to low friction with lots of Moly, driving car as usual,more aggressive." |
2011-05-31 |
348 |
15.9 |
$3.75 |
21.89 |
"Put in MMO to tank this fill, Speedway 89. raced with buddy up to 120 mph. So it ate a lot of gas...Will try to drive gently and slow on this tank." |
