2011-05-13 |
149 |
6.712 |
22.2 |
"87 Octane (1st tank)
Cowboys 280
(misfire fixed halfway through tank)" |
2011-05-16 |
274.5 |
8.72 |
$3.669 |
31.48 |
"87 Octane
Cowboys 280
(more highway than city)" |
2011-05-19 |
224.5 |
9.018 |
24.89 |
"87 Octane
Cowboys 280
(only couple miles not for work)" |
2011-05-26 |
293.1 |
10.25 |
$3.609 |
28.6 |
"87 Octane
Cowboys 280
(mainly work miles. couple extra highway trips.
parked Fri-Sun due to electrical issues.)" |
2011-06-01 |
247.7 |
10.6 |
23.37 |
"87 Octane
Chevron 280 at the Summit
(nearly all work miles. parked Sat-Tues for exhaust manifold swap. only 1/8 tank left after repair. ran out of gas end of route, used ? amount from neighbor's can, ""fuel used"" isn't exactly correct.)" |
2011-06-06 |
229.6 |
8.576 |
26.77 |
"87 Octane
Cowboys 280
(nearly all work miles. first full tank after exhaust manifold repair. also, timing changed at 3/4 tank.)" |
2011-06-09 |
194.7 |
6.93 |
28.1 |
"87 Octane
Cowboys 280
[all work miles. shut off car at each apartment stop. P0420 code through full tank.]" |
2011-06-14 |
222.7 |
8.003 |
$3.489 |
27.83 |
"87 Octane
Cowboys 280
[all work miles.]" |
2011-06-17 |
220.9 |
7.782 |
$3.469 |
28.39 |
"87 Octane
Cowboys 280
[mostly work miles. some extra interstate miles.]" |
2011-06-20 |
194.7 |
7.249 |
$3.449 |
26.86 |
"87 Octane
Cowboys 280
[all work miles. extra route, so 20 extra city miles/day.]" |
2011-06-23 |
219.3 |
8.144 |
$3.439 |
26.93 |
"87 Octane
Cowboys 280
[all work miles. CEL still showing, ticking noise still unresolved.]" |
2011-06-27 |
286.9 |
9.868 |
29.07 |
"87 Octane
Chevron Oxmoor/Cobb
[work miles plus trip to Trussville and back, extra highway miles.]" |
2011-07-01 |
279.9 |
9.636 |
29.05 |
"87 Octane
Trussville Hwy 11 Shell
[extra highway miles, less work miles. parked Thur and Fri for transmission fluid leaks at axles. tires rotated after repairs and prior to fill-up. ultra-gauge also installed at fill-up.]" |
2011-07-05 |
310.5 |
9.909 |
31.34 |
"87 Octane - Pump 13
Cowboys 280
[extra interstate miles, 1.5 Trussville trips, 1 Argo trip. less work miles, 2 days on route. some around town. ultra-gauge installed entire tank, though not calibrated for accurate readings. transmission leak fixed.]" |
2011-07-08 |
233.3 |
7.984 |
$3.449 |
29.22 |
Cowboys 280
2011-07-12 |
268.4 |
9.597 |
27.97 |
Cowboys 280
[work miles. also used little during days with family, running A/C.]
Ultra-Gauge trip report:
269.2 Distance (not yet calibrated)
15:29 Run Time
27.6 Avg MPG (not fully calibrated)
17.4 Avg MPH (w/out distance calibrated)" |
2011-07-15 |
287.7 |
10.01 |
28.74 |
"87 Octane - Pump 3
[work miles. 1/2 trip to Trussville. exhaust leak fixed immediately prior to fill-up.]
289.0 Distance (not yet calibrated)
17:11 Run Time
28.3 Avg MPG (not fully calibrated)
16.8 Avg MPH (w/out distance calibrated)" |
2011-07-20 |
282.9 |
9.705 |
29.15 |
"87 Octane - Pump 1
Cowboys 280
[mostly work miles. new route for ~1/2 tank. some random around town mileage.]
284.8 Distance (not yet calibrated)
16:08 Run Time
29.2 Avg MPG (not fully calibrated)
17.6 Avg MPH (w/out distance calibrated)" |
2012-02-04 |
295.1 |
10.053 |
29.35 |
Cowboys 280
[nearly all work miles. Single route all but one day, extra route did lower FE].
294.6 Distance (not calibrated)
12:20 Run Time
23.9 Avg MPH (w/out distance calibrated)" |
2012-02-09 |
284.6 |
9.527 |
29.87 |
Cowboys 280
[all work miles, except one extra trip down 280 to borrow truck. New front wheel bearings 3 tanks ago.]
283.6
11:35
29.8
24.4" |
2012-02-13 |
266.2 |
9.732 |
27.35 |
Cowboys 280
[work miles. Around town miles. Extra route one day.]
Ultra-Gauge Trip Report:
265.8
12:01
27.1
22.1" |
2012-02-22 |
310.2 |
10.452 |
$3.439 |
29.68 |
"87 Octane - Pump 9
Cowboys 280
[work miles, extra route two days. Some extra highway miles. ""New"" tires.]
UG report:
308.9
12:19
30.0
25.1" |
