2012-03-29 |
459.19 |
10.33 |
$1.149 |
44.45 |
"new car driving way too nice as I get familiar
222xxxkms" |
2012-04-04 |
576.01 |
13.61 |
$1.149 |
42.32 |
2012-04-11 |
471.93 |
11.69 |
$1.139 |
40.37 |
"getting a feel for the turbo . boost is good" |
2012-04-17 |
546.31 |
13.35 |
$1.149 |
40.92 |
"oil change 225000kms w/flush" |
2012-04-23 |
558.24 |
$1.118 |
41.97 |
"used car as a pick up truck for a couple days. hauled a 383 big block dodge to machine shop and back" |
2012-04-27 |
549.29 |
13.51 |
$1.103 |
40.66 |
"near constant limp mode ,part ordered
228xxxkms" |
2012-05-04 |
542.83 |
12.99 |
$1.108 |
41.79 |
"limp mode . lots of passing ." |
2012-05-10 |
566.13 |
13.42 |
$1.108 |
42.19 |
"still in limp mode.... have new n 75 valve...just need time to install ." |
2012-05-15 |
562.09 |
13.32 |
$1.076 |
42.2 |
"installed new boost control valve (n75) no more limp mode....boost is what makes little diesels fun" |
2012-05-29 |
544.07 |
12.64 |
$1.05 |
43.04 |
"Amsoil engine flush , Motul oil change at 231,000km new wipers , and a bad fuel issue(never trust unknown fuel) new fuel filter . all prior to this fuel cycle .
This tank 3000-4000 rpm shifts half the time . 80%hwy 20%city" |
2012-06-05 |
553.64 |
12.55 |
$1.04 |
44.11 |
"normal , 80%hwy 20% city , mid to hi rpm shifts , l/r whl brg and stub axle need replacement ." |
2012-06-14 |
559.98 |
12.88 |
$1.024 |
43.48 |
"well it is always interesting in used vehicle territory. oil press sender leaked enough to cause low oil pressure and coat the engine bay and undercarrige in new motul synth oil and force me to call for spare oil to make the last few KM's to work . plug until replacement sender sourced , quick drain and fill napa 5w30 , new sender..... seems o.k so far . parts arrived for rear wheel brg issues , milage recorded plus 10kms that accrewed prior to trip meter reset . 891.2/901.2km , hauled 350ci v8 block plus few pounds of equip. from Princess auto" |
2012-06-20 |
613.17 |
14.34 |
$1.019 |
42.76 |
"No break downs lots of rain and wind , every 2nd or 3rd day . mid to hi RPM shifting , mostly hwy KMs . much more stable with whl brg repair . still needs handiling upgrades . always carrying 10lbs lunch bag/crap collector and 20-30lbs in the trunk (preparedness kit/fluids) still running conventional oil" |
2012-06-25 |
563.96 |
12.48 |
$0.9922 |
45.19 |
"No issues , no change in driving pattern , little less passing , better weather foggy am's occasional light rain" |
2012-07-03 |
548.42 |
12.26 |
$0.9817 |
44.73 |
"No change in driving pattern or route , decent weather some strong winds . no c.e.l. or breakdowns" |
2012-07-11 |
732.22 |
16.48 |
$1.02 |
44.43 |
"no change in driving style or route , good weather cond . motul 5w40 oil change at 238,000kms" |
2012-07-17 |
565.01 |
12.92 |
$0.998 |
43.73 |
"No change in driving pattern or style . lots of passing 80%hwy 20%city mostly decent weather . small rust repair /roof rock chip" |
2012-07-23 |
539.35 |
12.22 |
$1.018 |
44.14 |
"no change in driving pattern or style . good weather normal amount of passing ." |
2012-07-27 |
542.08 |
12.34 |
$1.029 |
43.93 |
"no change in driving pattern or route . some strong winds ." |
2012-08-01 |
681.21 |
14.69 |
$1.085 |
46.37 |
"road trip to edm. for Iron Maiden....lots of hyw good weather . still pulling lots of rpms when rowing gears . just under 1100km this tank . 55.6L to fill from on fumes..." |
2012-08-08 |
604.47 |
13.88 |
$0.779 |
43.55 |
"no change in driving style or conditions , decent weather most of the time , some rain and high winds . cheap fuel at superstore when you buy a bunch of groceries ." |
2012-08-15 |
965.98 |
22.91 |
$1.15 |
42.16 |
"cheap fuel with coupon from super store/saved $0.25/l filled tank and 2 20l jerry cans . /also 46l of husky diesel for total tank/kms , same driving patterns ." |
2012-08-21 |
672.32 |
15.09 |
$1.155 |
44.55 |
"another edm. trip , to see Metallica.....wahoo.
good weather , fully loaded for trip 4 people, trunk half full . no change in driving style . tires checked and fully inflated , all fluids checked . 245000kms approx. 750kms from husky red deer , home to edm back to sundre and home again . all for heavy metal" |
2012-08-27 |
540.03 |
12.76 |
$1.16 |
42.32 |
"Back on Husky fuel , good weather ,average amount of passing , try to keep it under 120kms/h when cruising no change in driving pattern or route ." |
2012-08-31 |
566.38 |
13.18 |
$1.154 |
42.97 |
"no change in driving pattern , or route , good weather n75 boost control valve starting to act up again , intermitantly , so far approx 247,000kms topped up engine oil approx 1L" |
2012-09-06 |
518.97 |
12.35 |
$1.16 |
42.02 |
"no change in driving style or route" |
2012-09-11 |
644.73 |
14.33 |
$1.151 |
44.99 |
"trip to high river and back to get new diesel sub . no change in driving style ." |
2012-09-18 |
694.01 |
16.07 |
$1.148 |
43.19 |
"no change in route or driving style . occasional dtc 1550 , likely n75 valve/limp mode" |
2012-09-24 |
544.26 |
12.87 |
$1.13 |
42.29 |
"no change in route or driving style , intermittent limp mode. oil change at 251000km , motul 501000 5w30" |
2012-09-28 |
551.4 |
12.83 |
$1.13 |
42.98 |
"No change in driving style or route . intermittent limp mode , p1550 ." |
2012-10-04 |
561.28 |
13.69 |
$1.139 |
41 |
"no changes route or style , fall weather , new fuel treatment klean-flo? (1 L Freebie)-- fuel from superstore (not mohawk/husky) . more of dtc p1550" |
2012-10-11 |
542.52 |
13.87 |
$1.139 |
39.11 |
"filled with shell diesel today , last tankfull lost a mpg or 2 , slightly colder , new fuel treatment and more limp mode from dtc p1550 . no route or pattern changes" |
2012-10-18 |
530.78 |
13.1 |
40.52 |
"finished the tank of shell fuel , limp mode near constant . weather reasonable . no change in route or pattern. back to husky fuel" |
2012-10-30 |
526.6 |
13.8 |
$1.139 |
38.16 |
"limp mode, cold fall/winter weather -5to -10c" |
2012-11-05 |
561.19 |
14.01 |
$1.116 |
40.06 |
"constant limp mode . transported another bigblock ..." |
2013-01-03 |
568.52 |
15.24 |
$1.167 |
37.3 |
"261,000kms first full tank after replacing timing belt and related. new water pump as well , decoked intake . 80%highway cold -15 to -20ish celcius . some snow days. 3 % tire size correction factor 195 70 14 winter tires ." |
2013-01-09 |
537.16 |
13.43 |
$1.129 |
40 |
"2nd full tank since timing belt/boost leak issue. synth oil change at 265,000kms rotella t6 5w40. 80% highway , dry roads , -10 to -20 c . intermitant stalling , check and clean grounds ." |
2013-01-21 |
576.91 |
13.76 |
$1.129 |
41.93 |
2013-02-05 |
589.9 |
14.41 |
$1.174 |
40.94 |
"no change in pattern or style , mild seasonal weather" |
2013-02-22 |
529.1 |
12.88 |
$1.22 |
41.08 |
"no change on driving style or route" |
2013-02-28 |
539.29 |
12.85 |
$1.22 |
41.97 |
2013-03-10 |
534.73 |
12.94 |
$1.21 |
41.32 |
"no change in driving style or route ." |
2013-03-15 |
542.92 |
13.29 |
$1.182 |
40.85 |
"no changes seasonally moderate weather" |
2013-03-21 |
543.69 |
13.55 |
$1.16 |
40.12 |
"no changes mild weather ." |
2013-03-27 |
539.72 |
12.89 |
$1.209 |
41.87 |
"no changes mild weather" |
2013-05-04 |
577.51 |
13.67 |
$1.179 |
42.25 |
"No change in route or driving style , decent weather" |
2013-05-29 |
593.64 |
12.86 |
$1.179 |
46.16 |
"277,792kms back on the road just after crank gear replacement. taller profile summer tires/cheepo chineese tires. mileage numbers modified for 6% increase in distance. mild driving at first , normal driving after first week. no driveability issues . decent spring weather , fuel from superstore" |
2013-06-07 |
557.02 |
13.5 |
$1.179 |
41.26 |
"driving more spirited , car working good , some rain and wind . super store fuel , 70%hiway/30%city" |
2013-06-14 |
565.39 |
12.86 |
$1.139 |
43.97 |
"no change in driving pattern or style more wind and rain than previous week , fuel from superstore , using additive at every fill past and future" |
2013-06-20 |
573.03 |
13.34 |
$1.139 |
42.96 |
"no change in route or style , rainy and windy , superstore fuel ." |
2013-06-26 |
548.13 |
12.66 |
$1.139 |
43.3 |
"no change in route or driving style . filled w/shell fuel" |
2013-07-04 |
421.15 |
9.65 |
$1.139 |
43.64 |
"same as prev. w/some road construction multiple days on commute ." |
2013-07-10 |
625.97 |
14.38 |
$1.139 |
43.53 |
"some gravel road at hwy speeds to avoid road construction otherwise same route and style" |
2013-07-22 |
574.89 |
12.86 |
$1.139 |
44.7 |
"some gravel roads , good weather , 80 hwy 20 city. superstore fuel , w additive/Gaurdex 1oz" |
2013-07-25 |
592.73 |
13.17 |
$1.149 |
45.01 |
"No change in route/good weather some high crosswind days , mid/high rpm shifts as per usual 80%hwy 20 % cty always have additional weight(lunch, comp, spare fluids and parts) from 30-100lbs ocassionaly more (big block chevies/dodges,in pieces" |
2013-08-07 |
582.12 |
13.42 |
$1.139 |
43.38 |
"no change." |
2013-08-13 |
552.87 |
11.1 |
$1.139 |
49.81 |
"no change except for standyne diesel additive" |
2013-08-26 |
1204.09 |
27.43 |
$1.149 |
43.9 |
"no change in route or driving style , standyne diesel fuel add. full tank plus 2 jerrycans all super store fuel" |
2013-08-30 |
525.87 |
11.62 |
$1.129 |
45.26 |
"no change / standyne" |
2013-09-02 |
538.06 |
12.16 |
$1.179 |
44.25 |
"no change" |
2013-09-10 |
845.97 |
18.29 |
$1.159 |
46.25 |
"no change . standyne" |
2013-09-17 |
534.17 |
11.69 |
$1.179 |
45.69 |
"no change" |
2013-09-28 |
646.93 |
14.52 |
$1.179 |
44.55 |
"No change in route or driving cond." |
2013-10-08 |
617.16 |
14.2 |
$1.169 |
43.46 |
"no change , back to lube gaurd" |
2013-10-10 |
530.28 |
12.58 |
$1.179 |
42.15 |
"no change , lube gaurd (gaurdex?)" |
2015-04-01 |
489.08 |
10.75 |
$0.959 |
45.5 |
"same route mild weather . some snow" |
2015-04-06 |
507.35 |
11.88 |
$0.979 |
42.71 |
"same route and style , mild to warm , wind" |
2015-04-10 |
472.18 |
11.57 |
$0.959 |
40.81 |
"same route and driving style, warmish some wind" |
2015-04-16 |
508.47 |
11.81 |
$0.919 |
43.05 |
"spring time warm weather , with addatives" |
2015-04-21 |
553.77 |
12.36 |
$0.919 |
44.8 |
"same route and driving style , 3rd superstore fillup with adative . flat tire on the ride home today." |
2015-04-27 |
488.4 |
12.06 |
$0.919 |
40.5 |
"mild weather good driving conditions same route and driving style" |
2015-05-01 |
500.76 |
11.9 |
$0.999 |
42.08 |
"same route and driving style, filled at shell drove to calgary picked up and installed new tires ,
bridgestone potenza 195 60r14" |
2015-05-05 |
469.45 |
11.02 |
$0.959 |
42.6 |
"superstore fillup , new tires , fairly agressive driving , rowing gears , 115kms /h same route same style" |
