2012-05-30 250 3.73 $3.33 67.02 "My first tank trying some semi advanced hyper miling techniques. Crouching, slower speeds on freeway, more coasting to stop and shutting off engine. this tank was not fun however."
2012-06-11 256 3.93 $3.34 65.14 ""
2012-06-21 280 4.08 $3.33 68.63 "Think I'm getting better at this. I am having more fun on the bike. Keeping up realistic speeds but using the clutch and kill switch more efficiently."
2012-06-25 238 3.5 $3.33 68 "Rode 2 up a bit. Also trying to teach GF to ride my bike."
2012-07-06 259.5 3.672 $3.36 70.67 "Found the last few tanks I was running on a little over 15psi on both tires. Put them up to 45+"
2012-07-10 246 3.65 $3.33 67.4 "Did quite a bit of offroading on this tank"
2012-07-16 266 4.19 $3.31 63.48 "Rode about 120 miles with girlfriend on back at almost 80 the whole time. Also did about 30 miles ballsout because I was in a big hurry and did some offroading. All this and still got well over EPA by coasting and shutting off as much as possible."
2012-07-20 252.49 3.439 $3.379 73.42 "Would have done better but rode for 40 minutes in a downpour and had to surge the motor to keep it going while it popped and sputtered @ 60 mph."
2012-07-27 280.2 4.084 $3.549 68.61 "Some offroad and hard riding."
2012-08-03 286 4.107 $3.699 69.64 "Bit of offroading on this tank."
2012-08-20 259 3.921 $3.699 66.05 ""
2012-08-27 292.4 4.383 $3.699 66.71 ""
2012-09-03 286.6 4.049 $3.899 70.78 ""
2012-09-07 256.9 3.69 $3.799 69.62 ""
2012-09-14 245.4 3.817 $3.899 64.29 ""
2012-09-14 164.8 2.543 $3.919 64.81 ""
2012-09-15 244.5 3.642 $3.999 67.13 ""
2012-09-15 265.2 4.005 $3.899 66.22 ""
2012-09-17 223.4 4.74 $3.899 47.13 "Almost this whole tank was spent doing 80-85"
2012-09-27 269.6 3.923 $3.779 68.72 ""
2012-10-21 258 3.983 $3.599 64.78 ""
2012-11-09 247.6 3.925 $3.399 63.08 ""
2012-11-15 271.8 4.218 $3.499 64.44 ""
2012-12-01 266.1 4.621 $3.479 57.58 ""
2013-04-17 272 4.373 $3.549 62.2 ""
2013-04-23 218.9 3.298 $3.519 66.37 ""
2013-05-04 274.4 4.174 $3.79 65.74 ""
2013-05-14 252.2 4.064 $3.699 62.06 ""
2013-06-02 260.2 4.189 $3.679 62.12 ""
2013-06-12 260.3 4.073 $3.969 63.91 "Found bike on its side after several hours so a bit of gas leaked from the tank."
2013-06-18 254.2 3.69 $3.7 68.89 ""
2013-07-08 256.7 4.346 $3.459 59.07 ""
2013-07-15 288.2 4.632 $3.699 62.22 ""
2013-07-19 257.9 3.851 $3.659 66.97 ""
2013-07-25 253.2 3.751 $3.729 67.5 ""
2013-07-29 262.7 3.974 $3.529 66.1 ""
2013-08-05 242.9 3.784 $3.599 64.19 ""
2013-08-10 271.6 4.001 $3.499 67.88 ""
2013-08-17 251 4.049 $3.429 61.99 ""
2013-08-17 297.5 4.53 $3.719 65.67 ""
2013-08-19 290.1 4.55 $1.38 63.76 ""
2013-08-20 272.7 4.76 $1.394 57.29 ""
2013-08-21 253.4 4.48 $1.355 56.56 ""
2013-08-21 220.8 3.83 $1.394 57.65 ""
2013-08-22 265.3 4.4 $3.679 60.3 ""
2013-08-23 284.5 4.749 $3.659 59.91 ""
2013-08-24 304.3 5.03 $3.379 60.5 ""
2013-08-24 261.6 4.418 $3.799 59.21 "Loaded with gear. Mixed terrain(freeway/city/dirt trails) and a screwed up chain/ sprocket
as were the last tanks through 8/17."
2013-09-06 280.6 5.09 $3.659 55.13 "Replaced worn chain and sprockets 80 miles in"
2013-09-15 249.1 4.59 $3.499 54.27 ""
2013-09-23 290.4 4.899 $3.599 59.28 ""
2013-10-02 255.1 3.838 $3.399 66.47 ""
2014-04-25 255.3 4.739 $3.799 53.87 "Tank from last fall. sat over winter."
2014-05-12 289.6 4.337 $3.689 66.77 ""
2014-05-18 284.5 4.456 $3.759 63.85 ""
2014-05-27 267.6 4.253 $3.66 62.92 ""
2014-06-03 257 3.959 $3.899 64.92 ""
2014-06-10 263.4 3.896 $3.769 67.61 ""
2014-06-18 278.2 4.251 $3.709 65.44 "Good amount of off roading including getting stuck numerous times and revving the crap out of it, laying it on its side with fuel leaking out etc."
2014-07-01 299.7 4.686 $3.769 63.96 ""
2014-07-10 271.9 4.214 $3.569 64.52 ""
2014-07-20 214 3.356 $3.399 63.77 ""
2014-07-20 211.8 2.936 $3.699 72.14 ""
2014-07-24 248.4 4.179 $3.499 59.44 ""
2014-08-03 309.4 4.723 $3.239 65.51 ""
2014-08-08 260.2 4.045 $3.36 64.33 ""
2014-08-19 262.3 3.951 $3.369 66.39 ""
2014-08-31 298.1 4.576 $3.699 65.14 ""
2014-09-09 299.8 4.665 $3.469 64.27 ""
2014-09-18 297.3 4.603 $3.299 64.59 ""
2014-09-25 275.5 4.369 $3.369 63.06 ""
2014-10-13 264.6 4.343 $3.269 60.93 ""
2014-10-16 308.6 4.825 $3.159 63.96 ""
2014-10-23 284 4.93 $2.96 57.61 ""
2014-11-04 274.4 4.481 $2.96 61.24 ""
2014-11-30 282 4.837 $2.649 58.3 ""
2015-03-13 202.1 3.976 $2.239 50.83 "12/24/14 did some heavy off roading, dumped it several times (gas spillage, then parked it for a few months for the winter."
2015-04-12 271.7 4.219 $2.249 64.4 ""
2015-05-07 266.5 4.813 $2.549 55.37 "Adjusted the valves. Exh. was .005 under min. int. was at low end of mean. Both are now at high end.
Adjusted exh cam timing 1 tooth.
Drove this tank a little spirited because of new found power. need to log total mileage."
2015-05-24 151.1 2.417 $2.729 62.52 ""
2015-06-02 292.7 4.792 $2.779 61.08 ""
2015-07-14 262.6 5.104 $2.57 51.45 "Trip computer was malfunctioning and cut off quite a few miles in the beginning. Should be better mileage."
2015-07-27 250.8 3.786 $2.369 66.24 ""
2015-08-10 284.4 4.576 $2.299 62.15 ""
2015-08-15 284.3 4.755 $2.799 59.79 ""
2015-09-15 274.1 4.099 $2.159 66.87 "Did a bit of offroading,"
2015-10-06 303.6 4.787 $2.199 63.42 ""
2015-11-02 297.1 4.782 $1.999 62.13 ""
2015-12-01 278.1 4.78 $1.739 58.18 ""
2015-12-26 244.6 4.09 $1.799 59.8 ""
2016-02-22 220.6 4.23 $1.59 52.15 "High speed highway and some offroad."
2016-02-22 256 4.741 $1.599 54 "Sitting for a while during winter and high speed highway. (70+)"
2016-05-09 267 4.931 $2.199 54.15 ""
2016-05-31 257.8 3.992 $2.559 64.58 "Dumped bike and probably spilled some fuel. Besides that, average riding."
2016-06-30 287.2 4.758 $2.199 60.36 ""
2016-08-11 296.2 5.078 $1.829 58.33 ""
2016-09-06 324.3 4.984 $2.099 65.07 ""
2016-10-01 267 4.507 $1.999 59.24 ""
2016-10-03 240.3 4.93 $2.099 48.74 "Most this tank was spent doing about 76 mph"
2016-11-17 291.4 5.445 $1.919 53.52 ""
2017-04-10 273.6 4.978 $2.17 54.96 "Same tank sitting all winter"
2017-05-15 231.4 5.029 $2.499 46.01 "Almost all freeway ~75mph Several above tanks were mixed freeway and spirited mountain driving."
2017-05-15 182.2 3.483 $2.49 52.31 ""
2017-05-15 214.9 4.279 $2.399 50.22 ""
2017-05-15 247.5 4.516 $2.279 54.81 ""
2017-05-15 221.3 4.7 $2.09 47.09 ""
2017-05-30 215.9 4.942 $2.199 43.69 ""
2017-06-22 292 4.819 $2.099 60.59 ""
2017-08-01 279 4.968 $2.29 56.16 ""
2017-08-14 268.6 4.408 $2.219 60.93 ""
2017-08-21 271.6 4.651 $2.599 58.4 ""
2017-09-05 306.4 5.136 $2.529 59.66 ""
2017-10-17 236.4 4.883 $2.139 48.41 ""
2018-05-17 251.5 4.833 $2.629 52.04 ""
2018-05-29 292.3 5.035 $2.85 58.05 ""
2018-07-09 278.1 5.086 $2.959 54.68 ""
2018-08-06 285.9 4.824 $2.629 59.27 ""
2018-08-06 231.1 3.848 $2.719 60.06 ""
2018-08-16 280.5 4.738 $2.759 59.2 ""
2018-08-30 249.7 4.265 $2.699 58.55 ""
2018-09-13 255.8 4.743 $2.599 53.93 ""
2018-11-12 287.1 4.755 $2.429 60.38 ""
2019-01-04 289.4 5.207 $1.819 55.58 ""
2019-05-07 257.1 4.765 $2.579 53.96 ""
2019-05-28 284.7 5.086 $2.499 55.98 ""
2019-07-01 265.4 4.374 $2.369 60.68 ""
2019-07-29 277.8 4.814 $2.739 57.71 ""
2019-07-30 245.6 5.859 $2.649 41.92 "A lot of high speed freeway."
2019-08-27 268.6 5.0126 $2.559 53.58 ""
2019-09-03 258.6 4.943 $2.299 52.32 "More high speed freeway"
2019-10-01 251.8 5.113 $2.749 49.25 ""
2020-04-06 205.6 4.113 $1.299 49.99 ""
2020-05-26 413 8.459 $1.999 48.82 "Added ~4 gal from can. Lots of spirited riding, offroad and high speed highway."
