2013-06-09 |
473 |
13.97 |
33.86 |
"W. conv" |
2013-06-23 |
476.8 |
14.088 |
33.84 |
"W. conv" |
2013-07-11 |
402.9 |
17.168 |
23.47 |
"Valero, oil change" |
2013-07-27 |
586 |
13.554 |
$3.689 |
43.23 |
"Replaced fuel line, + shut off valve" |
2013-08-09 |
13.689 |
$3.689 |
29.59 |
"W conv, rear seat pad replaced" |
2013-08-18 |
383.6 |
16.779 |
22.86 |
"Cornerstore, front seat pad replaced" |
2013-08-28 |
420.4 |
13.848 |
30.36 |
"Safeway GM, motor mount & AC repaired" |
2013-09-10 |
424.9 |
15.219 |
$3.669 |
27.92 |
"Ksooper @ HR, rear headrest" |
2013-09-30 |
434.5 |
15.724 |
$3.669 |
27.63 |
"Ksooper@aurora" |
2013-10-11 |
428.1 |
16.576 |
25.83 |
"Ksooper- aurora" |
2013-10-26 |
464.3 |
13.854 |
$3.609 |
33.51 |
"W.conv, part fill" |
2013-11-01 |
379.5 |
16.641 |
22.81 |
"L&j" |
2013-11-20 |
444.4 |
16.455 |
$3.539 |
27.01 |
"Corner store" |
2013-12-01 |
459.9 |
16.27 |
28.27 |
"Safeway-centennial, Oil change" |
2013-12-28 |
453.9 |
16.046 |
28.29 |
"L&j, bilsteins" |
2014-01-25 |
328.9 |
13.121 |
25.07 |
"Antenna switch & wiring, Safeway" |
2014-02-15 |
443.8 |
18.328 |
$3.57 |
24.21 |
"Fanfare horn, my mart, over filled" |
2014-03-15 |
518.4 |
17.518 |
29.59 |
"Replaced Battery tray & mat, Valero" |
2014-03-27 |
495.7 |
16.91 |
$3.719 |
29.31 |
"Amber fog caps, corner store" |
2014-04-15 |
423.5 |
16.288 |
$3.73 |
26 |
"Replaced cruise control cable, fuse box fuse cap, added 4 fuel line clips & dash cap- my mart" |
2014-04-21 |
495.7 |
16.868 |
$3.719 |
29.39 |
"1/2 highway miles, replaced master brake cylinder, passenger pull lever, power window plate- corner store" |
2014-05-08 |
470.9 |
16.574 |
$3.709 |
28.41 |
"Replaced master brake cylinder, washer pump, re-solder glow plug wire, l&j" |
2014-05-27 |
463.8 |
17.188 |
26.98 |
"Replaced radio, front speaker, Corner store wads" |
2014-06-15 |
396.6 |
16.289 |
$3.669 |
24.35 |
"Replaced rear speaker, l&j" |
2014-07-07 |
485.2 |
16.141 |
$3.61 |
30.06 |
"Repaired odometer, l&j" |
2014-08-07 |
456.8 |
15.737 |
29.03 |
"Flying j" |
2014-08-17 |
462.9 |
17.636 |
26.25 |
"Gas express" |
2014-08-31 |
475.9 |
16.683 |
28.53 |
"King sooper" |
2014-09-17 |
478 |
17.056 |
28.03 |
"Repaired master vac lock & rr lock actuator, mitigated rl fender rust, l&j" |
2014-09-28 |
444.2 |
16.428 |
27.04 |
"Coalmine gas" |
2014-10-10 |
475.1 |
17.022 |
$3.43 |
27.91 |
"Jewel gas express" |
2014-10-21 |
466.2 |
17.078 |
27.3 |
"Coalmine gas express" |
2014-10-29 |
451.3 |
14.376 |
$3.389 |
31.39 |
"L&j, full tank?" |
2014-11-08 |
414.9 |
15.65 |
$3.469 |
26.51 |
"Corner store" |
2014-11-26 |
385.3 |
13.449 |
$3.539 |
28.65 |
"My mart, diesel additive" |
2014-12-10 |
383.5 |
15.152 |
25.31 |
"Oil change, lnj" |
2014-12-16 |
428.3 |
16.194 |
26.45 |
2015-01-11 |
461.2 |
17.451 |
26.43 |
"My mart" |
2015-01-19 |
464.4 |
14.848 |
31.28 |
"L&j, rotate tires" |
2015-02-01 |
442.2 |
15.877 |
27.85 |
"Al wheels + michelin, icon blades, & Jewell gas" |
2015-07-05 |
475.1 |
17.466 |
$2.529 |
27.2 |
"Replaced water pump, t-stat, air filter & valve adj, my mart" |
2015-07-25 |
511.1 |
15.88 |
32.19 |
"Replaced OAT display, driver cowl vent grill, K sooper" |
2015-08-10 |
506.8 |
15.657 |
32.37 |
"Replaced fanfare horns, unlevel surface, gas express" |
2015-08-18 |
441.4 |
16.677 |
26.47 |
"Castle Rock W. Conv." |
2015-08-29 |
460.8 |
16.445 |
28.02 |
"K soopers" |
2015-09-12 |
358.9 |
13.218 |
$2.239 |
27.15 |
"Oil & brake fluid change, bow mar gas" |
2015-09-29 |
508.9 |
16.013 |
$2.159 |
31.78 |
"Replaced #1 glow plug & dash bulb, 2nd valve gasket, k sooper sun valley" |
2015-10-13 |
424.6 |
15.374 |
$2.139 |
27.62 |
"Replaced exhaust system, k sooper" |
2015-10-25 |
452.2 |
16.506 |
$2.069 |
27.4 |
"K sooper- bellview" |
2015-11-06 |
439.6 |
15.658 |
28.08 |
"Corner store- hampden" |
2015-12-04 |
414.2 |
16.244 |
$2.059 |
25.5 |
"K sooper, kipling" |
2015-12-21 |
455.5 |
16.587 |
$1.799 |
27.46 |
"K sooper, Kipling" |
2016-01-11 |
444.5 |
15.742 |
$1.839 |
28.24 |
"Bow mar" |
2016-01-19 |
437.4 |
15.782 |
$1.739 |
27.72 |
"Bow mar gas" |
2016-02-17 |
451.9 |
16.74 |
$1.539 |
27 |
"Aur corner store" |
2016-05-05 |
477.2 |
16.855 |
$2.039 |
28.31 |
"D purge, fuel filter & oil change, tire rotate, replace radio, coalmine gas" |
2016-05-27 |
478.7 |
17 |
$2.059 |
28.16 |
"Bleed brake lines, iPod aux, replaced left front speaker, l&j" |
2016-07-05 |
491.7 |
16.661 |
$1.899 |
29.51 |
"Dashmat, k sooper" |
2016-08-05 |
484 |
16.486 |
$1.919 |
29.36 |
"Rear left fender rust mitigation, k sooper" |
2016-08-25 |
427.8 |
15.911 |
26.89 |
"K sooper- Sheridan" |
2016-09-04 |
446.7 |
16.721 |
$2.059 |
26.71 |
"K sooper" |
2016-09-19 |
430.7 |
16.269 |
$1.879 |
26.47 |
2016-10-02 |
444.3 |
16.069 |
$1.899 |
27.65 |
"K sooper- kipling" |
2016-10-17 |
437.7 |
16.663 |
$2.159 |
26.27 |
"K sooper- jellison" |
2016-10-17 |
437.7 |
16.663 |
$2.159 |
26.27 |
2016-10-28 |
429 |
15.574 |
$2.089 |
27.55 |
"L&j s Union" |
2016-11-15 |
401.3 |
16.421 |
24.44 |
"Air filter, clean fuel sender, l&j" |
2016-12-02 |
427 |
16.572 |
$2.149 |
25.77 |
"Oil change, tire rotation, circle k- Kipling" |
2017-01-01 |
442.5 |
17.013 |
$2.059 |
26.01 |
"L&j k sooper" |
2017-01-25 |
433.8 |
16.389 |
26.47 |
"L&j k sooper" |
2017-02-09 |
432.6 |
15.725 |
$2.249 |
27.51 |
"Intake manifold replaced, l&j k sooper" |
2017-02-22 |
435 |
16.304 |
26.68 |
"Thermostat wire solder, brake fluid replaced, l&j" |
2017-03-09 |
409.2 |
15.347 |
$2.249 |
26.66 |
"L&j" |
2017-03-16 |
384.2 |
14.179 |
$2.229 |
27.1 |
"Dash light repair, l&j" |
2017-03-30 |
427.8 |
15.888 |
26.93 |
"L&j k sooper" |
2017-04-09 |
422 |
15.522 |
$2.369 |
27.19 |
"L&j k sooper" |
2017-04-16 |
431.3 |
15.699 |
$2.239 |
27.47 |
"Differential oil change, Conoco- kipling" |
2017-04-27 |
441.8 |
16.315 |
$2.229 |
27.08 |
"Replaced trunk weatherstrip, k sooper-Kipling" |
2017-05-12 |
429.9 |
16.497 |
$2.249 |
26.06 |
"L&j-Kipling" |
2017-05-28 |
441.9 |
15.97 |
$2.329 |
27.67 |
"Oil, differential & transmission fluid service, valve adj, tire rotation, k Sooper- Sheridan." |
2017-06-08 |
446.3 |
15.567 |
28.67 |
"K sooper L&j" |
2017-06-20 |
434 |
15.271 |
$2.269 |
28.42 |
"FR & RL dual diaphragm door actuator replaced, K Sooper Kipling" |
2017-07-05 |
456.5 |
15.806 |
28.88 |
"Brake fluid change, k sooper" |
2017-07-20 |
460.1 |
15.168 |
30.33 |
"K Sooper- kipling" |
2017-08-02 |
458.8 |
16.548 |
$1.899 |
27.73 |
2017-08-16 |
445.4 |
15.788 |
28.21 |
"Corner store-Kipling" |
2017-08-25 |
422.1 |
14.629 |
28.85 |
"K sooper- Kipling" |
2017-09-04 |
459.3 |
16.375 |
$2.519 |
28.05 |
2017-09-14 |
458.8 |
15.408 |
29.78 |
"K. Sooper, Kipling" |
2017-09-28 |
442 |
16.133 |
27.4 |
2017-10-07 |
456.7 |
16.71 |
$2.509 |
27.33 |
"Oil change, tire rotation, k sooper" |
2017-10-19 |
431.7 |
16.619 |
25.98 |
"Coalmine gas" |
2017-10-29 |
432.6 |
16.295 |
$2.569 |
26.55 |
"Lowell- slope fill up" |
2017-11-15 |
464.7 |
15.947 |
$2.729 |
29.14 |
"K sooper, Jellison" |
2017-11-30 |
418.6 |
16.108 |
25.99 |
"K sooper, Sheridan" |
2017-12-10 |
432.3 |
15.899 |
$2.529 |
27.19 |
"K Sooper- Kipling" |
2017-12-31 |
438.5 |
17.009 |
25.78 |
"K sooper- Hampton" |
2018-01-11 |
449 |
15.552 |
28.87 |
"K sooper- Parker" |
2018-01-31 |
431.8 |
16.588 |
$2.789 |
26.03 |
"Shell- Arapahoe" |
2018-02-27 |
438 |
17.155 |
$2.519 |
25.53 |
"K sooper, Federal" |
2018-03-25 |
439.3 |
15.494 |
$2.519 |
28.35 |
"K Sooper- Bellview" |
2018-04-15 |
459.5 |
16.479 |
27.88 |
"Air filter, K sooper Bellview" |
2018-05-31 |
414.5 |
14.674 |
$2.869 |
28.25 |
"Oil change, diesel purge, fuel filters, skid plate, power antenna, K sooper- Bellview" |
2018-06-25 |
443.9 |
16.384 |
$2.969 |
27.09 |
"K sooper" |
2018-07-23 |
436.1 |
15.702 |
27.77 |
"K sooper" |
2018-08-12 |
412.7 |
15.084 |
$2.729 |
27.36 |
"K sooper" |
2018-08-25 |
479.3 |
16.534 |
28.99 |
"K sooper" |
2018-09-05 |
450.8 |
16.239 |
$3.039 |
27.76 |
"Shell- Santa Fe" |
2018-09-21 |
452.1 |
16.298 |
27.74 |
"K sooper" |
2019-05-31 |
407.7 |
13.997 |
29.13 |
"K sooper" |
2019-12-26 |
430.8 |
16.643 |
25.88 |
"K sooner, Peoria" |
2020-06-30 |
411.1 |
14.415 |
$2.169 |
28.52 |
"Replaced brake hose & pads, upgrade aux fan & radio, repaired vac leak rear driver door, seat pad modiflied," |
2021-05-19 |
415.7 |
15.263 |
27.24 |
"K sooper" |
2021-08-15 |
395.2 |
13.999 |
$2.89 |
28.23 |
"Oil & filter change, replace oil pan gasket, k sooper" |
2022-04-17 |
389.6 |
16.466 |
$4.539 |
23.66 |
"Valve adj, steering box adj & alignment, K sooper" |
2022-07-04 |
414.1 |
13.413 |
$5.299 |
30.87 |
"Circle k" |
2022-07-12 |
373.4 |
13.956 |
$5.169 |
26.76 |
"K sooper" |
2022-07-23 |
406.1 |
14.138 |
$4.999 |
28.72 |
"K sooper" |
2022-07-29 |
368.7 |
12.612 |
$4.869 |
29.23 |
"K sooper" |
2022-08-04 |
435.7 |
15.284 |
$4.769 |
28.51 |
"K sooper" |
2022-08-29 |
427.9 |
14.948 |
$4.499 |
28.63 |
"Brake booster & master cylinder replacement, k sooper" |
2022-09-07 |
389.1 |
13.654 |
$4.469 |
28.5 |
"K sooper" |
2022-10-19 |
379.8 |
14.077 |
$5.099 |
26.98 |
"Replaced starter, battery, 1 glow plug and neutral safety switch, K sooper" |
2022-10-26 |
431.7 |
15.517 |
$4.999 |
27.82 |
"K.sooper" |
2022-11-08 |
405.5 |
14.09 |
$4.829 |
28.78 |
"K sooper" |
2022-12-02 |
400.7 |
15.378 |
$4.469 |
26.06 |
"Tire rotation, k soopers" |
2022-12-14 |
394.1 |
15.678 |
$4.299 |
25.14 |
"Air & oil filter change, drag link replaced, safeway" |
2023-03-09 |
416.9 |
15.097 |
$4.799 |
27.61 |
"Airport" |
2023-05-06 |
344.6 |
14.055 |
$3.729 |
24.52 |
"K sooper" |
