2013-10-23 |
322.8 |
12.288 |
26.27 |
"Mi: 62,896. 1st mpg run." |
2013-11-02 |
296.4 |
11.63 |
25.49 |
"Fill till 1st click" |
2013-12-07 |
296.5 |
12.579 |
23.57 |
"Lost last fill-up data. Mi: 64098" |
2013-12-16 |
296.25 |
12.212 |
24.26 |
"Mi: 64394" |
2013-12-24 |
302.5 |
12.038 |
25.13 |
"Mi: 64697" |
2013-12-31 |
303.2 |
11.639 |
26.05 |
"Mi: 65,000" |
2014-01-12 |
316.15 |
12.072 |
26.19 |
"Mi: 65316" |
2014-01-23 |
308.4 |
12.38 |
$3.379 |
24.91 |
"Mi: 65624" |
2014-02-06 |
298.4 |
11.847 |
25.19 |
"Mi: 65923" |
2014-02-16 |
275.65 |
10.981 |
$3.719 |
25.1 |
"Mi: 66198" |
2014-02-26 |
316.4 |
12.027 |
26.31 |
"Mi: 66515" |
2014-03-11 |
300 |
11.585 |
25.9 |
"Mi: 66815" |
2014-03-21 |
341.85 |
12.782 |
$3.839 |
26.74 |
"Mi: 67157" |
2014-04-05 |
311.4 |
11.331 |
27.48 |
"Mi: 67468" |
2014-04-14 |
11.738 |
28.97 |
"Mi: 67808
Oil Change
Transmission/Differential Oil Change (Redline)
Alternator Replaced" |
2014-04-28 |
340.85 |
12.269 |
27.78 |
"Mi: 68149" |
2014-06-08 |
314.9 |
11.645 |
27.04 |
"Mi: 68928" |
2014-06-17 |
344.8 |
12.795 |
$4.019 |
26.95 |
"Mi: 69273" |
2014-06-29 |
356.25 |
12.729 |
$4.039 |
27.99 |
"Mi: 69630" |
2014-07-10 |
367 |
13.151 |
27.91 |
"Mi: 69997
Alliance" |
2014-07-25 |
313.75 |
12.394 |
25.31 |
"Mi: 70310
Valero" |
2014-09-21 |
347.5 |
12.723 |
27.31 |
"Mi: 71308" |
2015-01-28 |
243.8 |
10.998 |
22.17 |
"Mi: 73057
Alliance" |
2015-02-21 |
284.6 |
11.623 |
24.49 |
"Mi: 73341" |
2015-05-01 |
286.3 |
11.719 |
24.43 |
"Mi: 74223" |
2015-06-08 |
284.05 |
11.517 |
24.66 |
"Mi: 74,507" |
2015-07-09 |
332.4 |
13.294 |
25 |
"Mi: 74,839 - Mid" |
2015-08-06 |
283.8 |
11.564 |
$3.3 |
24.54 |
"MI: 75,123, Mid
Oil change @ 75,264" |
2015-10-04 |
315.7 |
12.324 |
25.62 |
"Mi: 75756 - Mid" |
2015-11-03 |
285.5 |
12.462 |
22.91 |
"Mi: 76041; 87
New Battery (11/7/15)
Air filter (76,466)
Smog (11/25/15 @ 76,395) Fail due to high NOx
After test inspection/work:
Found plastic bag covering radiator
Seafoam/Clean plugs & distributor contacts
O2 sensor seems to funtion properly
Connected lower air box properly
Retest TBD - Smog shop closed 11/29" |
2015-12-05 |
224.4 |
9.846 |
22.79 |
"Mi: 76,536 - 86
Smog Retest Fail after Seafoam/ Ign. Tuneup." |
2015-12-19 |
323.8 |
13.333 |
24.29 |
"Mi: 76,860 - Shell Gas
Replaced Fuel Filter" |
2016-02-23 |
297.1 |
12.23 |
$2.179 |
24.29 |
"Mi: 77386. Los Altos Shell" |
2016-03-09 |
286.3 |
12.029 |
23.8 |
"Mi: 77,672 Shell" |
2016-04-24 |
23.15 |
"Approx. miles. Ran out of gas going fill station by less than 1/8 mile. 2 Gal at Chevron, 11 Gal at Shell. Safe to say 13 Gal is max tank. Unless fuel gauge off cuts off fuel sender. Will fix fuel gauge but so far will determine 13 gal max instead of 14.5 as noted by internet & BMW manual." |
2016-05-18 |
281.65 |
12.478 |
22.57 |
"Mi: 75548 - Berryessa Shell" |
2016-09-24 |
250.1 |
10.046 |
24.9 |
"Mi: 80,004
Oil Change 10/09/16 80,202" |
2016-12-29 |
255.8 |
11.836 |
21.61 |
"Mi: 81,143 - Shell Berryessa (12/29/16)" |
2017-01-14 |
285 |
11.916 |
23.92 |
"Mi: 81,428 - Berryessa Shell (1/14/17)" |
2017-07-26 |
281.5 |
10.462 |
26.91 |
"Previous fill @ Valero." |
