2013-08-28 |
10.646 |
28.37 |
"First tankful. Purchased car Aug 23, 2013" |
2013-09-03 |
306 |
10.004 |
30.59 |
"Visit to Sarasota, FL" |
2013-09-30 |
11.243 |
28.46 |
2013-10-06 |
346 |
10.606 |
$3.24 |
32.62 |
"Folded in passenger side mirror." |
2013-10-12 |
347 |
10.785 |
$3.24 |
32.17 |
"Styrofoam Front, mudflap delete" |
2013-10-18 |
346 |
10.886 |
$3.24 |
31.78 |
"Oil change, full synthetic, rush hour driving (dayshift)" |
2013-10-26 |
377 |
10.497 |
$3.24 |
35.92 |
"Wheel Covers, aero wipers, new sparkplugs, disable power steering, Used less AC (night shift, cooler temps)" |
2013-11-02 |
303 |
8.145 |
37.2 |
"Glassed Front Bumper, Increased front/rear tire pressure +2 PSI, 36 rear/35 front." |
2013-11-10 |
368 |
9.973 |
$3.13 |
36.9 |
"Deleted Passenger Side Mirror, Added 98-02 ""aero"" mirror on Driver's Side, 36psi front and rear tires, obtained OBDII Bluetooth device at end of tank." |
2013-11-18 |
435 |
11.169 |
$3.11 |
38.95 |
"Extensive use of ""Pulse and Glide"", painted hood (keep it from rusting), extensive use of OBDII and Torque Lite" |
2013-11-25 |
390 |
10.293 |
$3.5 |
37.89 |
2013-11-27 |
416 |
10.845 |
$3.43 |
38.36 |
2013-12-14 |
364 |
9.679 |
37.61 |
2013-12-18 |
376 |
10.358 |
$3.3 |
36.3 |
"Sped to work one time, one way, at 65mph. Brought the entire average down." |
2013-12-19 |
409 |
10.855 |
$3.33 |
37.68 |
2013-12-21 |
402 |
10.643 |
$3.36 |
37.77 |
2013-12-26 |
10.089 |
$3.27 |
36.97 |
2013-12-29 |
9.537 |
37.64 |
"Mostly Cruise Control @ 60mph. 90% hwy, 10% city." |
2014-01-05 |
395 |
10.567 |
$3.42 |
37.38 |
2014-01-13 |
9.736 |
$3.39 |
34.92 |
2014-01-18 |
358.5 |
9.39 |
$3.36 |
38.18 |
"Odometer reading did not record on phone. Number is half the distance of the next reading." |
2014-01-24 |
358.5 |
10.858 |
$3.3 |
33.02 |
"219958-?=?
Inflated tires to 40.5 PSI. Odometer reading is half of fill up from two fill ups ago." |
2014-01-31 |
10.555 |
36 |
"220338-219958=380" |
2014-02-07 |
10.739 |
35.39 |
"220732-220338=394" |
2014-02-14 |
379 |
10.431 |
$3.389 |
36.33 |
"221111-220732=379
Lots of drafting, and no more turning off the engine at stop lights. Battery has been getting dangerously low. Stalled in the driveway when I turned on the headlights, and could not crank the engine, because the battery was so low." |
2014-02-23 |
376.5 |
10.145 |
37.11 |
"221485-220732=753/2=376.5" |
2014-03-01 |
371 |
10.403 |
35.66 |
"221856-221485=371" |
2014-03-08 |
384 |
10.204 |
37.63 |
"222240-221856=384
Cell Phone Alarm Clock didn't go off, had to speed to work at about 70mph one day." |
2014-03-15 |
10.911 |
35.38 |
"222626-222240=386" |
2014-03-22 |
9.799 |
$3.589 |
36.64 |
"222985-222626=359" |
2014-03-29 |
377 |
10.009 |
37.67 |
"223362-222985=377" |
2014-04-08 |
383 |
11.039 |
34.7 |
"223745-223362=383" |
2014-04-13 |
9.895 |
36.28 |
"224104-223745=359" |
2014-04-22 |
374 |
37.4 |
"224478-224104=374" |
2014-04-27 |
392 |
10.281 |
38.13 |
"224870-224478=392
New tires on rear." |
2014-05-04 |
10.709 |
35.58 |
"225251-224870=381
Running the AC alot due to rain and humidity." |
2014-05-11 |
334 |
9.042 |
36.94 |
"225585-225251=334" |
2014-05-18 |
362 |
9.729 |
37.21 |
"225947-225585=362
One day traveled 65mph to work. 60mph all other times." |
2014-05-26 |
394 |
10.519 |
37.46 |
"226341-225947=394
One day to work at 65mph." |
2014-06-08 |
404 |
10.745 |
$3.329 |
37.6 |
"226745-226341=404" |
2014-06-17 |
424 |
11.292 |
37.55 |
"227169-226745=424" |
2014-06-21 |
418 |
10.883 |
$3.589 |
38.41 |
"1.413+8.359+1.111=10.883 Gallons
227587-227169=418 Miles
Trip to Sarasota and back." |
2014-06-30 |
404 |
10.678 |
37.83 |
"227991-227587=404" |
2014-07-07 |
413 |
11.019 |
37.48 |
"228404-227991=413" |
2014-09-01 |
366 |
10.823 |
33.82 |
"230171-229805=366
Second full refuel since series of half-fills." |
2014-09-10 |
424 |
11.572 |
36.64 |
"230595-230171=424
New Tie rods installed, newer 14"" tires from Paseo on the front. 13"" rims from Tercel on the back. Tire air pressure not yet checked. Lots of AC use in mid summer heat." |
2014-09-16 |
389 |
10.451 |
$3.269 |
37.22 |
"230984-230595=389
New tie-rods, two best 185-60/r14 on front, two best 165-65/r13 on rear. PSI is about 35-36 all around." |
2014-09-20 |
10.718 |
$3.249 |
35.45 |
"231364-230984=380
Filled tires to 40psi all around." |
2014-09-26 |
366 |
10.362 |
$3.249 |
35.32 |
"231730-231364=366" |
2014-10-04 |
10.369 |
36.45 |
"232108- 231730=378" |
2014-10-11 |
394 |
10.911 |
$3.279 |
36.11 |
"232502-232108=394" |
