2014-03-26 |
237.4 |
11.405 |
$3.78 |
20.82 |
"This tank had Chevron with Techron ran through it and some mild boosting. Most shifting done before 3K RPM unless boosting. Tire psi brought up to 40 from 32 psi. Power steering o-rings changed and system flushed in order to restore consistent PS use." |
2014-03-30 |
194.2 |
8.584 |
$3.62 |
22.62 |
2014-04-09 |
239 |
11.417 |
$3.68 |
20.93 |
2014-04-14 |
269 |
10.751 |
$3.69 |
25.02 |
2014-04-20 |
272 |
11.706 |
$3.789 |
23.24 |
2014-04-30 |
286 |
11.82 |
$3.74 |
24.2 |
2014-05-06 |
223 |
11.317 |
$3.78 |
19.7 |
2014-05-16 |
242 |
11.249 |
$3.78 |
21.51 |
2014-05-24 |
265 |
$3.78 |
22.75 |
2014-05-30 |
313 |
12.892 |
$3.87 |
24.28 |
2014-06-01 |
370 |
14.058 |
$3.78 |
26.32 |
2014-06-11 |
308 |
13.316 |
$3.78 |
23.13 |
2014-06-27 |
267.6 |
13.131 |
20.38 |
2014-07-02 |
347.5 |
14.224 |
$3.81 |
24.43 |
2014-07-13 |
346.9 |
13.671 |
$3.709 |
25.37 |
2014-07-22 |
280 |
12.121 |
$3.68 |
23.1 |
2014-07-30 |
300.8 |
13.832 |
21.75 |
2014-08-05 |
323.2 |
12.482 |
$3.58 |
25.89 |
2014-08-14 |
283.3 |
11.493 |
$3.69 |
24.65 |
2014-08-25 |
295 |
13.571 |
$3.64 |
21.74 |
2014-08-30 |
320.4 |
12.794 |
$3.73 |
25.04 |
2014-09-07 |
314.2 |
12.742 |
$3.73 |
24.66 |
2014-09-19 |
282.7 |
12.971 |
$3.53 |
21.79 |
2014-09-26 |
289.6 |
11.901 |
$3.48 |
24.33 |
2014-10-11 |
258.1 |
12.432 |
$3.33 |
20.76 |
2014-10-16 |
244.2 |
10.497 |
$3.26 |
23.26 |
2014-10-26 |
256 |
11.243 |
$3.53 |
22.77 |
2014-11-04 |
220 |
10.105 |
$3.42 |
21.77 |
"Partial tank with snow tires on and driving in snow" |
2014-11-14 |
240.7 |
12.425 |
$3.09 |
19.37 |
"First full tank on snow tires" |
2014-11-23 |
202.9 |
10.828 |
$3.03 |
18.74 |
"Many minutes of idling on this tank since EBH is not working :-(" |
2014-12-02 |
250.5 |
12.508 |
$2.93 |
20.03 |
2014-12-11 |
251.1 |
12.559 |
$2.66 |
19.99 |
"for most of this tank, boost was acting funny. After a trip to dealer for recall airbag work. boost started acting normal again." |
2014-12-22 |
250.2 |
12.197 |
$2.49 |
20.51 |
2014-12-27 |
261.6 |
12.63 |
$2.49 |
20.71 |
2015-01-03 |
255 |
11.813 |
21.59 |
2015-01-10 |
183.7 |
9.878 |
$2.319 |
18.6 |
2015-01-23 |
249.4 |
12.332 |
$2.29 |
20.22 |
2015-01-31 |
239.4 |
11.668 |
$2.33 |
20.52 |
2015-02-05 |
229.8 |
12.103 |
$2.49 |
18.99 |
"P0302 stored but not displayed for this tank" |
2015-02-13 |
272.9 |
13.173 |
$2.46 |
20.72 |
"Been getting misfire code P0302 intermittently, suspect a bad coil connection but will not be able to troubleshoot until warmer weather." |
2015-02-24 |
234.7 |
12.747 |
$2.63 |
18.41 |
2015-03-01 |
171.9 |
9.013 |
$2.83 |
19.07 |
2015-03-07 |
234.1 |
12.235 |
19.13 |
2015-03-18 |
267.1 |
12.479 |
$2.69 |
21.4 |
2015-03-28 |
240 |
11.398 |
$2.56 |
21.06 |
2015-04-03 |
326.9 |
13.352 |
$2.63 |
24.48 |
"Lots of highway driving" |
2015-04-13 |
288.6 |
12.834 |
$2.63 |
22.49 |
2015-04-19 |
12.947 |
$2.63 |
24.1 |
2015-04-28 |
246.5 |
11.454 |
$2.76 |
21.52 |
2015-05-05 |
290.4 |
10.484 |
$2.81 |
27.7 |
"Suspected that the pump stopped before full tank reached" |
2015-05-11 |
252.6 |
13.173 |
$2.85 |
19.18 |
2015-05-19 |
313.1 |
13.528 |
$2.94 |
23.14 |
2015-05-26 |
316.3 |
13.361 |
$3.01 |
23.67 |
2015-06-03 |
300.2 |
13.287 |
$3.02 |
22.59 |
2015-06-09 |
261.1 |
12.063 |
$2.96 |
21.64 |
2015-06-15 |
320.3 |
13.092 |
$2.96 |
24.47 |
2015-06-19 |
299.8 |
12.733 |
$2.97 |
23.55 |
2015-06-19 |
306.3 |
12.927 |
$2.96 |
23.69 |
2015-07-06 |
266 |
11.953 |
$3.06 |
22.25 |
2015-07-11 |
262.3 |
10.618 |
$2.93 |
24.7 |
2015-07-28 |
271.4 |
11.79 |
$2.96 |
23.02 |
2015-08-04 |
316.9 |
13.905 |
$2.89 |
22.79 |
"Last fill before pulling the engine for rebuilding and other maintenance" |
2015-11-16 |
280.5 |
12.612 |
$2.49 |
22.24 |
"First tank through new rebuild" |
2015-12-08 |
248.9 |
12.225 |
$2.32 |
20.36 |
2015-12-22 |
221.6 |
10.317 |
$2.09 |
21.48 |
2015-12-29 |
224.4 |
10.852 |
$2.09 |
20.68 |
2016-01-12 |
248.9 |
11.258 |
$1.96 |
22.11 |
2016-01-23 |
244.2 |
12.342 |
$1.85 |
19.79 |
2016-01-28 |
245.4 |
11.461 |
$1.93 |
21.41 |
2016-02-05 |
223.7 |
11.924 |
$1.69 |
18.76 |
2016-02-15 |
233.3 |
11.741 |
$1.79 |
19.87 |
2016-02-28 |
246 |
12.075 |
$2.09 |
20.37 |
