2013-11-24 |
365 |
9.99 |
36.54 |
"Last years baseline personal best in November @ 67mph avg.
Temp. 45* F avg.
No wind and light traffic." |
2014-11-23 |
321 |
9.39 |
$2.92 |
34.19 |
"2014 Base test run.
Cool temps 40*F avg.
60 mph avg.
wet/dry roads
hot air system disabled
EGR disabled
Lean burn enable
Ultra Lean burn disabled" |
2014-12-01 |
289 |
7.6 |
$2.71 |
38.03 |
"2014 November
65 mph avg.
dry roads
hot air system enable
EGR 5% enable
Lean burn enable
Ultra Lean burn enable" |
2015-01-28 |
9.26 |
$2.7 |
41.04 |
"40*F
Lean Burn
Hot EGR
65MPH avg." |
2015-02-22 |
9.54 |
$1.5 |
44.03 |
"Ultra Lean Burn
Hot EGR
65 MPH avg." |
2015-05-18 |
368 |
8.97 |
41.03 |
"Ultra lean burn freeway/city combine.
A couple full throttle pulls to check boost leaks." |
2015-05-27 |
391 |
$2.81 |
42.04 |
"ultra lean burn
city/freeway" |
2015-06-07 |
417 |
9.9 |
$1.96 |
42.12 |
"Long haul waste solvent test.
3 gallons burned
ultra lean burn
cold egr only
freeway
60 mph avg" |
2015-06-28 |
433 |
$1.87 |
45.1 |
"warmer conditions
60 mph avg
3 gallons waste solvent enable
ultra lean burn enable
new lean map for mid boost" |
2015-07-20 |
505 |
$2.1 |
45.91 |
"Ultra lean burn
60 avg mph
3 gallons waste solvent enable" |
2015-07-30 |
441 |
$1.93 |
47.42 |
"ultra lean burn
60 mph avg" |
2015-08-05 |
206 |
5.6 |
$1.42 |
36.79 |
"Increase waste solvent test 50/50
Ultra Lean Burn
60 mph avg.
90*F" |
2015-08-16 |
461 |
10.52 |
$1.74 |
43.82 |
"Ultra lean burn waste solvent enable
60 MPH avg
90* F avg" |
2015-09-07 |
459 |
10.1 |
$1.57 |
45.45 |
"Colder end of run temps
60/40 freeway city
Ultra Lean burn
Waste solvent enable" |
2015-09-19 |
389 |
10.5 |
$1.48 |
37.05 |
"Much cooler temps
ultra lean burn
2015-10-03 |
489 |
10.8 |
$1.39 |
45.28 |
"Ultra lean burn
single valve enable at 350 miles into this tank
55*F temps avg." |
2015-10-14 |
108 |
2.5 |
43.2 |
"Waste solvent with DTR 601 Reducer only" |
2015-10-28 |
$0.03 |
42.63 |
"Waste Solvent 99%" |
2015-11-24 |
477 |
39.75 |
"waste solvent enable
cooler temps" |
2016-02-16 |
481 |
$0.03 |
37 |
"ABA test with out compound system
45*F temps
60mph avg." |
2016-03-02 |
360 |
$0.03 |
36 |
"2nd ABA test without compound system
45*F
60mph avg" |
2016-05-22 |
9.8 |
$0.03 |
38.57 |
"warmer 75F avg" |
2016-07-09 |
351 |
8.77 |
$0.03 |
40.02 |
"warmer temps
N2O testing to help lean burn" |
2016-07-26 |
8.41 |
$0.03 |
45.3 |
"lean burn
N2O
single valve
warm temps 90+
55 mph avg" |
2016-08-29 |
411 |
9.7 |
$0.03 |
42.37 |
"warm temps 85*f
55 mph average" |
2016-10-15 |
478 |
46.86 |
"Lean Burn
55mph avg" |
2016-12-04 |
452 |
41.09 |
"Much cooler temps
Lean burn waste solvent enable" |
2018-01-06 |
421 |
10.26 |
41.03 |
"Single valve enable.
Waste solvent
Lean-Burn
55* temps" |
2022-04-12 |
376 |
9.42 |
$0.11 |
39.92 |
"Retesting waste-solvent tune. Cold temps 45avg." |
2022-05-26 |
321 |
8.44 |
$4.88 |
38.03 |
"Cold temps testing new injectors on pump 87
Lean burn enable two valve mode" |
