2014-12-18 |
289 |
12.802 |
$2.929 |
22.57 |
"Significant dip in MPG since purchase of vehicle in Sept. Warming up the vehicle plus switch to winter gas contributing to dip?" |
2014-12-30 |
263.3 |
12.362 |
21.3 |
"trip computer indicated around 23.5 mpg. seems like it's optimistic" |
2015-01-24 |
268.3 |
13.057 |
20.55 |
"Stupid Rochester still has expensive gas. #5 most expensive in the US. Bitter cold of late means more idle time with the remote car starter to warm up" |
2015-02-03 |
236 |
10.929 |
21.59 |
"figures may be off slightly...did not fill the tank all the way on this one so made some mods to estimates. I got 276.6 actual miles, but should have filled more than 10.929 gals. Instead of missing an entry or finding a 'true' and accurate solution, I bumped down the miles here based upon the tri[ computer MPG estimates to be slightly lower than what the car said as that has been consistent thus far. Car said this tank was 22 mpg. Will have to watch the fill closer at Fastrac...kept shutting down the pump early thinking car was full when it wasn't..." |
2015-02-11 |
271 |
12.896 |
21.01 |
2015-02-23 |
265.9 |
13.864 |
19.18 |
"stupid never ending freezing winter = lots of warm up time idling to de ice." |
2015-03-04 |
263 |
12.308 |
21.37 |
"Would have been much better this tank...if not for the hour and a half commute home in the slush last night...to go 12 miles. Lots of idling and going nowhere fast." |
2015-03-11 |
310.2 |
12.575 |
$2.549 |
24.67 |
"Trip up north to Niagara on the Lake. Lots of thruway driving to get up there, then lots of slow going in town. Weather broke into the 40's so no pre heating!" |
2015-03-20 |
311.7 |
12.607 |
24.72 |
"Mostly highway commuting, very little warm up time with the weather starting to turn. Much better" |
2015-04-04 |
357.2 |
13.098 |
$2.569 |
27.27 |
"Finger Lakes trip boosted this tank" |
2015-04-15 |
322.8 |
13.104 |
24.63 |
"14,300" |
2015-04-27 |
351.9 |
13.847 |
25.41 |
"trip cpu - 26.5mpg" |
2015-05-09 |
323.7 |
12.595 |
25.7 |
"15,000 miles" |
2015-05-21 |
333.6 |
13.331 |
$3.139 |
25.02 |
"15,295 filled with Premium ethanol free today. Just cause" |
2015-06-06 |
384.4 |
14.25 |
26.98 |
"Tank did well on ethanol free premium." |
2015-06-13 |
282.2 |
11.078 |
$2.798 |
25.47 |
"Lost receipt, going based upon memory. Was a $31 fill, believe $2.79/gal. So backed into the math for fuel used" |
2015-06-21 |
396.3 |
14.794 |
26.79 |
2015-07-06 |
334.4 |
13.155 |
25.42 |
2015-07-27 |
324.8 |
12.485 |
26.02 |
"17,345 trip cpu = 27.5" |
2015-08-08 |
357.4 |
13.778 |
$2.689 |
25.94 |
"17,700 miles. oil change. lucas oil top end fuel treatment additive added today. Prepped for a road trip!" |
2015-08-14 |
276 |
9.775 |
28.24 |
"Fill up of ethanol free premium before the road trip" |
2015-08-15 |
263.1 |
9.914 |
26.54 |
"many fills on the 2,000 miles put on for vacation. Tons of mountains, elevation changes and AC running through VA and WV. Fully loaded with cargo and people, the truck downshifted a ton back down to 5th and sometimes 4th gear." |
2015-08-15 |
213.4 |
7.748 |
$2.549 |
27.54 |
2015-08-15 |
207.1 |
7.041 |
29.41 |
2015-08-22 |
171.2 |
7.086 |
24.16 |
2015-08-22 |
286.6 |
9.835 |
29.14 |
2015-08-22 |
11.802 |
27.54 |
"20,000 miles" |
2015-08-30 |
354.7 |
12.813 |
27.68 |
2015-09-09 |
343.7 |
12.925 |
$2.259 |
26.59 |
2015-09-21 |
317.6 |
11.968 |
$2.089 |
26.54 |
"I LOVE CHEAP GAS! 20,800" |
2015-09-30 |
413.4 |
14.905 |
$1.919 |
27.74 |
"21,675 trip to Buffalo and back boosted this tank a bit. How about gas for under $2!! =)
$1.989 retail cost
$1.919 with member card program" |
2015-10-10 |
355.8 |
13.809 |
$2.059 |
25.77 |
"21,870" |
2015-10-22 |
324.5 |
12.804 |
25.34 |
2015-11-01 |
336.1 |
13.597 |
24.72 |
"22650 hit B Lo today but wind was insane. cpu real time MPGs topped out at 25 on way there. About 4-5 MPGs lower than normal" |
2015-11-09 |
329.7 |
13.092 |
$2.438 |
25.18 |
"Accidentally filled up with ethanol free premium 91. Whoops. Regular would have been ~ $2.05
1st fill after fresh oil change." |
2015-11-18 |
320.9 |
12.517 |
$1.998 |
25.64 |
"Switched to winter wheels and tires so expecting some efficiency losses due to tires, and switch to winterized fuel.
Also trying the Eco settings on the truck to see if that will offset things." |
2015-11-24 |
326.3 |
12.735 |
25.62 |
"23,450
Installed K&N air filter" |
2015-12-04 |
290.7 |
12.42 |
$2.069 |
23.41 |
2015-12-14 |
333.4 |
13.451 |
$2.059 |
24.79 |
"24,000" |
2015-12-23 |
328.7 |
13.811 |
$2.049 |
23.8 |
2016-01-07 |
248 |
11.549 |
$2.009 |
21.47 |
"24575" |
2016-01-15 |
284.1 |
12.594 |
$1.989 |
22.56 |
"24950" |
2016-01-27 |
284.7 |
12.084 |
$1.899 |
23.56 |
"25,075 inflated the winter tires from 36 to 40 psi this morning. See if I can reduce a little rolling resistance." |
2016-02-07 |
321.2 |
13.321 |
$1.899 |
24.11 |
"25,350" |
2016-02-15 |
264.4 |
13.179 |
$1.889 |
20.06 |
"winter idle time leading to lower mpgs as usual" |
2016-02-26 |
309.9 |
13.77 |
$1.779 |
22.51 |
"26,038" |
2016-03-09 |
316.2 |
14.411 |
$1.849 |
21.94 |
"26,450 ish" |
2016-03-15 |
318.8 |
11.089 |
$1.889 |
28.75 |
"~26,700
trip back and forth to Buffalo boosted this tank. more of that in the coming weeks" |
2016-03-24 |
274.7 |
12.97 |
21.18 |
"26,950 fresh oil & filter. filled with ethanol free 91" |
2016-03-31 |
306 |
12.062 |
25.37 |
"27,250
one more fill of ethanol free 91." |
2016-04-08 |
297.5 |
12.221 |
$2.029 |
24.34 |
"back to reg. FI Cleaner added this tank" |
2016-04-20 |
324.9 |
13.438 |
$2.169 |
24.18 |
2016-05-16 |
299.5 |
11.874 |
$2.219 |
25.22 |
2016-05-25 |
355.7 |
13.073 |
$2.329 |
27.21 |
"28,850 ish miles. Swapped back to summer tires finally mid tank. Should hopefully bump things up more" |
2016-06-07 |
323.7 |
11.521 |
$2.219 |
28.1 |
"29,060
May not have completely filled? MPG's high on this fill. Trip computer said 26.7 mpg..." |
2016-06-16 |
262 |
11.079 |
$2.219 |
23.65 |
"29,321
def was off last fill, which affected this one.
added a gallon to this fill, subtracted one from the last...same thing in the end, but will be a bit more accurate as i knew i didn't pull a 30mpg tank last fill. . ." |
2016-07-01 |
276.5 |
11.417 |
24.22 |
"29,985
hills of PA, 3 passengers and cargo...lots of 5th gear holding" |
2016-07-05 |
136.4 |
4.766 |
$2.119 |
28.62 |
"30121
top off of cheap MD gas before heading home..." |
2016-07-05 |
338.6 |
12.231 |
$2.289 |
27.68 |
"30,460
filled up at home after round trip to MD and back" |
2016-07-15 |
314.4 |
13.152 |
$2.159 |
23.91 |
"30,758. Fresh oil change today" |
2016-07-21 |
321.1 |
12.065 |
$2.159 |
26.61 |
"31,096 wine tour in FLX last weekend" |
2016-07-28 |
329.5 |
12.773 |
$2.149 |
25.8 |
"31,425" |
2016-08-05 |
335.9 |
12.818 |
$2.149 |
26.21 |
"31,761" |
2016-08-17 |
335.7 |
13.216 |
$2.119 |
25.4 |
"32,097" |
2016-08-24 |
348.4 |
13.043 |
$2.189 |
26.71 |
"32,445" |
2016-09-06 |
319 |
12.852 |
$2.159 |
24.82 |
"32,764" |
2016-09-13 |
356.1 |
13.301 |
$2.139 |
26.77 |
"33,120" |
2016-09-22 |
340.5 |
12.336 |
$2.109 |
27.6 |
"33,461
Gas trigger must have shut off gas prematurely and I didn't notice...no way I got this mileage. Did fail to check tires...so they were all low by about 8 PSI. Should be better mpg's from now until snow tire time.
340.5 miles was actual. Adjusted fuel used to compensate. . .
Actual was 10.336, added 2 gals" |
2016-10-03 |
260.9 |
10.812 |
$2.189 |
24.13 |
"33,722
Actual was 260.9...per last log, adjusted down 2 gals to attempt to compensate. Actual fuel showed 12.812" |
2016-10-11 |
396.6 |
14.628 |
$2.229 |
27.11 |
"34,293" |
2016-10-24 |
350.8 |
13.204 |
$2.189 |
26.57 |
"34,644" |
2016-11-04 |
317.2 |
13.279 |
$2.229 |
23.89 |
"34,962" |
2016-11-13 |
323.3 |
12.652 |
$2.189 |
25.55 |
"35,285" |
2016-11-25 |
349.8 |
14.524 |
$2.289 |
24.08 |
"35,635" |
2016-12-05 |
248.5 |
10.462 |
$2.609 |
23.75 |
"15 cents off on Sunday today so splurged on the Premium just cause I felt like it. Lots of city driving back and forth due to the house move.
35,883" |
2016-12-20 |
292.2 |
12.783 |
$2.3 |
22.86 |
"36,452 - hit up BJs after some shopping for this round." |
2016-12-29 |
292.3 |
12.389 |
$2.389 |
23.59 |
"36,744" |
2017-01-09 |
278 |
13.226 |
$2.389 |
21.02 |
"37,023" |
2017-01-19 |
314.2 |
13.132 |
23.93 |
"37,337, tires were a bit low so filled today
Been warm past few weeks, no need to preheat car for long periods with no snow." |
2017-01-29 |
13.247 |
24.16 |
"37,657" |
2017-02-10 |
329.9 |
13.987 |
23.59 |
"37,987" |
2017-03-06 |
322.9 |
13.393 |
$2.169 |
24.11 |
"38,310" |
2017-03-16 |
300.3 |
$2.25 |
25.03 |
2017-03-29 |
329.7 |
12.924 |
$2.089 |
25.51 |
"So cheap in Henrietta. . . 20 cents less
38,940
Oil and filter change" |
2017-04-07 |
320.1 |
13.169 |
$2.259 |
24.31 |
"39,260 miles" |
2017-04-18 |
315.5 |
12.421 |
25.4 |
"39,575" |
2017-04-29 |
363.6 |
13.331 |
$2.389 |
27.27 |
"39,939" |
2017-05-04 |
319.7 |
12.494 |
$2.249 |
25.59 |
"40,259" |
2017-05-17 |
320.8 |
12.569 |
25.52 |
"40,751" |
2017-05-28 |
287.9 |
11.022 |
26.12 |
"41,039" |
2017-06-08 |
319.9 |
11.649 |
$2.339 |
27.46 |
"41,359 full tank on all seasons. last few fills with Mobil to clean up the system a little." |
2017-06-20 |
351.6 |
13.177 |
$2.159 |
26.68 |
"41,711" |
2017-06-29 |
345.2 |
12.539 |
$2.129 |
27.53 |
"42,056" |
2017-07-10 |
341.2 |
12.85 |
$2.389 |
26.55 |
"42,397" |
2017-07-20 |
11.26 |
$2.229 |
27.71 |
"42,709" |
2017-07-28 |
234.4 |
8.695 |
$2.329 |
26.96 |
"42,943" |
2017-08-02 |
324.2 |
11.97 |
$2.289 |
27.08 |
"43,268
oil change today" |
2017-08-14 |
319.8 |
12.047 |
26.55 |
"43,588" |
2017-08-18 |
190.6 |
7.0729 |
$2.389 |
26.95 |
"43,778
fill up before HHI trip" |
2017-09-16 |
397.2 |
14.986 |
$2.689 |
26.5 |
"46,632 gas prices have spiked post hurricane affecting TX." |
2017-09-25 |
342.4 |
13.027 |
26.28 |
"46,974" |
2017-10-05 |
386.7 |
14.687 |
$2.519 |
26.33 |
"47,361. Oil & filter change" |
2017-10-14 |
320.8 |
12.39 |
$2.389 |
25.89 |
"47,682" |
2017-10-23 |
308.3 |
11.464 |
$2.329 |
26.89 |
"47,990" |
2017-11-01 |
343 |
13.112 |
$2.429 |
26.16 |
"48,333" |
2017-11-13 |
300.1 |
10.899 |
$2.589 |
27.53 |
"48,634" |
2017-11-21 |
276.4 |
12.634 |
$2.509 |
21.88 |
"48,910 snow tires are on" |
2017-12-13 |
266 |
11.1 |
23.96 |
"49,501, Mobil fill." |
2017-12-24 |
268.7 |
11.604 |
$2.529 |
23.16 |
"49,769" |
2017-12-31 |
272.7 |
13.08 |
$2.519 |
20.85 |
"50,042" |
2018-01-16 |
287.7 |
13.204 |
21.79 |
"50,330" |
2018-01-23 |
276.8 |
11.568 |
23.93 |
"50,607" |
2018-02-01 |
310.6 |
13.115 |
23.68 |
"50,917 Mobil" |
2018-02-13 |
13.115 |
22.95 |
"51,218, oil change - synth blend, Mobil fill again." |
2018-02-14 |
216.9 |
8.88 |
24.43 |
"51,435" |
2018-02-16 |
309.3 |
12.466 |
24.81 |
"51,745 road trip to Boston MA. Truck is too weak under load and at speed, needs to downshift into 5th and sometimes 4th to maintain speed
Gulf on I-90" |
2018-02-18 |
292.4 |
12.627 |
$2.629 |
23.16 |
"52,037 fill after return home from Boston. Delta Sonic" |
2018-02-28 |
346.2 |
14.233 |
$2.529 |
24.32 |
"52,383 fastrac fill" |
2018-03-19 |
318.2 |
13.466 |
23.63 |
"53,011 Mobil" |
2018-04-02 |
336.5 |
14.356 |
23.44 |
"53,347 Mobil fill" |
2018-04-11 |
309.8 |
12.225 |
25.34 |
"53,657 Mobil. Seafoam added to fuel" |
2018-04-23 |
309.7 |
12.922 |
23.97 |
"53,967, Mobil" |
2018-05-03 |
316.4 |
12.382 |
25.55 |
"54,283 Mobil" |
2018-05-29 |
336.4 |
14.253 |
23.6 |
"54,620 Mobil fill, back to all season tires" |
2018-06-05 |
282.1 |
10.555 |
$2.989 |
26.73 |
"54,902 Delta Sonic fill. Summer tires back on. MPGs should start climbing again. This tank also had road trip to Onondaga lake...so lots of highway" |
2018-06-12 |
361 |
12.854 |
28.08 |
"55,263 Mobil fill. K&N filter cleaned. It was filthy..." |
2018-06-25 |
359.9 |
13.591 |
26.48 |
"55,623 Mobil fill" |
2018-07-09 |
348.9 |
12.736 |
27.39 |
"55,972 miles
Fastrac fillup...tried diff station to confirm no more ethanol free premium. =(" |
2018-07-21 |
298.2 |
11.418 |
26.12 |
"56,270 Fastrac" |
2018-08-05 |
360.9 |
12.741 |
28.33 |
"56,631 Mobil fill" |
2018-08-10 |
313 |
11.038 |
28.36 |
"56,944
Mobil" |
2018-08-16 |
339 |
11.928 |
28.42 |
"57,283 Mobil" |
2018-08-23 |
169.6 |
7.122 |
23.81 |
"57,453 Mobil" |
2018-08-24 |
408.6 |
14.315 |
28.54 |
"57,861 Shell in VA" |
2018-08-25 |
308.4 |
11.354 |
$2.629 |
27.16 |
"58,170" |
2018-09-01 |
273.7 |
10.816 |
25.31 |
"58,444" |
2018-09-01 |
269.9 |
9.685 |
27.87 |
"58,714" |
2018-09-02 |
371.3 |
13.819 |
26.87 |
"59,085 High's MD" |
2018-09-04 |
360.2 |
12.693 |
28.38 |
"59,445 Mobil" |
2018-09-17 |
355.3 |
13.45 |
26.42 |
"59,801 Fastrac Fill" |
2018-09-25 |
316.4 |
11.877 |
$2.989 |
26.64 |
"60,117 Sunoco" |
2018-09-25 |
171.5 |
6.503 |
$3.098 |
26.37 |
"60,289 Sheetz" |
2018-09-27 |
361 |
13.171 |
$2.889 |
27.41 |
"60,650 Mobil" |
2018-10-08 |
342.9 |
12.153 |
$2.803 |
28.22 |
"60,993 Mobil
$2.99/gall reg price, after rewards of $2.39 via card, adjusted price per gallon" |
2018-10-18 |
316.6 |
11.56 |
$2.889 |
27.39 |
"61,310 Mobil" |
2018-10-31 |
320.9 |
12.503 |
25.67 |
"61,630 Mobil fill" |
2018-11-16 |
238.9 |
11.127 |
$2.889 |
21.47 |
"61,869
DeltaSonic fill" |
2018-12-07 |
245 |
11.466 |
21.37 |
"62,115
Mobil fill. Should be getting some better MPGs being back at work and more highway travel" |
2018-12-14 |
242.6 |
10.004 |
24.25 |
"62,357
Mobil fill" |
2018-12-28 |
262.1 |
11.592 |
$5.549 |
22.61 |
"62,619
Mobil" |
2019-01-08 |
284.4 |
11.399 |
24.95 |
"62,904 Mobil" |
2019-01-23 |
237 |
10.775 |
22 |
"63,141
Mobil fill
more idle time warming since it's been 0 degrees..." |
2019-01-29 |
179 |
7.775 |
23.02 |
"63,320 Fastrac fill before the vortex hits...yay" |
2019-02-20 |
284.9 |
13.268 |
21.47 |
"63,605 Mobil" |
2019-03-18 |
284.7 |
12.063 |
23.6 |
"64,165 Mobil" |
2019-03-26 |
315.1 |
13.196 |
23.88 |
"64,481 Mobil" |
2019-04-03 |
306.2 |
12.06 |
25.39 |
"64,787 Mobil" |
2019-04-12 |
319.2 |
12.503 |
25.53 |
"65,106 Mobil" |
2019-04-24 |
337.9 |
12.557 |
26.91 |
"65,444 Mobil" |
2019-05-10 |
353.3 |
12.935 |
27.31 |
"65,797 Mobil" |
2019-05-21 |
312.6 |
11.361 |
27.52 |
"66,110 Mobil" |
2019-06-11 |
325.7 |
11.539 |
28.23 |
"66,683 Mobil, seafoam gas treatment" |
2019-06-24 |
351.5 |
12.286 |
28.61 |
"67,034 Mobil" |
2019-07-03 |
281.6 |
11.174 |
25.2 |
"67,316 Mobil" |
2019-07-15 |
381.6 |
14.772 |
25.83 |
"67,698 Mobil" |
2019-07-26 |
293 |
9.539 |
30.72 |
"68,571 Mobil
lost the last couple fills from the ADK trip. Was doing great MPG wise per the gauge too.
Rebooted phone, so lost all mileage pics and etc. fail" |
2019-08-06 |
291.8 |
10.914 |
26.74 |
"68,863 Mobil" |
2019-08-15 |
214.4 |
8.213 |
26.1 |
"69,077 Fastrac" |
2019-08-16 |
343.3 |
12.917 |
26.58 |
"69,420 Shell - MD trip down to HHI" |
2019-08-17 |
220.4 |
7.752 |
28.43 |
"69,641 Mobil" |
2019-08-17 |
201 |
6.856 |
29.32 |
"69,892" |
2019-08-20 |
11.936 |
$2.329 |
24.04 |
"70,119" |
2019-08-24 |
167.9 |
7.192 |
$2.259 |
23.35 |
"70,287" |
2019-08-24 |
299.7 |
11.397 |
$2.259 |
26.3 |
"70,587" |
2019-08-25 |
275.3 |
10.13 |
27.18 |
"70,862" |
2019-08-27 |
350.1 |
12.448 |
28.13 |
"71,213 Mobil" |
2019-09-10 |
379 |
14.252 |
26.59 |
"71,592 Mobil
Swapped out to new Cooper tires for the all seasons. Will see if it impacts MPGs as factory tires are low resistance eco tires." |
2019-09-16 |
313.4 |
12.27 |
25.54 |
"71,905 Mobil" |
2019-09-26 |
293.1 |
11.855 |
24.72 |
"72,198 Mobil" |
2019-10-07 |
318.9 |
12.707 |
25.1 |
"72,517 Mobil" |
2019-10-23 |
298.6 |
11.948 |
24.99 |
"72,816 Mobil" |
2019-11-04 |
272.5 |
11.665 |
23.36 |
"73,088 Mobil" |
2019-11-15 |
272.3 |
11.703 |
23.27 |
"73,361 Mobil" |
2019-11-25 |
319.3 |
13.306 |
24 |
"73,680 mobil" |
2019-12-13 |
248.6 |
10.767 |
$2.549 |
23.09 |
"74,249 Mobil" |
2020-01-13 |
297.3 |
12.707 |
23.4 |
"75,103 Mobil" |
2020-01-22 |
284.9 |
12.154 |
23.44 |
"75,388 Mobil" |
2020-02-05 |
312.9 |
13.292 |
23.54 |
"75,701 Mobil" |
2020-02-17 |
12.592 |
$2.549 |
22.79 |
"75,988, Mobil" |
2020-03-06 |
337.4 |
13.944 |
24.2 |
"76,611 Mobil" |
2020-03-16 |
273.4 |
11.047 |
24.75 |
"76,884 Mobil" |
2020-06-14 |
275.6 |
13.023 |
$2.189 |
21.16 |
"77,513, Mobil. First fill with All Seasons on. Yikes" |
2020-06-27 |
223.2 |
9.073 |
$2.259 |
24.6 |
"77,737 Mobil" |
2020-07-05 |
236.9 |
9.618 |
24.63 |
"77,973 Mobil" |
2020-07-19 |
355.6 |
15.222 |
23.36 |
"78,329 Mobil" |
2020-07-22 |
330.3 |
12.471 |
$2.189 |
26.49 |
"78659 Speedway. Roadtrip to the Catskills, lots of mountainous roads" |
2020-07-27 |
336.7 |
12.924 |
26.05 |
"78,996 Marathon Penfield" |
2020-08-22 |
161.9 |
6.13 |
26.41 |
"79396" |
2020-08-22 |
237.5 |
10.519 |
$2.229 |
22.58 |
"79234" |
2020-08-23 |
291.6 |
11.266 |
25.88 |
"79687" |
2020-08-29 |
232.5 |
9.729 |
23.9 |
"79920" |
2020-08-29 |
221.2 |
8.378 |
$2.369 |
26.4 |
"80141" |
2020-09-17 |
319.6 |
12.559 |
25.45 |
"80,705 Marathon" |
2020-10-07 |
275.9 |
12.337 |
$2.249 |
22.36 |
"80,981 Mobil" |
2020-10-30 |
257.8 |
12.432 |
20.74 |
"81,239 Marathon" |
2020-12-11 |
243.5 |
12.94 |
18.82 |
"81,759 Marathon" |
2021-01-02 |
281.6 |
13.943 |
20.2 |
"82,041 miles, Marathon 250/441" |
2021-02-13 |
149.7 |
9.417 |
$2.549 |
15.9 |
"82407, fill up at Mobil on the way to Other Half before the snow storm" |
2021-03-13 |
231.6 |
13.098 |
$2.939 |
17.68 |
"82,638 Mobil in Fairport" |
2021-04-09 |
285.4 |
13.551 |
21.06 |
"82,924 Marathon Penfield" |
2021-04-23 |
288.9 |
13.215 |
21.86 |
"83,213 Marathon 250/441
Did a Seafoam top end cleaning/treatment at Dan Z's the other week. Seems to idle better....no real MPG change since still all short trips" |
2021-05-17 |
283.6 |
12.907 |
$3.099 |
21.97 |
"83,497 Marathon 250/441" |
2021-05-29 |
261.5 |
11.582 |
$3.099 |
22.58 |
"83,758 A Plus Sunoco in Sacket's Harbor on our camp weekend trip" |
2021-07-02 |
244.7 |
10.925 |
22.4 |
"84,607 Tops gas on way to camps" |
2021-07-09 |
199.4 |
8.268 |
$2.939 |
24.12 |
"84,807 fill up at Fastrac before latest camping drive...was $0.20 off for the summer....woot." |
2021-07-17 |
296.4 |
12.004 |
$3.198 |
24.69 |
"85,103 Sunoco out in the Finger Lakes...on way home from Deb and Matt's" |
2021-08-01 |
286.1 |
12.958 |
22.08 |
"85,389 Marathon Penfield" |
2021-08-13 |
196.2 |
12.455 |
$3.099 |
15.75 |
"85,632 Mobil fill up before HHI trip
Awful mileage due to over an hour of idling in the heat waiting on COVID tests this tank" |
2021-08-14 |
294.2 |
12.026 |
24.46 |
"85,926 Sheetz in PA" |
2021-08-14 |
281.1 |
10.805 |
26.02 |
"86,207 Exxon" |
2021-08-14 |
239.3 |
8.67 |
$2.889 |
27.6 |
"86,447" |
2021-08-18 |
257.3 |
14.17 |
18.16 |
"86,704" |
2021-08-21 |
121.3 |
6.049 |
$3.058 |
20.05 |
"86,825 Shell" |
2021-08-21 |
254.9 |
10.936 |
23.31 |
"87,080" |
2021-08-22 |
321.3 |
12.716 |
25.27 |
"87,402 Sheetz" |
2021-08-23 |
12.35 |
24.45 |
"87,704 Marathon" |
2021-09-10 |
306.8 |
14.217 |
21.58 |
"88,011 Fastrac on the way to Buttermilk Falls camp" |
2021-09-21 |
313.5 |
13.715 |
22.86 |
"88,324 Marathon" |
2021-10-24 |
246.7 |
12.473 |
19.78 |
"88,571 Fastrac" |
2021-11-13 |
261.1 |
13.087 |
19.95 |
"88,832 Marathon" |
2021-11-26 |
242.1 |
11.574 |
20.92 |
"89,074 Kwik Fill in Ellicotteville" |
2021-12-06 |
217.7 |
9.763 |
$3.539 |
22.3 |
"89,292 Mobil" |
2021-12-26 |
225.1 |
12.222 |
18.42 |
"89,517 Mobil Webster" |
2022-01-16 |
183 |
10.489 |
17.45 |
"89,700 Marathon 441" |
2022-02-01 |
211 |
11.739 |
17.97 |
"89,911 Marathon 250/441
Guesstimate on mileage as I disconnected battery for Repair cycle. So trip meters all reset." |
2022-02-16 |
204 |
11.582 |
17.61 |
"90,115 Marathon
another estimate, replaced the battery so trip meters reset.
Installed New NGK Laser Iridium plugs so hopefully some MPG improvements to come." |
2022-03-08 |
233.8 |
12.166 |
$4.298 |
19.22 |
"90,349 Fastrac Henrietta. Gas prices gone cray" |
2022-03-20 |
221.8 |
10.423 |
$4.399 |
21.28 |
"90,571 Marathon" |
2022-04-10 |
182.9 |
9.311 |
$4.199 |
19.64 |
"90,754 Mobil Fairport
Seafoam treatment. Summer tires back on" |
2022-04-20 |
213.2 |
9.259 |
$4.299 |
23.03 |
"90,967" |
2022-04-22 |
231.7 |
9.305 |
$2.929 |
24.9 |
"91,199" |
2022-04-22 |
151.3 |
5.8 |
$4.199 |
26.09 |
"91,350" |
2022-05-06 |
329.8 |
13.398 |
$4.359 |
24.62 |
"91,680 Marathon" |
2022-05-23 |
254.1 |
11.615 |
$4.899 |
21.88 |
"91,934 Marathon" |
2022-06-10 |
207.5 |
9.471 |
$4.899 |
21.91 |
"92,142 Fastrac on way to A-Bay" |
2022-06-12 |
250.1 |
9.231 |
$4.799 |
27.09 |
"92,392 Fastrac on way home from A-Bay. All light cruising" |
2022-06-19 |
256.3 |
10.071 |
$5.089 |
25.45 |
"92,649 Mobil - drive to Tree House" |
2022-06-21 |
189 |
7.249 |
$4.649 |
26.07 |
"92,838 fill up before road trip back home" |
2022-06-23 |
346.9 |
13.119 |
$4.699 |
26.44 |
"93,185" |
2022-07-16 |
205.1 |
9.773 |
$4.799 |
20.99 |
"93,390 Marathon 441" |
2022-07-30 |
310.7 |
13.577 |
$4.699 |
22.88 |
"93,701 Marathon 441" |
2022-08-17 |
319.7 |
13.635 |
$4.239 |
23.45 |
"94,020 Mobil" |
2022-08-20 |
233.3 |
8.878 |
$4.199 |
26.28 |
"94,254 Sheetz" |
2022-08-20 |
151.8 |
5.462 |
27.79 |
"94,406 Sheetz MD" |
2022-08-20 |
150.5 |
6.502 |
$3.698 |
23.15 |
"94,580" |
2022-08-20 |
367.4 |
13.574 |
$3.598 |
27.07 |
"94,947" |
2022-08-27 |
292.1 |
12.9 |
22.64 |
"95,239" |
2022-08-28 |
238.2 |
10.528 |
22.63 |
"95,477 Shell NC" |
2022-08-28 |
157.4 |
6.192 |
25.42 |
"95,635 Pilot NC" |
2022-08-29 |
278.4 |
10.844 |
25.67 |
"96,271 Mobil Henrietta" |
