2015-02-17 |
531.9 |
9.984 |
$2.279 |
53.28 |
2015-02-24 |
551.6 |
9.831 |
$2.26 |
56.11 |
"Dead battery, need to get a chance to recharge" |
2015-03-06 |
566.3 |
10.047 |
$2.319 |
56.37 |
2015-03-15 |
577.9 |
$2.19 |
60.2 |
"200 mi normal driving, 400 mi Highway - to and from Springfield" |
2015-03-26 |
581.9 |
9.68 |
$2.21 |
60.11 |
2015-04-05 |
607.8 |
9.73 |
$2.3 |
62.47 |
"FCD is wrong by 2.5 MPG" |
2015-04-10 |
625.8 |
9.454 |
$2.369 |
66.19 |
"FCD reads 65.5" |
2015-04-15 |
659.7 |
10.086 |
$2.5 |
65.41 |
"69.3 FCD" |
2015-04-29 |
654.1 |
9.748 |
$2.4 |
67.1 |
"68.3 FCD
No Battery" |
2015-05-04 |
556 |
8.162 |
$2.4 |
68.12 |
"69 FCD. Mostly highway 65-70 MPH. Trip to Cincinatti
No Battery" |
2015-05-11 |
651.5 |
9.7 |
$2.5 |
67.16 |
"FCD 69
No Battery" |
2015-05-19 |
627.2 |
9.876 |
63.51 |
"67.4 FCD
100 mi of hard driving at 75-78 MPH avg (I was late)
No Battery" |
2015-05-29 |
632.4 |
8.97 |
70.5 |
"69.3 FCD" |
2015-06-09 |
664.2 |
10.217 |
65.01 |
"69.7 FCD" |
2015-06-18 |
679.6 |
9.377 |
$2.74 |
72.48 |
"73.5 FCD" |
2015-06-29 |
660.7 |
9.71 |
$2.87 |
68.04 |
"69 FCD" |
2015-07-05 |
660 |
9.92 |
$2.9 |
66.53 |
"69 FCD
no battery" |
2015-07-13 |
630.8 |
8.993 |
$2.6 |
70.14 |
"71.6 FCD
The battery is almost done with reconditioning!" |
2015-07-24 |
695.2 |
10.122 |
68.68 |
"71.4 FCD No Batt" |
2015-08-03 |
670.4 |
9.26 |
$2.12 |
72.4 |
"75.6 FCD
No Batt." |
2015-08-27 |
671.1 |
9.68 |
$2.44 |
69.33 |
"72.3 FCD No Batt" |
2015-09-18 |
642.5 |
10.165 |
$2.2 |
63.21 |
"64.6 FCD
Vacation to Hocking Hills - Driving pretty hard the entire way. Lots of up and down.
No batt." |
2015-09-30 |
660.4 |
9.488 |
$2.179 |
69.6 |
"68.8 FCD - Getting colder : /
Battery back in! Reconditioned! Works!" |
2015-10-21 |
653.2 |
10.119 |
$2.2 |
64.55 |
"Mostly cold. Also did a decent bit of city driving.
Battery is back in and working well. Only two recals - haven't charged it since i put it in (3 weeks ago)!" |
2015-10-26 |
622.9 |
9.562 |
$2.069 |
65.14 |
"68.1 FCD
Faster Highway driving. Front right bearing is going bad, started growling. Still cold out - had to scrape my car off twice from the frost." |
2015-11-12 |
616.1 |
9.534 |
$2.1 |
64.62 |
"67.6 FCD
Getting even colder out. MPG is suffering : /
battery pack has been holding up quite well
Also, it wasn't the bearing - I replaced it... I suspect an out of balance wheel or a bad CV axle." |
2015-11-23 |
630.2 |
10.32 |
$1.74 |
61.07 |
"63.4 FCD
Someone smashed into the back of my car when it was parked outside my house... Now my insight looks sad. The bumper is all messed up, the fender is bent, the fuel gauge only displays the first quarter tank, and my insurance doesn't cover hit and runs...
It is still going strong though! 450 miles on ""E"" is a new record for me!" |
2015-12-04 |
551.9 |
9.434 |
$1.74 |
58.5 |
"61.1 FCD
Quite cold out. Winter is coming! Car is solid even after the accident." |
2015-12-14 |
614.9 |
9.916 |
$1.77 |
62.01 |
"62.7 FCD
IMA and CEL at the end of this tank. Batt pack out of balance.
An overnight charge and a reset worked well." |
2015-12-28 |
636 |
$1.82 |
63.6 |
"62.2 FCD" |
2016-01-23 |
510.6 |
10.05 |
$1.49 |
50.81 |
"Started driving purpcar again... and then I found out the front bearings were bad. Now I am back to driving the insight through the winter : /
57.3 FCD" |
2016-02-17 |
524.3 |
8.65 |
$1.55 |
60.61 |
"63.4 FCD
Winter has not been nice..." |
2016-03-01 |
601.4 |
9.57 |
$1.62 |
62.84 |
"63.4 FCD" |
2016-04-08 |
567.1 |
8.74 |
$1.96 |
64.89 |
"64.8 FCD
Waiting for Ohio weather to get warmer, I have a bunch of repairs to do that I have been putting off!" |
2016-04-18 |
554.6 |
8.416 |
$2 |
65.9 |
"65.8 FCD
Oil change 0w20 full syn, new oil filter, new air filter, repaired exhaust manifold clamp to cat, greased some stuff, re-aired tires to 50 psi" |
2016-05-08 |
545.5 |
8.09 |
$2.09 |
67.43 |
"68.8 FCD
Almost a whole month without filling up!" |
2016-05-31 |
607.4 |
9.28 |
$2.36 |
65.45 |
"69 FCD
Driver rear brake line went out! Installing a new one was a pain!" |
2016-06-15 |
486.2 |
6.839 |
$2.34 |
71.09 |
"73.7 FCD
Getting a bearing noise. I checked the suspected wheels, they felt fine. I think it might be the input shaft bearing on the transmission : /" |
2016-07-06 |
484 |
6.527 |
$1.98 |
74.15 |
"69.7 FCD
Half the tank has been without the IMA - moving houses and haven't bothered to balance it out..." |
2016-07-22 |
461.2 |
6.979 |
$2.059 |
66.08 |
"77.5 FCD
Columbus and back twice" |
2017-05-31 |
675.8 |
9.645 |
70.07 |
"72.1 FCD
Columbus and back once
Rebuilt the tranny! New bearings and modified 2nd and 3rd syncros. No more 2nd gear grind!" |
2017-06-28 |
663 |
9.126 |
$1.94 |
72.65 |
"75.2 FCD
Still no grid charging - its going well!" |
2017-07-17 |
620.6 |
9.525 |
$2.16 |
65.15 |
"69.7 FCD
Battery finally went out of balance. Didn't have time to charge/reset it. The car is woefully underpowered without it : /" |
2017-08-18 |
648 |
9.318 |
$2.12 |
69.54 |
"71.9 FCD
Ended up resetting the battery - forgot to turn the pack off while charging. Took a bit of fiddling to get it to do a recal." |
2017-09-19 |
625.9 |
10.061 |
$2.45 |
62.21 |
"68.8 FCD
Lots of trips to and from Columbus. I need to do some repairs : / battery not on for most of this tank." |
2017-09-21 |
654 |
68.84 |
"70.9 FCD
Battery off, need to quit being lazy" |
