2015-03-23 |
458.25 |
37.89 |
$2.824 |
12.09 |
"First actual MPG figure. Lots of idling on this tank and cold weather, and a leaky fuel injector early on in the tank.
Pumped at Brookville, PA Getgo Pump 10 with $13 off the tank from FuelPerks. No biodiesel added. ScangaugeII plugged in, set up for ""Diesel A"" but not calibrated.
Add: Last tank without actual MPG figure but 28.5 gallons (or thereabouts) added at the cost of $94.31 or so.
Note: Fuel tank had a hole in it near the top." |
