2015-06-01 34 1.12 $2.89 30.36 "The bike was not happy about life
Evidently V4 engines run really smooth on two cylinders. Luckily the main jets are ""slow"" so it runs lean at 4k RPM at the same time the ignition coil for cyls 2 & 4 poops out
O_o
Hopefully the cobwebs have been knocked loose.
I don't want to have to take the carbs (all 4) apart again..... ever"
