2015-08-28 |
577.11 |
11.374 |
50.74 |
"First tank of the second year! This tank had 0 lean burn miles though. This tank will be a starting point/ base tank. This is what is possible without LB
93 octane... is ridiculous! +$0.69 price difference between 93 and 87 around here!" |
2015-09-03 |
422.918 |
8.122 |
$2.019 |
52.07 |
"Another tank without lean burn! Still going strong with the 50 mpg game!
Trying 87 octane this time around." |
2015-09-10 |
452.48 |
9.052 |
$1.989 |
49.99 |
"1st gas for under $2.00/gal. in quite some time!
My pump was broken this time around. I went to another pump and parked the same way as usual to minimize differences. It turns out that the pump was acting weird? It was s-s-s-looow on the usual lowest setting, and as the fuel got close to it, it just slowed down the stream! I'm calling this a slight overfill.
SG said 8.56 gals. needed for 51.8 mpg" |
2015-09-14 |
342.578 |
7.213 |
$2.509 |
47.49 |
"First tank with lean burn. It was on after the 100 mile mark.
I honestly don't know what to say right now. This is a major disappointment.
93 octane
SG said 56.6 mpg, 5.9 gallons needed." |
2015-09-17 |
216.3 |
4.263 |
$2.509 |
50.74 |
"A bit better this time. I'm still trying to figure the lean burn out.
SG said 58.3 mpg
93 octane" |
2015-09-25 |
468.238 |
9.348 |
50.09 |
"I had to increase the fuel offset to over 50% tonight! My SG still said 56.8 mpg for the tank. I'm in need of a MPGuino...
93 Octane" |
2015-10-03 |
498 |
10.542 |
47.24 |
2015-10-06 |
351.436 |
7.202 |
48.8 |
2015-10-13 |
474.933 |
9.163 |
51.83 |
"Mpgs are getting better and better the more I get to use lean burn and learn it I added a near 100% grill block this tank along with modifying my rear fender skirts.
SG said 54.3 mpg
Fuel offset upped to 61%!" |
2015-10-18 |
334.802 |
6.886 |
48.62 |
"One morning of oversleeping and driving like a normal person for work dropped this tank an easy 4 mpg. It is a shame, but it is motivation to do very well on the next tank
93 octane" |
2015-10-21 |
305.807 |
6.281 |
48.69 |
2015-10-27 |
353.805 |
7.043 |
50.23 |
"Warmer temps helped this tank out. I had a fueling problem one night that dropped the SG by 2 mpg.
SG said 52.0 mpg
Fuel offset increased to 62.8%
Tire pressure increased to 68.5 psi for next tank
93 octane" |
2015-11-01 |
570.003 |
11.384 |
50.07 |
"Switched back to Pump #8 @ RPCS for this fill. Idk if that threw off the numbers, but they were almost spot on with my SG.
I'm surprised that this tank was as high as it is. I did a couple 2nd gear pulls up to 5000 rpm just cause (car pulls great BTW!) And expected a drop from the previous tank. I'm not complaining though
87 Octane" |
2015-11-06 |
366.745 |
7.598 |
$2.159 |
48.27 |
"This tank had a bad start with the first 80 miles averaging 39 mpg. Lots of rain and short trips held this tank back. Finished out with a 58.2 trip to the pump! Lots of mods done during this tank as well.
87 octane" |
2015-11-08 |
246.154 |
5.094 |
$2.159 |
48.32 |
"Disappointed that this tank was so low. The SG said 54.1 mpg.
87 octane
Fuel offset upped to 75.7%!!!" |
2015-11-12 |
287.82 |
5.667 |
50.79 |
"Happy with this fill! Looks like last tank was an overfill. This is my 8th fill over 50 mpg
Tire size multiplier of 1.025 (2.5%) over stock odometer
87" |
2015-11-17 |
462.28 |
9.607 |
48.12 |
"Gas under $2, woohoo!
This tank had many short trips and cold starts that put a damper on getting higher mpg. I put the knock senator back in and I am still getting excellent FE
87 octane
451 miles x 1.025 = 462.28 miles driven" |
2015-11-21 |
326.258 |
6.901 |
47.28 |
"Lower than I want, but still great for the cooler weather.
87 octane" |
2015-11-24 |
452.281 |
9.24 |
48.95 |
"Trying 93 octane to reduce knock!" |
2015-11-27 |
258.608 |
5.461 |
47.36 |
"Early fill to see how modifying the LB box was helping. It is inconclusive due to rushing on Thanksgiving Day and a full throttle 10-70 mph roll. Good to see the car still has good power for its age and mileage!
93 octane" |
2015-12-04 |
276.34 |
5.766 |
47.93 |
"I am doing a short fill this time because I will be switching stations to cut $0.30/gal off!
93 octane" |
2015-12-18 |
529.823 |
11.271 |
$2.209 |
47.01 |
"Going to new pump from now on! Wally World's 93 is MUCH cheaper than RPs, so I will get gas from pump #7 from now on.
I hit a deer this tank and had considerable front end damage. I didn't expect great FE, but I didn't give up
New fill method: fill till turn off on lowest setting, then to closest .x0
93" |
2015-12-22 |
295.354 |
6.251 |
$2.159 |
47.25 |
"It is awesome when the WalMart gifts card you receive for Christmas save youoney at the pump! $0.18 this time
93" |
2015-12-29 |
443.518 |
9.109 |
$1.789 |
48.69 |
"Filled with 87" |
2016-01-04 |
298.788 |
6.555 |
$1.769 |
45.58 |
"Cold weather has arrived!
87" |
2016-01-12 |
504.71 |
10.412 |
$1.729 |
48.47 |
"A woman got my usual pump, so I had to go to the one behind her. I do believe that this is a underfill, and it will show next tank.
The tank had a lot of Interstate driving, with the lean burn tuned to run ~16.1-16.5 AFRs at 55-65 mph.
All on 87 octane" |
2016-01-18 |
512.5 |
11.793 |
$2.079 |
43.46 |
"So this tank definitely is going to average put my previous tank... so much for keeping my tank mpg over 45 this year lol.
I had to get 93 octane due to Wally World being out of 87, still decently priced." |
2016-01-24 |
476.88 |
10.295 |
$1.739 |
46.32 |
"Pretty good mpgs even with a massive cold snap, short trips and a snow/ice storm!
I have had to go back to the Hess/Speedway station Pump #1 due to Walmart closing up... so this tank has location bias, but next tank will show more accuracy.
87" |
2016-01-30 |
454.74 |
9.373 |
$1.739 |
48.52 |
"Still doing well!
87 octane" |
2016-02-07 |
495.28 |
11.184 |
$1.699 |
44.28 |
2016-02-14 |
451 |
10.474 |
$1.699 |
43.06 |
"Valentine's fill! The cold is hurting me as far as max mpgs, but I can't be too picky
87" |
2016-02-22 |
444.133 |
9.827 |
$1.699 |
45.2 |
2016-03-03 |
447.11 |
10.288 |
$1.759 |
43.46 |
