2016-02-29 |
532.5 |
8.89 |
59.9 |
"FIRST MEASURED/RECORDED FILLUP
At this fillup, I added 4 oz. Marvel Mystery Oil to the fuel tank. First time doing that on this car. MMO label instructions: 4 oz per 10 gallons fuel.
I did my first Insight oil change - also fixed up the underbody front aero panels - shortly before this fillup, at 163,516 miles on the odometer. Mobil 1 full synthetic 0-20, with 6 oz Marvel Mystery Oil included. And a brand new Honda oil filter. Prev. owner had changes done at Honda shop. They used Honda filter BUT they overfilled the oil (or someone did), it was a good 3/4"" over the top dipstick mark.
TABLE OF MARVEL MYSTERY OIL GALLON EQUIVALENTS
Add these amounts to pump readout when adding MMO to the gas at fillup.
1 oz. = 0.008 gal.
2 oz. = 0.016 gal.
3 oz. = 0.023 gal.
4 oz. = 0.031 gal." |
2016-03-03 |
571.6 |
9.509 |
60.11 |
"Filled high test at Glastonbury Shell, Rt 2.
Fil amount includes 4 oz MMO.
Fill included trip to Port Washington, NY.
FCD: 62.0 mpg, 581.6 mi = 9.38 gal est." |
2016-03-09 |
581.6 |
9.269 |
62.75 |
"FCD said 62 mpg = estimated 9.38 gal.
Filled up regular at Henny Penny Shell, Wtfd. Rte. 85.
Did not use Marvel Mystery Oil in the fuel this time.
Avg spd something like 39 mph. Definitely under 40. Civic and Accord were usually 42-43 mph. average." |
2016-03-15 |
534.5 |
8.426 |
$2.159 |
63.43 |
"The prior fill included no MMO. Lean burn behavior got worse and worse as the tank wore on. Instead of holding lean burn at 90-92 % load, it got shaky at 80-82%. I finally decided to fill a bit early, and add MMO again. This time, just 87 octane instead of the previous high test.
I've already driven about 40 mi. on the new fill with MMO. Lean burn is improving. Not yet back to as smooth as things were before I restored the MMO to the fuel.
I dunno, and don't care, whether the MMO is cleaning the EGR valve or the passages, or the injectors, or the LAF sensor (I think that's what it is) or the oxygen sensor. Whatever it's doing, it restores lean burn. I plan on cleaning the passages but this restores lean burn much faster and easier." |
2016-03-22 |
637.9 |
9.844 |
64.8 |
"Low fuel light came on at ?1 bar? I drove about 2-3 miles to nearest Shell station.
FCD said 65.5 mpg.
ScanGauge: avg 41 mph, 57.6 mpg (it doesn't measure lean burn)
Fuel qty here includes the 4 oz MMO I added in this fill." |
2016-03-31 |
666.8 |
10.945 |
60.92 |
"I didn't really get 666.8 mi on the tank. I put in 4.505 gallons yesterday and topped it up fully today. Kept the mileage counter going and logged it all as one fill.
Avg spd. 39 mph.
FCD: 666.8 mi, 65.0 mpg = est. 10.258 gal.
FCD fuel estimate has been consistently low. I sometimes smell fuel when driving. Hmmm....." |
2016-04-02 |
117.7 |
2.243 |
52.47 |
"Interesting. Even when this car was spitting fuel into the air, it still got 52 mpg!
Fill includes about .5 ounce of MMO, but I didn't include that amount in the fuel consumption number. It was already bad enough.
Discovered and repaired fuel leak at the usual location for Gen 1 Insights: within the grip area of the clamp holding lines to firewall, passenger side. My friend Rob Bareiss guided, assisted and provided invaluable input based on his many years of experience.
After completing the repair I thought it appropriate to top it up, so the subsequent tank would reflect the new status and not the leak. That turned out to be a good move. The car took 0.51 GALLONS more than the FCD numbers indicated.
FCD fuel estimate: 1.733 gal (67.9 mpg showing on display)
ScanGauge avg speed: 34 mph" |
2016-04-14 |
1204.5 |
18.234 |
66.06 |
"FCD reported 63.4 mpg.
No, I didn't have a 1200 mile tank. And tank holds only 10.6 gallons (per Honda). I added fuel twice and kept the trip odometer going. This was in prep for the Green Grand Prix. Running the 10% ethanol fuel out of the system, to fill with the max possible amount of pure gas at my first non-ethanol fuel stop. That fill was 8.961 gallons at the last fuel stop in this fill. Done at Stewart's Shop #250 in Duanesburg, NY. Total fill amount here includes 8 oz. Marvel Mystery Oil." |
2016-04-15 |
270.6 |
4.7 |
57.57 |
"Filled at Lakes Gas Sat. at 12:18 pm, after the road rally.
I zeroed Trip A for the road rally. My recollection is, it showed about 55 mpg at the end of the rally. Sorry I didn't note the FCD's data for Trip B at this fillup.
Includes (estimate) of 2 oz MMO." |
2016-04-16 |
294.5 |
4.412 |
66.75 |
"Includes the (likely overfilling) fill at TOPS just before the WGI track event, plus my final NY non-ethanol fill in Monticello on Apr. 16 at 2:24 p.m.
Fill record also includes 2 oz. MMO.
FCD showed 78.9 mpg over 90.3 miles in the GGP event. This is track miles only.
I strongly suspect the volunteer overfilled the tank at TOPS. I saw nothing spilling over, but he may have flooded the evap system, causing a subsequent loss of fuel and/or fuel vapors. Or maybe his ultra-slow fill just filled it higher than I ever do. It was filled at Lakes 4.5 miles prior to the fill at TOPS. Obviously I didn't use 1.401 gallons to drive those 4.5 miles. Lakes guy stopped at the first click, TOPS guy filled very slowly. I guess he was trying to do me a favor." |
2016-04-20 |
613.2 |
9.347 |
65.6 |
"FCD estimate 9.03 gal. Based on:
613.2 milies, FCD 67.9 mpg.
avg speed 43 mph
This was the first 10% ethanol fillup (regular grade) following the Green Grand Prix. It includes the approx. 350 mile trip home from NY State.
Data includes the MMO added at fill time." |
2016-04-25 |
414.2 |
6.194 |
66.87 |
"avg speed 39 mph
Filled with 93 octane Sunoco; research indicates overseas Insight manuals specified 91 octane. Only US was specd for 87. Sheeesh.
Includes 2.5 oz. Marvel Mystery Oil in the fuel." |
2016-05-03 |
742.4 |
11.691 |
63.5 |
"FCD:
742.4 mi, 65.3 mpg
Avg spd: 39 mph
Filled with 93 octane Sunoco + MMO.
After trip up to Boston in rain. Lousy traffic." |
2016-05-09 |
581.3 |
8.544 |
68.04 |
"93 octane, like last time. Shell gas.
Avg. speed 40 mph
FCD Estimated Gallons: 8.715
Weather has finally warmed up (again; we had a temporary warmup a couple weeks ago). This tank was begun in/near Bellingham, MA after my trip up to Boston." |
2016-05-17 |
621.1 |
9.265 |
67.04 |
"Sunoco high test
Avg speed 39 mph
8.96 gal estimated by FCD (est. 69.3 mpg)
9.265 gal. incl. 3.6 oz MMO" |
2016-05-23 |
636.8 |
9.568 |
66.56 |
"FCD estimate 68.3 mpg = 9.32 gal. est.
Avg speed 37 mph
ODO reading 172,029 mi.
Shell high test, Waterford Rte. 85
Fuel qty incl. 4.3 oz MMO. I only planned on about 3.7 oz but I went over a bit." |
2016-05-29 |
683 |
10.132 |
67.41 |
"High test at Hillsborough, NJ Exxon.
Includes 3.6 oz MMO.
Needed a/c for trip to NJ; it was hot out! Got about 65 mpg on that trip.
Lost ScanGauge data due to 12V battery went flat when I left the lights on during the week, at work. Got the miles from the main odometer because... I managed to zero out the B trip clock in mid-tank." |
2016-06-03 |
584.5 |
8.819 |
$3.089 |
66.28 |
"Fill amt includes 3.5 oz Marvel Mystery Oil.
FCD estimate 8.52 gal.
Odo reading 173,296
Avg speed 42 mph, includes trip back from NJ.
Some a/c use in this tank.
Shell on Rt 85, Waterford CT" |
2016-06-09 |
644.5 |
9.457 |
68.15 |
"Rte 85 Shell, Waterford CT
Avg spd 39 mph
Fill data include 3.5 oz MMO
FCD estimate 68.3 mpg = est 9.436 gal." |
2016-06-14 |
572.4 |
8.824 |
64.87 |
"Includes NY trip with a/c. Plus a commute run with a/c. Warmer weather is nice for the engine but if it's hot enough to need a/c, there's about a 10 mpg hit from that.
FCD estimate 66.2 mpg.
Avg spd 40 mph.
174,513 ODO at fullup
87 octane again. I like the results better than hi test." |
2016-06-21 |
678.8 |
9.824 |
$2.449 |
69.1 |
"some a/c used in this tank.
40 mph avg speed
Est. 68.8 mpg on FCD
Est. 9.866 gallons from FCD - just about dead on vs actual!
Odo at 175,192
Filled at Shell, Glastonbury - Chestnut Mart - Main St. by DD." |
2016-06-27 |
549.6 |
8.379 |
65.59 |
"Filled 9 am at Shell, Rte 85, Waterford, CT.
avg speed 40 mph
87 octane
odo reading 175,742
FCD Estimate: 8.12 gallons
Fill includes 1.6 oz MMO. This is now reduced to 1/2 strength, 2 oz /10 gal fuel, on account of I cleaned the EGR passages two days before the fill.
The new ""B"" Trip was inadvertently ZEROED after 40 miles. Add to B trip value at next fillup.
Tank included a FAST trip up to Bloomfield/West Hartford for P&W United Chorus, with A/C. Only 61 mpg." |
2016-07-05 |
608.6 |
8.66 |
70.28 |
"No MMO used in this fill.
Added 40 mi. to Trip B number due to inadvertently zeroed earlier (see note in previous fill).
Avg speed 38 mph" |
2016-07-11 |
592.4 |
8.659 |
68.41 |
"No MMO this fillup.
87 Octane
Rte 85 Shell, Waterford, CT.
FCD said 71.2 mpg = 8.32 gal.
Actual was .34 gal more.
Odo: 176,943" |
2016-07-18 |
634.6 |
8.791 |
72.19 |
"89 octane this time.
I think it was $.40/gallon more expensive!
FCD: 71.9 mpg, calculates out to 8.826 gallons.
40 mph avg speed
Mostly pretty warm dry weather. I think no ac at all in this tank. IMA battery issues showed up at the end of the tank but it ended up being an excellent tank anyway.
Note - IMA light cleared after pulling the appropriate under dash fuse. Frequent recalls seem to be happening again but at least the IMA light seems to be staying off, now about 150 miles into the next tank." |
2016-07-25 |
653.1 |
9.038 |
72.26 |
FCD estimate 74.0 mpg = 8.826 gal
Avg speed 41 mph.
Prior to this tank, did a slow charge of hybrid battery, till V started dropping very slowly. Also did a BCM reset which pretty much ended the constant pos and neg recals it had been getting.
Weather is hot and I rarely use ac." |
2016-07-30 |
505.2 |
7.032 |
71.84 |
"Seaport Shell on Rt 27, Mystic
FCD's est mpg: 73.5 = est 6.873 est. gal.
Filled before trip to NY.
Aired up the tires at this fill - were at about 40, I put them to about 48 psi." |
2016-08-01 |
315.6 |
4.896 |
64.46 |
"Filled following trip to NY.
NY trip seriously hurt my mpg.
Avg speed for return trip (highway) was 53 mph, much faster than my usual ~40 mph tank average. Actual highway speeds were mostly between 60-70. It's just that I usually drive a lot slower than that on the highway!
I drove about 30 miles on smaller roads in NY with a/c, many hills, stop signs, lights, and traffic. Fuel economy on those local trips averaged about 45 mpg, far below anything I see in my usual travels near home. So I decided to let this NY trip show up as its own low-mpg tank.
Trip up to work the next day (most of which is in the next tank), went fine. About 75-76 mpg on the FCD. So it's not the car, it's the circumstances." |
2016-08-08 |
655.9 |
9.2 |
$2.169 |
71.29 |
"Shell station, Main St, Glastonbury.
Nice level pavement.
Avg speed 40 mph
Est. gallons: 8.98, aka 73.0 mpg
Been having some battery issues, learning how to cope using Calpod. Been able to avoid a/c use, mostly." |
2016-08-17 |
598.8 |
8.543 |
70.09 |
"Filled at Rte 83 Shell in Waterford CT.
Estimated mpg: 70.336 = 8.51 gal.
Avg speed: 41 mph.
Aug 7 (approx.) I installed my dash top LED display of battery cooling fan voltage. Around that time, I also shifted to greater use of EOC. Less use of battery sometimes requires more fuel ""up front"", but there can be a net gain in mpg because the IMA system reportedly is only 70% efficient. In my case with an ailing IMA battery, it's probably even less efficient." |
2016-08-20 |
609.8 |
8.242 |
73.99 |
"Estimated mpg on FCD, 75.4 mpg =
Estimated gallons: 8.088
43 mph avg
Not-too-brutally hot weather has let me avoid ac use.
Keeping the IMA SOC up by use of Calpod also helps a lot.
And I've been doing more EOC, since using less assist requires less regen. Just avoid assist as much as possible.
[on 8-24-16, checked receipt and found the miles was 609.8, not 608.8 as recorded here. Edited record to correct it.]" |
2016-08-25 |
633.3 |
9.025 |
70.17 |
"Filled at Shell, Waterford, Rte 85.
FCD estimated mpg: 70.0
FCD est. gallons: 9.047
Avg speed: 40
This tank was started at Exit 62 rest stop on the way in to NY. So, this tank includes round trip to PW from home. NY trip didn't hurt mpg as badly as the last one, because I didn't do local errands in Insight, AND I only used ac for a short while on this trip." |
2016-09-06 |
680.9 |
10.574 |
64.39 |
"Avg speed 39 mph.
Tank includes a NY road trip.
FCD mpg estimate 65.5 mpg" |
2016-09-08 |
361.5 |
5.497 |
65.76 |
"89 octane at Shell on Rte 85, Waterford.
Fill qty includes 4 oz Marvel Mystery Oil.
avg speed 40 mph
FCD Estimate 68.8 mpg = 5.254 gal estimate
Filled on Thursday evening, prior to trip to NY which began after work Friday." |
2016-09-13 |
565.7 |
8.607 |
65.73 |
"Fill includes 3.5 oz MMO
40 mph avg speed.
FCD estimate 65.5 mpg = 8.637 gal est.
Actual: 65.73 mpg
Filled at Shell in Mystic, Rte 27, by McDonalds.
Fill includes round trip to NY
NY trip: 60 mpg going there, 70.7 mpg coming back. AC and faster going in, no ac and slower coming back." |
2016-09-16 |
329.8 |
5.315 |
$2.339 |
62.05 |
"Filled at exit 62 rest stop on the way to NY.
Est MPG 66.0=4.997 gal est FCD
Avg speed 39 mph
#s include 2 oz MMO" |
2016-09-23 |
717.1 |
10.715 |
$2.329 |
66.92 |
"Did a partial fill, 5.003 gal. Then filled fully a day later at lower priced Shell station in RI.
Avg speed 40 mph
Est mpg 67.6 = est gal 10.608 (pretty close!)" |
2016-09-27 |
595.6 |
9.191 |
64.8 |
"Groton Shell, corner Rte 117 & Rte 1.
Avg Spd 39 mph
Est mpg 65.0 = 9.163 gal est.
Fill includes 3.67 oz MMO (calculated target qty)
Tank included round trip to NY. IMA battery trouble light came on, as I entered the NYC area. Did a grid charge in PW, NY. It ran much better on the trip home. had to do another grid charge Monday evening, Sep. 26.
Warranty replacement battery is due in Friday Sep. 30." |
2016-10-02 |
574.7 |
8.601 |
$2.249 |
66.82 |
"Oriental-owned Shell at I-95 exit 40 northbound.
46 mph vag speed - fast!
FCD Estimate 67.6 mpg. = 8.501 gal estimated
Fill amt. includes 3.4 oz MMO, the calculated amount.
I WILL EDIT THE FUEL QTY TO BE THE FCD ESTIMATE PLUS 0.1 GALLON.
I'M CONVINCED THE STATION OVER-REPORTED THE FUEL QTY. IVE SEEN SOME STATIONS DO THIS.
IT'S NOT DUE TO IMA ISSUES SUCKING DOWN FUEL - ANY ADDITIONAL FUEL USED WOULD HAVE BEEN METERED BY THE CAR'S COMPUTERS.
PUMP FUEL QTY: 9.204 (including my added MMO)
MY RECORDED FUEL QTY: 8.601 gal.
I blame the low mpg primarily on assumed fill pump inaccuracy. I've seen this before at some stations, but not yet at a Shell. Next fill could turn out to be UNDER the estimate by a matching amount. Or, the pump was just plain inaccurate. I've seen THAT before, and always off in that direction.
There also are these three things:
1) High average speed. Usually the tank avg is 39-40 mph. Not sure how I ended up at 46. I think I must have changed my driving pattern.
2) some rain
3) IMA battery on its way out. I was getting an IMA light every 1-2 days at the end. I might even have had 2 in one day. Approx 60 mi. after this fill, I changed out the IMA battery for a warranty replacement from Bumblebee." |
2016-10-08 |
571.6 |
8.204 |
69.67 |
"Fill includes 3.25 oz MMO
Avg speed 43 mph
FCD's est. mpg: 70.2 = 8.14 gal estimate
All but about 65 miles were driven with NEW REPLACEMENT IMA BATTERY by Bumblebee. Not sure if its brand new or a refurb.
MPG definitely is up." |
2016-10-13 |
546.6 |
8.397 |
65.09 |
"Estimated gallons: 8.084
Avg speed 42 mph
Fill data includes 4 oz MMO.
I poured in more than the 3.2 oz that I planned on. :-(
Weather is colder now. Some mornings in the upper 30's. Some daytime highs still in the 70's.
I could save some fuel by not allowing heat till its warmed up. Not sure if I want to do that.... and it's not even winter yet." |
2016-10-14 |
512.9 |
8.084 |
63.45 |
"Shell station at Rtes 1/117 in Groton
Estimated mpg: 68.3 Est. gallons: 7.51 gal
Sheeesh. Final amount was well over the FCD estimate.
It's been getting colder here." |
2016-10-19 |
600.7 |
8.994 |
66.79 |
"Shell station, Rte 85, Waterford CT
avg speed 43 mph
FCD MPG: 69.3 = 8.668 gal estimate
Actual, 8.994 = delta of 0.326 gal
Some great runs, 72-74 mpg. Some other runs, only in the high sixties. I blame the weather - somedays are like spring or late summer, other days are pretty cold or even rainy." |
2016-10-24 |
551.9 |
8.711 |
63.36 |
"Shell Rte 85, Waterford, CT
FCD estimate 65.5 mpg, or 8.426 gal.
Fill includes a calculated 3.37 oz. MMO.
40 mph avg speed." |
2016-10-29 |
512.5 |
8.243 |
62.17 |
"Mobil at Branford rest stop on Southbound I-95
43 mph avg speed.
FCD estimate 64.3 mpg = est. 7.97 gallons.
includes calculated 3.17 oz MMO" |
2016-11-09 |
529.9 |
8.645 |
61.3 |
Avg spd 40 mph
Est. mpg 64.8
Est. gal. 8.177" |
2016-11-15 |
573.7 |
8.931 |
64.24 |
"Shell on Silas Deane Hwy, near I-91.
Avg speed 42 mph
Est. gal. 8.666
Fill amt incl. 3.5 oz MMO" |
2016-11-18 |
386.5 |
5.947 |
64.99 |
"43 mph average
Rte 85 Shell" |
2016-11-23 |
559.4 |
8.807 |
63.52 |
"Est. gal. 8.54
Fill amt incl. 3.4 oz MMO
Avg spd 43 mph
Filling station not ID'd on receipt. Probably Rte 85 Shell in Waterford." |
2016-12-01 |
577.7 |
9.515 |
60.71 |
"Avg spd 43 mph
3.6 oz MMO (Calc'd)
FCD estimate 63.9 mpg" |
2016-12-02 |
129.6 |
2.372 |
54.64 |
"Short tank. I don't recall what circumstances yielded such low mpg - likely either very nasty weather and/or a lot of short trips.
Fill amt. includes 0.92 oz MMO
Filled early because I had mounted the snow tires. So this fill represents the last use of summer tires this season.
For future fillups, driving with snow tires:
FACTOR: 0.97886
Multiply displayed distance by the FACTOR, to get the actual distance.
Snow tires are 155/65-14.
Original size is 165/65-14." |
2016-12-10 |
571.3 |
8.888 |
64.28 |
"Avg spd 42 mph
Est. 65.8 mpg
ODO miles 583.6 * Factor 0.97886 =" |
2016-12-14 |
567 |
8.85 |
$2.319 |
64.07 |
"Westerly Shell.
Avg spd. 41 mph
Est gallons: 8.565, based on est mpg of 66.2
Added only TWO OUNCES MMO this time.
Calc'd amount was about 3.6 oz.
I want to see if it will run well on less MMO.
Tank includes a trip to NY. I don't recall any nasty weather in this tank." |
2016-12-16 |
342.6 |
5.798 |
59.09 |
"Waterford Shell, Rte 85.
Filled early due to NY trip early the next morning.
45 mph average
Fill includes 1.7 oz MMO
63.9 est mpg on FCD" |
2016-12-19 |
491.98 |
8.21 |
59.92 |
"Fill includes 2.5 oz MMO.
40 mph average.
Filled at Groton Hess, near Dunkin Donuts
60.1 estimated mpg on FCD
First 145 miles was in SNOW: to New London to pick up Mike, then to Long Island, NY. Car pulled only 48.4 mpg driving in mostly unplowed or long-ago-plowed snow. Rain began as we passed through the Bronx, so soon the roads were only wet, not snowy. Arrived at destination with a big 50 mpg showing on the FCD.
Traction with the new Nokian snow tires was OK. I had to be cautious. When I got home, there were a few inches of snow in the driveway and I needed a running start to get up it.
I pulled 70 mpg (FCD) coming home. Driving around in PW got me the usual ~45 mpg.
Then, a usual mix of commutes after that. But one day, it was only about 20ºF, so that hurt things. And a day of no work (dental issues) with some local trips also brought the numbers down." |
2016-12-24 |
509 |
8.669 |
58.71 |
"Madison rest stop, southbound on I-95
FCD est. 63.4 mpg
avg spd 43 mph
includes 3.4 oz MMO" |
2016-12-29 |
548.46 |
9.075 |
60.44 |
"Westerly Shell
47 mph avg.
includes 3.4 oz MMO
Continuing to correct miles for the slightly smaller snow tire size." |
2017-01-08 |
566.37 |
9.49 |
59.68 |
"Pre-fill in RI where gas is cheaper.
FCD est. 63.2 mpg
Est. 3.66 oz MMO
avg spd 42 mph
Rough weather, and drove with occupant who needed conventional driving..." |
2017-01-13 |
549.14 |
8.751 |
62.75 |
FCD est. 64.8 mpg
avg spd 42 mph
includes 3.5 oz MMO
Weather-wise, the last month or so has been pretty brutal. Weather seems to be warming up a bit - one of the few benefits of climate change.
In 20 degree weather, a trip to work or back nets about 60-61 mpg. In 45ish degree weather, I can pull high 60's, and even saw 71 once in a recent week. I had a nice tail wind that day." |
2017-01-17 |
568.8 |
8.945 |
63.59 |
"Snow tires:
Distance factor: 0.97886
(recorded distance is corrected for factor)
Est. MPG: 65.5 = 8.684 gal estimate
Avg Speed: 47 mph
Fill qty includes 3.5 oz MMO
Thankfully the weather has been a bit more gentle. Less precipitation, and slightly warmer temps." |
2017-01-23 |
522.9 |
8.094 |
64.6 |
"Shell, Rte 85, Waterford
Est. 67.9 mpg
Doing much better now. Some commutes over 70 mpg on the display.
Avg Spd. 43 mph" |
2017-01-27 |
500.295 |
8.165 |
61.27 |
"Salem Shell on Rte 85
Est 64.6 mpg
Avg speed 44 mph
Fill includes calculated 3.16 oz MMO" |
2017-02-06 |
714.27 |
11.603 |
61.56 |
"The tank doesn't hold 11.6 gallons.
And no, I didn't drive 714 miles without fueling.
I did a partial fill four days prior to the recorded fill. The recorded fill includes the combined miles AND the combined fuel qty.
Pre-fill at Valero in Colchester, CT.
Fill at Rte 85 Shell in Waterford, CT.
Estimated mpg 65.5 (Insight's FCD)
Avg Speed 45 mph (I've been driving faster lately)
Fill qty includes 3 oz MMO added in Waterford, none added in Colchester.
Distance (miles) is adjusted for snow tires." |
2017-02-13 |
499.12 |
8.532 |
58.5 |
"Rte 8 Shell in Waterford CT.
Avb speed 42 mph
Fill includes 3 oz MMO
Distance corrected for snow tires in use.
MPG has suffered. Granted, one trip was over snowy roads. That takes a toll - one earlier trip driving on 4-5"" of crumbled snow netted 48 mpg until we got to cleared pavement. Plus some very cold mornings and some nasty headwinds.
I will be watching to see if mpg improves properly under better conditions. If not, I'll need to investigate for a cause." |
2017-02-17 |
584.38 |
9.272 |
$2.469 |
63.03 |
"Shell Gas in Old Saybrook, Boston Post Rd. on west side of town.
Fill includes 3.6 oz MMO.
Miles are corrected for snow tires.
Avg Speed 43 mph
66.2 mpg was the FCD estimate." |
2017-02-22 |
581.44 |
8.885 |
65.44 |
"Filled at Rte 8 Shell in Waterford CT
Avg. speed 47 mph - due to road trip to PW, NY.
Est. mpg (on FCD) 69.7
3.6 oz MMO included in fill data
Miles are corrected for snow tires in use.
Weather has been NICE! No snow for this tank. Temps slightly warmer, some days in the 50's F. that was true for the NY trip, which I'm sure helped a lot." |
2017-02-28 |
582.42 |
8.936 |
65.18 |
"Avg speed 42 mph
She'll Gas, Rt 85 in Waterford
Weather has been improving!
Front grill block (the smaller one) is OK up to about 50°F outside temp. I need to remove it about 50% of the time now, or more, to prevent overheating." |
2017-03-05 |
496.478 |
7.837 |
63.35 |
"Westerly Shell, along the river.
Snow Tires Factor 0.97886
42 mph avg speed
est. 66.5 mpg would be 7.627 gal
Fill was .211 gal over the estimate
Fill amount 7.837 includes 3 oz MMO" |
2017-03-12 |
603.95 |
9.041 |
66.8 |
"I really did have a ~604 mile tank.
Filled at Mystic Shell on 27 by McD.
Svc speed 43 mph.
Est mpg: 68.3
We had some nice weather in the 50's°F. And I did some serious EOC when I had good tailwinds." |
2017-03-23 |
564.998 |
9.621 |
58.73 |
"Filled with 93 octane High Test
Shell Gas, Rte 85, Waterford
Avg spd 40 mph
Est mpg 64.3 = 8.977 gal.
Finding the actual fill this much over the estimate is unusual. I had the car facing the other way around at the pump, not my usual. So slight slope of car and tank was reversed from the usual. Or possibly the prior fill was a bit short, leaving more room for fuel in this fill." |
2017-03-29 |
561.49 |
8.962 |
62.65 |
"Avg speed 40 mph
Crazy weather. Some nice, some right around freezing, some windy, some rainy. They call that ""spring"" up here in New England.
Hi-test 93 octane, in prep for Green Grand Prix.
Shell in Glastonbury, Main Street.
Includes 2.2 oz MMO
100.1 miles into this tank, I had the snow tires removed and the RE92s reinstalled. Applied the snow tire correction factor to the first 100 miles of tank." |
2017-04-06 |
679.1 |
10.898 |
62.31 |
"Green Grand Prix 2017 trip.
FCD estimated mpg: 65.5
Fill includes 3 oz. MMO.
Filled at Stewarts #376 in Wurtsboro, NY.
Includes a partial 'fill"" of only 1.309 gal in Middletown, CT, on the way up to NY.
Avg speed 44 mph.
This fill was non-ethanol, 91 octane. The Middletown mini-fill was Premium E-10." |
2017-04-07 |
187.8 |
2.888 |
65.03 |
"Green Grand Prix:
TOPS fillup prior to track event.
FCD-Estimated MPG: 64.1 mpg
Fillup includes 2.265 gal at Lake's Gas in Montour Falls, and 1 ounce MMO.
This fill represents the trip to Watkins Glen area from Wurtsboro, NY - where I loaded in the first E-0 fuel." |
2017-04-08 |
276.9 |
4.345 |
63.73 |
"Filled with E-0, 91 octane, in Wurtsboro, NY, on trip homeward from GGP.
Est. mpg 68.3 mpg
Fill includes 1.8 oz MMO
This tank includes the track competition (FCD 78.0 mpg) PLUS the autocross. Autocross used a lot of fuel - I needed to idle engine continuously to warm it (at high rpms), and then continue idling between the runs to keep it warmed up. The runs themselves were something like 11 mpg.
The trip East from Horseheads area was relatively fuel efficient. Weather was around 38-40 at the start, and climbed during the day. Tailwind of about 15 mph was very nice. When I got home, the FCD showed 74.9 mpg for the 338.9 miles from the Horseheads area to home." |
2017-04-14 |
727.3 |
9.775 |
74.4 |
"Avg speed 42 mph (from the ScanGauge; I think it includes a certain amount of stopped time).
Car's digital display indicated 74.4 mpg; this is the first time it's turned out to be accurate in approximately forever.
This finished off the tank of 91 octane E-0 that I got in Wurtsboro, NY after the 2017 Green Grand Prix. Had a nice 15 mph tailwind the whole way home. Then a pretty decent 4-day week commuting; no work on Good Friday.
Fill amount includes 0.51 gallons in Mystic, 4 oz Marvel Mystery Oil, and a full fillup at I-95 Exit 3 in RI.
I probably could have made it all the way to the RI station without the .510 gallon mini-fill that I gave it in Mystic. Tank supposedly holds 10.6 gallons so this is a legitimate tank. Definitely my longest running and highest-mpg tank so far." |
2017-04-23 |
600.5 |
8.656 |
69.37 |
"Avg speed 40 mph
Filled at Fairfield CT rest stop on I-95 southbound.
Mobil.
Includes 3.4 oz Marvel Mystery Oil." |
2017-04-27 |
649.5 |
9.104 |
71.34 |
"Valero, Berlin Tpk
Mid-grade
Avg spd 39
Est mpg 72.3
I'm assuming 4 oz MMO" |
2017-05-04 |
640.5 |
9.225 |
69.43 |
"No MMO this time
Est. 71.4 mpg = est. 8.970 gal.
Avg. spd. 39 mph
Filled at Glastonbury Shell on Main St." |
2017-05-18 |
740.5 |
10.862 |
68.17 |
"Filled at no-name station in Mass.
Did a pre-fill before the MA trip, included in tot gas + mi.
Includes 4 oz MMO.
Avg speed 40 mph
Est MPG 68.8 = 10.763 gal. estimated" |
2017-05-20 |
635.2 |
9.141 |
69.49 |
"Waterford Shell
Est mpg 68.3
Avg spd 43 mph" |
2017-05-26 |
627.4 |
9.765 |
64.25 |
"42 mph avg
Incl 2 oz MMO
Waterford Shell, Rt 85
Est mpg 67.4. Turned out under that." |
2017-06-04 |
606.7 |
8.445 |
71.84 |
"Filled at Mobil on I-95 northbound, Branford, CT, about 6 pm on trip back home from PW, NY.
Fill qty includes 2 oz MMO.
Avg spd 42 mph
Est mpg: 71.2 = lest fuel 8.521 gal.
I did better than the estimate!" |
2017-06-08 |
611.4 |
9.137 |
66.91 |
"Incl 2 oz MMO
Est mpg 68.6
40 mph avg
Wtfd Shell Rte 85" |
2017-06-15 |
606.6 |
8.485 |
71.49 |
"Avg spd 49 mph
Filled at art 85 Shell, Wtfd.
Incl. 2 oz MMO
Eat mpg: 71.2. It turned out better." |
2017-06-22 |
530.7 |
8.16 |
65.04 |
"Westerly, RI Mobil on Rte 1 (Alltown)
est. mpg: 68.8
Avg speed 39 mph
The next day (today), I discovered left front tire was at 12 lb psi. The rest were at 52. I don't know yet if its a very slow leak or what. Likely was affecting mpg for a while." |
2017-06-29 |
600.5 |
8.518 |
70.5 |
"Mobil in Westerly, RI
2 oz MMO
Estimated mpg 72.3 = Est. 8.306 gal.
Actual was about .2 gal higher.
Avg speed 40 mph" |
2017-07-10 |
702.5 |
9.621 |
73.02 |
"Phillips 66 in East Hartford. NOT Tier 1 fuel.
Avg spd 40 mph
FCD Estimate: 71.2 mpg = 9.867 gal
Actual was about .2 gal less than that.
Weather has been ideal. Only slight rain, occasionally. Otherwise, temps are about the max I can tolerate without a/c. I use it about once or twice a week now." |
2017-07-19 |
673.4 |
9.284 |
72.53 |
"Phillips 66, Main St., East Hartford
Avg speed 42 mph
Est. 73.7 mpg = 9.137 est gallons
Fill data includes 2 oz Marvel Mystery Oil in the fuel.
That's standard for me.
I had the front sway bar links replaced a couple days before this fillup. Car handles a lot better now.. Don't need to slow down as much for turns or curves." |
2017-07-27 |
655 |
9.525 |
68.77 |
"Phillips 66 East Hartford
2 oz MMO
39 mph avg spd
Did not record dash mpg estimate" |
2017-08-01 |
659.6 |
8.985 |
73.41 |
"Rte 85 Shell, a Waterford, CT
Eat 74.7 mpg = 8.829 gal est.
Avg spd 44 mph
Incl. 2 oz MMO" |
2017-08-11 |
649.9 |
9.474 |
68.6 |
"Xpress/Hess, Rte 12, Groton
40 mph avg
2 oz MMO
Est 69.0 mpg = 9.419 gal
Tank included some heavy rain and some nasty hot wearher." |
2017-08-21 |
652.5 |
9.272 |
70.37 |
"Xpress Fuel
Incl 2 oz MMO
Avg spd 42 mph
Est mpg 71.4" |
2017-08-28 |
620.1 |
8.6 |
72.1 |
"Xpress Fuel
Incl 2 oz MMO
Avg spd 45 mph
Est mpg 74.2" |
2017-09-04 |
620 |
9.286 |
66.77 |
"Xpress Fuel, Groton
Est mpg: 69.5
Avg spd: 41 mph
Incl 2 oz MMO" |
2017-09-12 |
626 |
8.656 |
72.32 |
"Xpress Fuel in Groton
Avg spd 43 mph
Includes 1 oz MMO
Est mpg: 72.6" |
2017-09-16 |
345.2 |
4.932 |
69.99 |
"Fillup one day before NY road trip.
Est mpg, 73.0
A good spd 42 mph
Incl 1 oz MMO." |
2017-09-22 |
663 |
9.559 |
69.36 |
"Includes trip to PW, NY.
Avg spd 47 mph - much higher than my usual. Been commuting a bit faster, it's not just from the NY trip.
Xpress Fuel in Groton.
Incl. 3 oz MMO
Did not note the estimated mpg." |
2017-09-29 |
666 |
9.657 |
68.97 |
"48 mph avg
Incl 2 oz MMO
Xpress Fuel, Groton" |
2017-10-09 |
737.8 |
11.275 |
65.44 |
Includes 2 oz MMO" |
2017-10-16 |
592 |
9.025 |
65.6 |
44 mph avg
Incl 2 oz MMO
Est. 69.3 mpg" |
2017-10-23 |
638.1 |
9.691 |
$2.769 |
65.84 |
"Filled at Cumberland Farms, Glastonbury, CT
Est 69.0 mpg
Avg spd 47 mph
Fill record includes 2 oz Marvel Mystery Oil = MMO" |
2017-10-29 |
566.9 |
9.121 |
62.15 |
"Xpress Fuel, Groton, CT
est. mpg: 66.9
avg spd: 45 mph
2017-11-06 |
542.1 |
8.083 |
67.07 |
"Filled at 184 Mobil, Mystic
Est. 65.5 mpg
avg speed 39 mph
no MMO this time" |
2017-11-30 |
586.1 |
9.583 |
61.16 |
"Est. mpg: 64.1
Avg spd: 41 mph
Includes 2 oz Marvel Mystery Oil
Filled at Express Fuel, Groton" |
2017-12-03 |
473.3 |
7.5 |
63.11 |
"Express Fuel, Groton
Est. mpg: 66.9
Avg Speed: 42 mph" |
2017-12-06 |
328.6 |
4.784 |
68.69 |
"No MMO this time.
Filled at Mobil on Rte 12 near Honda dealer - because I used their free air pump for a while.
Est mpg. 65.5
Avg spd. 42 mph" |
2017-12-23 |
405.4 |
7.534 |
53.81 |
"Mystic Mobil, Rt 27 near I-95
Avg spd 34 mph
est. 58.7 mpg
Includes Winter Tires Factor 0.97886" |
2018-01-09 |
543.9 |
9.799 |
55.51 |
"Fill includes 2 oz MMO.
FCD estimate: 58.9 mpg.
42 mph average.
This would have included several weeks of local driving; I was out of work beginning Nov. 1.
2018-01-18 |
557.1 |
8.902 |
62.58 |
"Est mpg: 64.1
Avg spd: 45 mph
2018-01-30 |
751.9 |
12.231 |
61.47 |
"This includes a pre-fill a few days before, 3.253 gallons.
Est mpg: 64.6
Avg spd: 47 mph
No MMO noted on receipts so I didn't add it into the fuel qty.
2018-02-13 |
744.9 |
13.423 |
55.49 |
"Includes 2 pre-fills.
Avg spd 42 mph
Est Mpg 61.3
2018-02-21 |
677.3 |
10.302 |
65.74 |
"Est mpg: 66.7
Avg spd: 44 mph
Includes 2 oz MMO
Includes a pre-fill; I didn't get 691 miles on the tank without that assist.
2018-03-07 |
632 |
10.328 |
61.19 |
"Est. mpg: 63.2
Avg spd: 42 mph
REFERENCE NOTE:
Winter tires installed prior to the 12/23/17 fillup.
I had them balanced 12/10 before mounting them." |
2018-03-19 |
586.9 |
9.648 |
$3.379 |
60.83 |
"High test: 92 or 93 octane.
On I-95 northbound, Madison, CT
Avg spd 46 mph
Est. mpg: 64.6 mpg
No MMO this time.
High octane in preparation for upcoming Green Grand Prix, Apr. 13." |
2018-04-12 |
658.3 |
9.934 |
66.27 |
"Car had been very lightly used for several weeks, then put up on ramps + jack stands for two weeks prior to Green Grand Prix for belly pan build project. Thus no fillup for about a month.
This fill at Dutch's Market in Greentown, PA. Fill amount also includes a pre-fill of 0.700 gal about 30 miles prior - I may not have made it to Dutch's otherwise!
No Marvel Mystery Oil was being used prior to the GGP.
This fill: 91 octane, no ethanol, no MMO.
Pre-fill: 93 octane, no MMO, but WITH ethanol
Est mpg: 66.2
Avg speed: 46 mph
From home to Dutch's: 215 miles, per Google's route" |
2018-04-13 |
161.7 |
2.694 |
$3.109 |
60.02 |
"Ethanol-Free at Lakes Gas in Watkins Glen. (2.2 gal)
Plus 0.494 gal at the required fill at TOPS Gas in WG.
Total 2.694
Est MPG unknown, sorry
No MMO used.
They had us do our own fills at TOPS this year.
I gave it an extra squeeze so it was pretty full.
That likely accounts for the lowish mpg calc'd off this fill.
Also, the Lakes pump is an old school one with rotating number wheels. Likely not nearly as accurate as modern pumps." |
2018-04-14 |
133 |
1.929 |
$3.099 |
68.95 |
"Coldiron Fuel in Elmira, after breakfast at Anne's Pancakes Natural.
Google did an awful job of getting me to this place.
2000 College Avenue, Elmira.
Pump is in the back in the diesel truck filling area.
35 mph avg.
no est. mpg
These miles include the GGP competition plus driving around the WG/Elmira area." |
2018-04-14 |
172.4 |
2.901 |
59.43 |
"Est mpg. 73.3 !
Stewarts Shop #376, Wurtsboro, NY
Nice new, small Vegetarian restaurant in this town.
I don't know how or why the calc'd mpg is so different from the estimate on the car's computer. The fillup location is sloped. Maybe that's it. The next fillup data may balance this off." |
2018-04-20 |
682.7 |
9.565 |
$3.149 |
71.37 |
"Now I'm back to regular 10% ethanol fuel, with MMO added.
Filled in Mystic, Rte 27 Shell near McDonald's.
Est. mpg 68.6
Avg speed 48 mph
Includes 2 oz. MMO" |
2018-04-25 |
410.2 |
6.459 |
63.51 |
"I only could take 6.459 gal, but since I was in Westerly anyway, where gas is a bit cheaper, I filled up there. Shell on Main Street, approaching Beach Street.
Includes 1.5 oz MMO
44 mph avg.
Est. mpg: 66.2" |
2018-05-08 |
862.8 |
12.908 |
66.84 |
avg speed 47 mph
est. 70.2 mpg
incl. 2.5 oz MMO" |
2018-05-15 |
618.2 |
8.894 |
69.51 |
"Gulf on Mass Tpk
68.6 est. mpg
avg speed 46 mph
includes 0.016 gal MMO" |
2018-05-21 |
573.5 |
8.497 |
67.49 |
"Xpress Fuel
est. mpg: 6.79
Avg spd: 45 mph
includes 1.5 oz MMO." |
2018-05-31 |
724.6 |
10.63 |
68.17 |
"Xpress Fuel Groton
Includes a 2.005 gal pre-fil the day before.
70.2 est. mpg
avg speed 46 mph
2018-06-07 |
623.6 |
9.069 |
68.76 |
"Xpress Fuel Groton
Includes 2 oz MMO
est mpg: 96.3" |
2018-06-28 |
586.7 |
8.965 |
$2.939 |
65.44 |
"Incl. 2 oz MMO
Est. 68.1 mpg
avg 42 mph" |
2018-07-05 |
559.7 |
9.201 |
$2.939 |
60.83 |
"Est. 63.2 mpg
avg spd 42 mph
includes 2 oz MMO" |
2018-07-12 |
512.9 |
7.885 |
$2.939 |
65.05 |
"Est. 65.5 mpg
avg 45 mph
incl. 2 oz MMO" |
2018-07-23 |
566.1 |
9.435 |
$2.939 |
60 |
"Estimated 63.2 mpg
Avg spd 42 mph
Fill includes 2 oz MMO" |
2018-08-12 |
451.4 |
7.856 |
57.46 |
"No MMO in this fillup
estimated 58.0 mpg
29 mph avg speed" |
2018-08-31 |
503.7 |
9.2 |
54.75 |
"Est. 55.4 mpg
avg spd 29 mph
no MMO noted on receipt" |
2018-10-24 |
536.8 |
9.145 |
58.7 |
"59.6 est. mpg
avg 29 mph
2018-11-05 |
370.2 |
6.312 |
$2.729 |
58.65 |
"Est. 61.3 mpg
avg spd 37 mph
includes 1.5 oz MMO" |
2018-11-13 |
537.3 |
9.088 |
59.12 |
"est 62.2 mpg
45 mph avg
Incl. 2 oz MMO" |
2018-11-19 |
491.9 |
8.92 |
55.15 |
"Stop + Shop station in Glastonbury
MMO not noted on receipt
est. 58.5 mpg
avg spd 48 mph" |
2018-12-04 |
496 |
8.833 |
56.15 |
"This was the fillup immediately after having the spark plugs replaced.
Also had snow tires put on in the same shop visit.
(use for subsequent fills)
Because the snow tires are slightly smaller diameter.
High-test
Est. 58.5 mpg
avg 40 mph
Patrick Sullivan Station, 8:44 a.m.
382 Vauxhall St, New London" |
2018-12-09 |
498.04 |
8.385 |
59.4 |
"Xpress Fuel - Groton
est. 62.7 mpg (oem computer)
Avg spd unknown - ScanGauge computer reset itself when battery power dropped too low.
Distance corrected for snow tires." |
2018-12-18 |
553.56 |
9.073 |
61.01 |
"Xpresss Fuel Groton
HIGH TEST - 93 octane
No MMO in this fill.
Est. 63.9 mpg
No avg speed - it zeroed out." |
2019-01-03 |
544.93 |
8.808 |
61.87 |
"Cumberland Farms, Glastonbury
estimated 64.8 mpg
50 mph average (!)
fill includes 2 oz MMO
NOTE: Driving this tank, it may be going into lean burn less often and less easily. Cheap Cumby Farms gas might not be the best." |
2019-01-09 |
544.93 |
8.931 |
61.02 |
"Xpress Gas Groton
No MMO this fill.
No avg. speed." |
2019-01-16 |
594.07 |
9.869 |
60.2 |
"Includes 2.5 oz MMO
Xpress Gas, Groton
49 mph avg. (over 493 mi of the tank)
Car's B trip zeroed out due to fumble fingers. Distance derived by math and confirmed by ScanGauge. So, no estimated MPG.
Replaced 12V battery on 1/13/2019. Old was AGM, undersized, 20AH capacity. New is AGM Group 51 by ""Champion"". I fully charged it in garage before installation. It needed about 1.5 hours at 10A to show as fully charged." |
2019-01-22 |
474.26 |
7.958 |
59.6 |
"Xpress Gas, Groton
est. mpg: 62.5
Avg speed 48 mph
Now running on new AGM battery, stock Group 51 size.
It started off that battery at 1ºF!" |
2019-01-28 |
510.38 |
8.639 |
59.08 |
"Xpress Fuel Groton
Est mpg: 62.5
Avg spd: 48 mph" |
2019-02-01 |
474.94 |
8.019 |
59.23 |
"Village Market, Ledyard CT
No MMO
Est mpg: 63.2
Avg spd: 51 mph" |
2019-02-15 |
485.81 |
8.25 |
58.89 |
"Xpress Fuel Groton
Est. mpg: 64/3
Avg spd: 48 mph" |
2019-02-22 |
568.42 |
9.448 |
60.16 |
"Xpress Fuel Groton
Est mpg: 62.7
Avg spd: 50 mph
incl. 2 oz MMO" |
2019-03-03 |
674.43 |
11.522 |
58.53 |
est. 62.2 mpg
49 mph avg
No MMO" |
2019-03-11 |
490.41 |
8.575 |
57.19 |
"Shell Henny Penny Rte 12 Groton
501 mi.
Est 61.3 mpg
avg spd 50 mph" |
2019-03-16 |
561.96 |
9.159 |
61.36 |
"Shell Henny Penny on Rt 12 Groton
No MMO
54 mph avg spd
Est. mpg: 65.0" |
2019-03-29 |
142.91 |
2.299 |
62.16 |
"Shell high test in Norwich on the way to work.
2 oz MMO included in fill.
Added because I felt minor bucking when going in/out of lean burn. Been running without MMO for a while; I think the passages might need a bit of a cleaning.
Distance is corrected for winter tires.
They were swapped off about 40 miles before this fillup.
Now back on summer Potenzas!
Green Grand Prix is ONE WEEK from today!" |
2021-11-30 |
521.928 |
9.41 |
$3.369 |
55.47 |
"On Nov 4 2021, I started commuting again, about 50 miles each way. So I'll log my fillups here. Been working very few hours, and from home, since Mar. 2020. I've been commuting on snow tires so....
Winter Tires Factor 0.97886 (They're a slightly smaller outer diameter due to being 155 width instead of 165. That's what was available for my Gen. 1 Insight.)" |
2021-12-10 |
560.005 |
9.912 |
$3.279 |
56.5 |
"Yesterday I put the radiator blocker in. It fits between the rad and the AC condenser. I should have done that sooner, but at least it's in now.
I have a nice grill/bumper cover that I didn't even bother putting on last winter. Hopefully I'll be able to install it tomorrow, Saturday. :-)
I aired up my tires to 46 psi before I restarted commuting, just before Thanksgiving. I should check them this weekend; it's been colder. Sometimes around 30ºF in the mornings, usually between 30-35º. I used to keep them around 50 psi; I might do that again." |
2021-12-21 |
509.11 |
8.179 |
62.25 |
2022-01-04 |
519.21 |
9.295 |
$3.279 |
55.86 |
2022-01-13 |
479.84 |
9 |
53.32 |
"All entries currently use the factor *.97886 to correct for the smaller diameter of my winter tires." |
2022-01-25 |
500.3 |
9.382 |
$3.289 |
53.33 |
2022-02-03 |
530.6 |
9.198 |
$3.379 |
57.69 |
"XPress Fuel in Groton, CT." |
2022-02-18 |
519.9 |
9.544 |
54.47 |
2022-03-03 |
558.24 |
10.609 |
52.62 |
"I did a pre-fuel on Mar 2. Numbers here are a total for the Mar 2 and Mar 3 fuelings. Miles are corrected downward for the slightly smaller winter tires." |
2022-03-10 |
384.2 |
7.143 |
$4.259 |
53.79 |
"I fueled early due to an incoming storm." |
2022-03-18 |
517.52 |
9.1 |
$4.179 |
56.87 |
"Distance corrected by a factor of 0.97886
for the winter tires.
I've been meaning to track Avg Speed Per Tank here. Maybe this note here will remind me..." |
2022-03-29 |
561.1 |
9.916 |
56.59 |
"Avg Speed: 50 mph (from ScanGauge)" |
2022-04-07 |
556.4 |
10.245 |
54.31 |
"Avg speed 54 mph (ScanGauge shows this in even miles)
Still on winter tires. They should come off soon." |
2022-04-15 |
591.23 |
10.194 |
58 |
"Avg speed: 49 mph
I'm still on winter tires. I need to get the regular ones back on the car!" |
2022-04-26 |
507.8 |
8.373 |
60.65 |
"Avg speed: 52 mph.
Berlin Gulf - not the Citgo. I believe Citgo shows and charges a larger qty of fuel than was actually pumped. Because my tank is only 10.6 gal and I've had several fills very close to that at Citgo - but the gauge didn't say the tank was nearly empty." |
2022-05-03 |
432.1 |
8.115 |
53.25 |
"Avg spd: 49 mph" |
2022-05-12 |
515.3 |
8.687 |
$4.179 |
59.32 |
"Avg speed: 47 mph" |
2022-07-06 |
382.4 |
6.42 |
$4.559 |
59.56 |
"Avg Speed: 35 mph." |
2022-08-21 |
420.4 |
8.396 |
50.07 |
