2016-12-16 |
13.702 |
$2.19 |
27.73 |
"First tank of fuel... No ecomods on the car, no real hypermiling(in fact some WOT acceleration for sake of playing), and seriously frigid temperatures(one commute was made at 8*F)... Hopefully the next tank will be above 30mpg..." |
2016-12-25 |
437.1 |
14.364 |
$2.25 |
30.43 |
"This car's got a huge fuel tank! It was still showing a quarter tank remaining and I got a nice comfortable nearly 440 miles! I coulda gone further, but I did a couple WOT acceleration pulls(measured 0-60 and 0-100) for a baseline... Also experimented with some grille blocking, which has bumped average coolant temp by 3* or so... Tires are still at 45psi... Onward and upward!" |
2017-01-03 |
302.4 |
10.47 |
$2.26 |
28.88 |
"A trip through the Allegheny Mtns, to Mt Storm... 9% grades and such... Some parts of the trip weren't hypermiling, but instead enjoying the road... Car is still mostly stock, with some grille blocking... Mountainous portions of he trip done in manual mode, and flat portions done in drive... The trans doesn't allow EOC, so all I can do is DWL" |
2017-01-05 |
322.3 |
10.491 |
$2.35 |
30.72 |
"A little of everything, some freeway, some local... Temps wildly varied on this tank, between 26* to 50*... Some driving in snow, and lots of wet roads... Replaced the missing front belly pan piece with one fabricated from black coroplast... So far, not too shabby..." |
2017-01-13 |
461.4 |
15.047 |
$2.14 |
30.66 |
"from shock, WV to Sylvania, OH, with detours to Fremont... Cruising speeds were set based on average speed, and not mileage, so the results aren't too bad, given temps in the high twenties and low thirties" |
2017-01-14 |
226.3 |
7.445 |
30.4 |
"From McCutcheonville, OH back to Spencer, WV... Went through Columbus instead of around, and drove aggressively once back in WV..." |
