2014-01-20 |
185 |
10.346 |
17.88 |
"I had owned the car about 6 years prior to this fill, but this is the point when I started looking into getting better gas mileage. Less than 18 MPG in a car, really?" |
2014-02-04 |
169 |
8.976 |
18.83 |
2014-02-13 |
211 |
10.488 |
20.12 |
2014-03-01 |
243 |
10.796 |
22.51 |
2014-03-15 |
282 |
11.617 |
24.27 |
2014-03-22 |
404 |
14.064 |
28.73 |
2014-04-09 |
315 |
11.699 |
26.93 |
2014-05-08 |
11.826 |
24.69 |
2014-05-25 |
293 |
10.255 |
28.57 |
2014-06-04 |
10.941 |
$3.449 |
31.99 |
2014-08-01 |
344 |
12.503 |
27.51 |
2014-09-15 |
321 |
12.436 |
25.81 |
2014-10-02 |
357 |
11.674 |
$2.969 |
30.58 |
2014-10-11 |
11.539 |
30.33 |
2014-11-12 |
316 |
12.753 |
$2.869 |
24.78 |
2014-12-06 |
291 |
11.957 |
$2.429 |
24.34 |
2015-01-02 |
253 |
10.762 |
$1.979 |
23.51 |
2015-01-14 |
249 |
12.448 |
$1.899 |
20 |
2015-02-02 |
250 |
10.917 |
$1.829 |
22.9 |
2015-02-18 |
279 |
12.835 |
$2.109 |
21.74 |
2015-02-27 |
258 |
11.359 |
$2.249 |
22.71 |
2015-03-21 |
12.127 |
23.67 |
2015-04-18 |
361 |
13.605 |
26.53 |
2015-06-11 |
365 |
13.892 |
26.27 |
2015-07-19 |
12.262 |
$2.289 |
28.14 |
2015-09-01 |
361 |
12.666 |
$2.829 |
28.5 |
2015-09-25 |
295 |
10.479 |
28.15 |
2015-10-23 |
372 |
12.82 |
$2.369 |
29.02 |
2015-11-11 |
317 |
11.982 |
$2.219 |
26.46 |
2015-12-12 |
251 |
10.555 |
$1.819 |
23.78 |
2015-12-30 |
263 |
11.833 |
$1.899 |
22.23 |
2016-01-18 |
300 |
13.438 |
$1.699 |
22.32 |
"229755
Cold!" |
2016-01-27 |
327.5 |
12.875 |
$1.659 |
25.44 |
"230082.5" |
2016-02-13 |
263.5 |
11.812 |
$1.549 |
22.31 |
"230346" |
2016-03-08 |
321 |
12.322 |
$1.899 |
26.05 |
"230667" |
2016-04-10 |
13.673 |
$1.739 |
25.23 |
"231012" |
2016-06-02 |
303 |
10.885 |
$2.179 |
27.84 |
"231315" |
2016-06-26 |
372 |
12.195 |
$2.139 |
30.5 |
"231687" |
2016-07-22 |
12.549 |
$2.039 |
28.61 |
"232046" |
2016-09-10 |
11.094 |
27.13 |
"232347" |
2016-10-07 |
13.855 |
$2.069 |
27.43 |
"232727" |
2016-10-27 |
370 |
13.989 |
26.45 |
"233097" |
2016-12-09 |
315 |
13.652 |
23.07 |
"233412" |
2016-12-31 |
310 |
12.673 |
$2.259 |
24.46 |
"233722
Was hoping to stretch this tank into the new year, but had to run an errand and I don't play chicken with the gas light in the winter." |
2017-01-18 |
338 |
13.639 |
24.78 |
"234060, botched correction factor on SG" |
2017-02-10 |
331 |
13.266 |
24.95 |
"234391
SG estimated 15 gal, since I put it on a borrowed pickup for a couple trips. In hindsight, I shouldn't have done any recalibration." |
2017-02-28 |
311 |
12.001 |
25.91 |
"234702
Gas pump kept clicking off early. I had to finesse the lever to keep it going, so accuracy of this fill is suspect.
SG only estimated 9.1 gal. I went all the way on compensation because I would rather have a pessimistic readout." |
2017-03-30 |
306 |
13.408 |
$2.149 |
22.82 |
"235008
Disappointing. Despite warmer weather, avg MPG is trending back down, not sure I can blame it on the goofy pump of the previous fill.
Also needed to adjust SG down again. Time for summer tires?" |
2017-05-30 |
12.737 |
23.63 |
"235307
Finally put on my summer tires a few days ago. Mileage is still not great, but at least I'm biking more. SG estimated 13 gal." |
2017-07-21 |
255 |
9.973 |
$2.149 |
25.57 |
"235562" |
2017-08-12 |
346 |
12.575 |
$2.149 |
27.51 |
"235908" |
2017-09-01 |
297 |
12.142 |
24.46 |
"236205" |
2017-10-10 |
390 |
14.155 |
$2.289 |
27.55 |
"236595" |
2017-11-18 |
314 |
13.603 |
$2.489 |
23.08 |
"236909
Car was parked at a slight incline at this gas station, so I'm hoping the MPG figure is pessimistic." |
2018-02-09 |
286 |
14.992 |
19.08 |
"237195
First tank under 20MPG in a while. Perhaps some gas evaporated while I used up this tank?" |
2018-04-04 |
314 |
14.634 |
21.46 |
"237509" |
2018-05-12 |
324 |
12.973 |
24.97 |
"237833
Vent pipe in filler is corroded, could be the cause of evaporation and occasional fuel smell when tank is full." |
2018-06-18 |
305.5 |
12.344 |
24.75 |
"238138.5
Nice and hot out recently." |
2018-06-29 |
335.5 |
12.554 |
26.72 |
"238474" |
2018-08-24 |
348 |
14.249 |
24.42 |
"238822
Mostly highway driving. Think I have a cruddy rotor in back that's affecting my coast." |
2018-09-19 |
13.09 |
25.36 |
"239154" |
2018-09-21 |
291 |
11.998 |
$2.929 |
24.25 |
"239445
Drive up to MN, headwinds" |
2018-09-23 |
329 |
11.914 |
27.61 |
"239774
Drive back from MN, tailwinds" |
2018-09-24 |
375 |
12.886 |
29.1 |
"240149" |
2018-10-18 |
13.619 |
22.91 |
"240461" |
2018-11-12 |
321 |
13.822 |
$3.539 |
23.22 |
"240782" |
2018-12-11 |
270 |
13.849 |
$2.169 |
19.5 |
"241052" |
2019-01-26 |
151 |
7.783 |
$2.1 |
19.4 |
"241477
Topped off tank before trip." |
2019-02-06 |
14.321 |
$2.029 |
23.04 |
"241807
Car has been warming up quicker than usual despite cold temps. Grille blocks are off. Suspect thermostat." |
2019-03-05 |
268 |
14.61 |
18.34 |
"242075" |
2019-06-07 |
156 |
7.916 |
$2.689 |
19.71 |
"242231
Topped off ahead of a trip.
T-stat replaced at 242220." |
2019-06-23 |
363 |
12.621 |
28.76 |
"242594" |
2019-07-19 |
176 |
6.728 |
26.16 |
"242770" |
2019-08-25 |
355 |
14.227 |
24.95 |
"243125" |
2019-11-04 |
315 |
13.666 |
23.05 |
"243440" |
2019-12-13 |
275 |
13.771 |
19.97 |
"243715" |
2020-02-06 |
294 |
14.227 |
20.66 |
"244009" |
2020-02-24 |
299 |
12.859 |
23.25 |
"244308" |
2020-03-18 |
309 |
12.893 |
$1.849 |
23.97 |
"244617
Not long after this fill, I noticed that the car has a slight oil leak that manifests itself as a burning smell. Awesome." |
2020-06-30 |
291 |
12.992 |
22.4 |
"244908" |
